Question about Radio Communications
Hi, I have an AOR AR8200 mk3 that recently would turn off after about an hour of scanning. I have inserted new batteries but now it will not turn on.
You may have it set in sleep mode to turn off after an hour to preserve the batteries (same as you get on a TV). Read the manual and then check if you have
Posted on Mar 21, 2011
Telstra 7100a home phone
Hi, It sounds like the batteries of the handset could be the problem.
Try replacing the batteries with other new batteries. I recently purchased a good brand of battery (not rechargeable), but they were down in their voltage straight out of the package.
Make sure the batteries are AAA NiMH batteries, and that they are charged for at least 16 hours.
Also check that you have inserted them the correct way +ve/-ve.
When you have inserted them, place the phone on the base and the handset should show you it is charging.
Jan 29, 2014 | Lands Phones
1998 grand marquis turns off by itself while running.
If you think the problem is the security system. This is for programming with no keys.
Use a scan tool to verify that the numkeys pid value is less than 8.
Use a scan tool to verify that the sparekey pid value is enable or yes.
Insert either the remaing key or a new cut key and turn to run.
Use the sacan tool to navigate to pats system and then choose security access. The scan will count to 10 minutes before the model will allow you in, once in, choose ignition key codes erase.
Did connect scan tool and turn key off. Inset key and turn to run for 3 seconds, then turn the key off and remove. Insert second second key and turn to run for three seconds, then turn key to off and remove.
Apr 05, 2017 | 1998 Mercury Grand Marquis
I recently changed the security code of my nokia X3-00. Yesterday i changed my mobile's sim card, and now when i turn it on my mobile asks for a new security code. I type my security code which is...
put the first sim on your mobile...but before that follow this steps
* turn off you mobile
* remove battery for an hour
* put it back the turn it on again
* insert the 1st sim that you have made a securitycode,try to change it if its possible
* if success,try to insert the 2nd sim the enter you previous code
if ask for a "new security code" enter 12345 or your previous code
May 31, 2011 | Cell Phones
Ir3570 Takes Half Hour to start printing 3 pages - help!!!
Sounds like you have the wrong driver installed, go to canon website and download a new driver for the machine
Jul 06, 2010 | Canon ImageRUNNER 3570 Copier/Printer
New CDJ1000 MK3 freezing and then turning itself off
CDJ 1000 mk 3 freezing while playing tracks and sometimes freezes when a cd is inserted. The orange cue light comes on but the green play doesnt. Any ideas?
Thanks
Sep 25, 2009 | Pioneer CDJ-1000 CD Player
Golf mk3 2.0L
Hi
One major cause of a hot engine cutting out is crank sensor failure. The sensor overheats, the engine cuts out, and then once everything cools back down the engine will start and run again.
Another possible cause is the O2 sensor.
A live scan would show up any problems.
Regards
Geordie
Jun 21, 2008 | 1996 Volkswagen Golf
MK3 Golf 1.8 Driver M-reg Cutting out.
It may be the fuel filter try having it replaced
Jun 20, 2008 | 1994 Volkswagen Golf
Vivicam 4345
Either the battery is not making proper contact in its chamber or a fuse is open.
Sep 19, 2007 | Vivitar ViviCam 4345 Digital Camera
Radio Communications Logo
154 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
