Question about Car Audio & Video
The alarm works and the remote is perfect. but when i arm the alarm on the car it goes off about 2 minutes after the arming, and it goes off all by its self
    Sniper:
  • 50 Answers
Hello... sorry to hear you are having a problem. Is this a system from the factory or an aftermarket alarm? Did you just purchase the car with this problem or did you just install it/have it installed?
20 year car audio/video installer
Bay manager
Posted on Mar 21, 2011
Alarm arming itself and unlock key won't work
See dealer and they can disarm the security system for you.
Aug 21, 2017 | Toyota Cars & Trucks
2005 chrysler 300c-deactivate anti-theft system
Instructions
    • 1 Ensure that the doors, hood, decklid and rear liftgate are properly closed. The alarm cannot properly arm if any of the doors or other openings are not closed.
    • 2 Replace the batteries in the key fob to ensure that the remote is capable of arming the alarm system. If the batteries have been dead for more than a few minutes, the fob will need to be synchronized with the vehicle to function. To synchronize the remote with the car, aim the remote at the vehicle and press the lock or unlock button twice. Next, place the key in the vehicle's ignition and turn the ignition switch to the "On" position. All of the steps must be completed within 30 seconds.
    • 3 Verify that the parking lamps flash three times when the system is armed using the remote. Alternatively, verify that the alarm is armed by looking at the alarm indicator on the dash. If the alarm is properly armed, the alarm indicator light should blink.
Jan 20, 2013 | 2005 Chrysler 300
Car alarm goes off 30 seconds after disarm and open a door
Apparently the alarm is set to passive arming and, once you disarm it, it immediately begins the arming process and it is not registering the door being open. I'm going to go out on a limb and say that the alarm door trigger is wired to the dome light and the dome light is turned off; an issue that occurs with GM vehicles that have a dome light override switch. What's the year, make and model of the vehicle?
Sep 02, 2012 | AviStart 4400 2-Way Security / Remote...
What is the valet button located inside of glove compartment used for
It is used for programing the alarm, it is used to disarm the alarm without the remote, [in case remote is damaged] and it is used to put alarm system into valet mode, [service mode] valet mode is only really needed if the alarm has been programed for passive arming, [alarm arms itself].
Your main use for the valet switch, [if programed for active arming instead of passive arming] is to have a way to disarm the alarm if the remote does not work.
Apr 22, 2012 | 1997 Cadillac DeVille
Hi. I have a Viper 5701 alarm in my car. Arm and disarm goes very well with the control unit. But I cannot programming to pasive arming, always have to use de button in remote control to works. Is ther a...
Open door, turn ignition on then off. Press aand hold programming button until you hear one chirp. After you hear the chirp, release programming button, press and release button one then press and hold. You will hear one chirp. While holding the programming button, press lock button on remote to change option. One chirp is active arming(what you currently have), Two chirps is passive arming without locks, Three chirps is passive arming with locks. Turn ignition on to exit programming. Test system.
Jun 13, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
2002 VW Cabrio alarm problem: alarm will not un-set. Door will not lock using the key OR the remote. Hitting "alarm off" button on remote, it unsets, then arms again immediately. With engine...
i have a 2002 vw cabrio and won't start after i took out the battery everbody is telling me that anti-theft is lock mode how do i rest it so i can start my car
Nov 08, 2010 | 2000 Volkswagen Cabrio
Spy 5000m remote start issues
You need to adjust the tachometer sensing wire, it usually wraps around a spark plug wire so I can sense when the car starts. On my spy alarm, the wire was grey. Hope this helps.
May 05, 2010 | Brand Remote Start/keyless/car Alarm Very...
Installed. Arm the car locked. About 2-3 hours
You must change the doors trigger connection if you have a negative input change it to positive input or vise versa and try. I’m sure that this is going to end your problems or the smart way is, take it back to Best Buy
Jan 08, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
05 Dakota remote wont work
That happened to mine too. Is it a "Karr" remote? If so, it seems as if they use really cheap switches. I ended up de-soldering a working switch from the trunk release circuit and soldering it onto the alarm arm/disarm circuit. Works perfectly now. If you don't own a soldering iron, I recommend getting a new one or getting a better alarm system.
Jun 27, 2009 | 2005 Dodge Dakota
Can not lock car by key remote . toyota rav 4 53 plate
If your car has an alarm with a separate remote, it is a separate system and it is probably self-arming. When you lock the doors with the key central lock, the alarm gets armed by the RAV4 being OFF and the door locking action. When you unlock the doors with the key, the alarm is still armed because the key is not comunicating with the alarm just the cars factory keyless system.
Mar 19, 2009 | 2008 Toyota RAV4
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
