Printer light and exclamation point are flashing on my HP Officejet 6500
SOURCE: I have a HP LaserJet 1320n printer and it will not
Possible Solution to your issue!
Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2. There is a paper jam in the printer.
3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
A. Pull the tray out of the printer and remove any paper.
B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
E. Slide the tray back in the printer.
5. The tray 2 paper level indicator is stuck.
6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
A. Turn the printer off.
B. Press and hold down the green GO button.
C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
D. Release the GO button.
NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state
Posted on Feb 23, 2009
Morikvendi
  • 56 Answers
SOURCE: HP printer cannot find access point and I'm not sure what to do.
You must first connect your printer to the pc using usb cable, then run installation wizard that is on the CD that came with the printer.
Wizard will guide you through the setup orcess where you will provider your routers ssid (linksys) to your printer, and your printer will use that ssid to connect to your router.
After the Wizard setup is done, it will tell you to disconnect the usb cable and only then your printer will work on wireless.
Good luck,
Milan
Posted on Jun 01, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
  • 55 Answers
SOURCE: new hp 6500 officejet printer, cannot print checks
This is actually a quick books issue that they blame on the printers
here are the follwing steps to resolve the issue
Quick Books (2009) qbprint.qbp file change
doc&settings\allusers\appdata\inuit\quickbooks
rename above mentioned file to qbprint.old
if its an erlier version of quickbooks ie. 2006, the file path is then: doc&settings\programfiles\inuit\quickbooks then look for the file and rename it
Here is the website from intuit that acknowledges the issue
http://support.quickbooks.intuit.com/support/Pages/KnowledgeBaseArticle/1006446
Posted on Apr 27, 2010
SOURCE: How to scan using a hp officejet 6500?
This outrageous. I buy a new HP Officejet 6500. It wiull not scan and I am asked to pay 20.00 to find out why.
Reggie Spencer
Posted on Nov 10, 2010
I changed the printer cartridge and now there is a blinking light exclamation symbol and it won't print.
I have had brand new print cartridges installed that were bad or were not factory type so they would not work. Check to see if other cartridges also need to be changed. Rich
Apr 13, 2015 | HP Officejet 6500 All-in-One Printer
Why does exclamation point orange light flashing on HP Officejet 7110?
The lights on the front of the HP product can be on, off, or blinking (flashing), depending on the status of the product. The lights indicate product status and are useful for diagnosing printing problems.
For more read... HP Support document and HP Tech Support .
Thanks,
Jun 27, 2014 | HP OfficeJet Office Equipment & Supplies
Hp officejet 6500 copier not starting up
Get the Diagnostic download for your 6500 from HP.com. It will trace the problem for you. Check you power supply to see if it is operational. Press all connections in tight.
Feb 04, 2018 | HP Officejet 6500 Wireless All-in-One...
Hp officejet 6500 all lights are flashing and mechine says turn off and on
My hp officejet 6500 flashes all its lights and tells me to turn it off and back on again.When I do this it just continues to flash and say the same thing.
Nov 05, 2010 | HP Officejet 6500 Wireless All-in-One...
How to reset the ink level of my hp officejet 6500
Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
  • The exclamation mark (! ) symbol indicates a low ink level.
  • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
Figure 1: Ink levels on the control panel displayc01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
  1. Make sure the product is on and connected to the computer.
  2. Open HP Solution Center .
    • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
    • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
  3. Click Settings .
  4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
  5. Check the ink levels displayed on the Estimated Ink Levels tab.
Figure 2: Estimated ink levelsc00670267.gif
Jun 02, 2010 | HP Officejet 6500 Wireless All-in-One...
Why does my new HP Officejet 6500 power light keep flashing about every 5 seconds ????
I thought I had a problem, but it is not a problem. The machine power light flashes when it has not been used in a while and kinda goes to sleep until you start to use it. That way it saves on power. Thanks any way. But before I would pay for help, I would throw the machine away. !!!
Mar 25, 2010 | HP Officejet 6500 Wireless All-in-One...
Recently bought an HP Officejet 6500. How do I
even though my laptop has been to the hp laserJet 1010 printer, the printer doesn't print !
Oct 31, 2009 | HP Officejet 6500 Wireless All-in-One...
FLASHING EXCLAMATION POINT
Link to the manual: http://h10032.www1.hp.com/ctg/Manual/bpd09762.pdf
Basically it only means that the printer needs attention.
I would check for a paper jam or misfeed, out of paper, low or empty toner.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
307 people viewed this question
k24674
jasbo
jasbo
