Question about Whirlpool Dishwashers
We have a whirlpool quiet partner VI (approx 2 1/2 yrs old) and over the past few months the dishes in the top rack have not come clean. Glasses, cups and sm plates do not always come clean requiring hand cleaning. For example Coffee stains do not come off, food debris is not removed as well as heavy spoting occurs. this occurs at either of the rack locations. We keep the rinse aid container filled but with little success. At times the same issues have come up with spoons and forks in the silverware holder. What can i do to fix this? Thank you
  • shreg01 Mar 24, 2011
    The solution worked wonderfully. My dishwasher is working like new. Thanks for the help!
    Guru:
  • 262 Answers
Very common issue
The videos i use here have helped many of my customers.
1.) Ensure the water is draining....
2.) how to clean the filter
click on the link http://www.youtube.com/watch?v=iRCCrEwrst8
3.)How to clean the spray arms.
click on the link http://www.youtube.com/watch?v=iABhGWZN778
If you have ensured the dishwasher is draining and the above did not solve your issue please post the results....this procedure will correct 90% of the issues you have stated on your post.
Please post results.
Keith
Posted on Mar 21, 2011
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Whirlpool Quiet Partner II that used to
ok first prime the sink then put a table spoon of tang in dispensor then run the unit this will clean the dish washer
Jun 30, 2010 | Dishwashers
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Quiet partner 1 top rack does not get clean at all
I would suspect you have debris in the pump that is causing a pressure drop so the water is not spraying well in the upper arm.
Try this procedure to clean out the sump. Let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 24, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Whirlpool Gold dishwasher
Either:
  1. not enough water gets into the dishwasher. check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
Vlad
First Choice Appliance
Mar 21, 2009 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Dishes not clean in bottom rack of Whirlpool Quiet Partner I (du1048xtps4)
check to make sure your lower spray arm openings are not blocked.
Nov 07, 2008 | Dishwashers
Dishwashers Logo
273 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
