Question about Hotpoint Ultima WF860 Front Load Washer
For quite a while now my washing machine has sounded like it has an unbalanced load - although I don't believe it has!! Apart from the 'lop sided' noise when spinning (which has been making it move slightly) the wash appears to have been done OK. However, put it on the other day and it made weird noise and up came fault F05. Took back off, drained water and checked hose and filter for blockages (nothing much there). Tried a spin cycle which drained some of the water off but still left some in bottom of machine - and was VERY 'lumpy' while spinning (rocking etc). At end got an F12 error code. It's a Hotpoint Ultima WF860. Any ideas what we could check please???
  • suet33 Mar 22, 2011
    Thanks for that John ... will try out your suggestions ... fingers crossed!!!
    Brigadier General:
  • 6,277 Answers
2, no 3, things really need checking - balance (rockin' and rollin'), filter (F05) and that F12!
Balance
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then- very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up! If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning).
Filter
Here are my (general purpose) guidance notes for checking both the drain filter and the drain motor. Please try following through to the end ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
F12
'F12' for Hotpoint (and other names made by Indesit!) decodes as 'communications error' which sounds major BUT is not uncommon in these machines and is often caused by poor contact between plugs/ cables and the control PCB, just needing re-seating- by an engineer ;-0(
John C
Posted on Mar 21, 2011
Testimonial: "Thanks very much John ... just off to try out your suggestion!!! Fingers crossed!!"
My Beko washing machine drum wobbles when it is washing & when it does a spine
The washer tube is support by struts, one of them is broken most likely. To check them you must pull the washer cabinet apart.
Nov 15, 2016 | Beko Washing Machines
Whirlpool cabrio W10106480A keeps giving Unbalanced Load message and tub bumps the sides very hard and loudly
follow this step and fix it. God bless you
Washing machines are complex and have many functional components. It's always best to stop an unbalanced load, rearrange it, and re-start the washer.
Oct 01, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool awoe 8761
Is it always loud or just when it is a full load. If the load is unbalanced it will be loud. Most F/L washers today have some kind of unbalanced load detection, but they are not all that great. If it spins quietly when empty it is just an unbalanced load. Don't over load and don't mix rugs with clothes, pillows, etc...
May 19, 2012 | Whirlpool Washing Machines
I have a very old Maytag - Model LA608. It has developed a habit of shaking around very violently. I have balanced out the feet so that it sits stable on the floor. I have also tried to balance out the...
Your drum is going unbalanced with the load.
Either you do have an unbalanced load but more likely is that the dampers on the underside of the drum have failed. (they are like shock absorbers)
There normally are 2 dampers attached to the drum and the frame.
They are accessed by tipping the machine onto its side.
However the machine is heavy and make sure you disconnect power and water if you want to investigate.
Cost of new dampers are around 50 each.
Please dont forget to vote if you liked my answer
thanks
Feb 11, 2011 | Maytag SAV3710AWW Washer
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Unbalanced load, sign UE is on, cannot open the door
UE:
• The load is too small.
• The appliance is tilted.
• Laundry is gathered to one side.
• Non distributable things are put into the drum.
See page 17
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 19, 2010 | LG WM-2277HW Front Load Washer
Washing Machine Shaking
Most common cause for the machine to shake during the spin cycle is due to a unbalanced load. A load of a couple of small bulky items or a small load in general may not be able to distribute the weight properly causing the machine to be unbalanced. It is best to wash full loads whenever possible. We have a brand new front loader as well, our first load about took the walls down...We just tossed a couple things in to see how it worked....thats how I learned to wash full loads. Now with the knowledge of why it shook so bad, we have had no more problems. Hope this helps
Please take the time to give this a fix ya rating
clarkco
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Whirlpool awm5125/4 washing machine
If the washer seems to complete all of its cycles, but it doesn't spin: 1) Be sure the load of clothes is not lop-sided. If the tub becomes unbalanced, it may spin erratically or not at all. Open the lid after 2 minute gap and reposition the clothes. This automatically resets an off-balance shut-off switch. Close the lid and re-try. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn't click when you press and release it, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The belt may be loose, worn, or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. Pl post back results
Apr 17, 2007 | Whirlpool AWM5125/1 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
229 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
