Question about Intel DQ965GF Motherboard
My intel DQ965GF shows a "0" on the righ bottom side of the screen just before boot, the 0 remains there for about 5 seconds and the the system boots, but sometimes the 0 remains there and the system doesn't boot. why it happens and what can I do to solve that? thx and best regards
  • 74 Answers
SOURCE: Won't boot, display stuck at Intel desktop board, can't go to BIOS
well lets see if I can help you...I supouse you try clicking delete during the upload to acc the cmos or try click f8 and f9 alternating clicking during the upload to acc.... in the passt I had a similar trouble and was the termal proteccion of the cpu it could be solve with coolant spray but puting in a plastic bag an leave in the freeser for a couple of minuts can solve the problem..but try with these site they will assist you...good luck
http://support.intel.com/support/motherboards/desktop/d845wn/sb/CS-008926.htm
Posted on Dec 31, 2007
judesoul
  • 127 Answers
SOURCE: Intel D915 GVWB Mother board giving 94 error
If you have an extra HD try putting in.
You can also make a system repair by booting into your OS bootable CD.
please rate.
Posted on Feb 06, 2009
  • 15 Answers
SOURCE: Will not boot past Logo screen with new XFX nvidia Gforce 9500Gt 1gig card
DD SYSTEM SOLUTIONS
(MOTHER BOARD CHIP LEVEL SERVICE CENTRE)
OLD NO.28, NEW NO.67, II FLOOR
SESHA CHALAM STREET, SAIDAPET,
CHENNAI - 600 015.
PHONE NO : 98405-11595
Posted on May 13, 2009
  • 784 Answers
SOURCE: Intel DG965RY CPU Overheating
Check the clamp of the cooling fan. If the clamp is not engaged, heat sink didn't take the heat away from the micro processor causing CPU over heating.
Posted on Jul 03, 2009
SOURCE: I have a Intel D865GLC and it will not
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattch both.
Make sure motherbord is not ground with cabinet.
When you power up the computer press F1 or F2 or "del" key then enter in bios .
Make sure in bios your harddisk is detected.
If not then change SATA or IDE cable of harddisk.
Then check .Go to boot menu nof bios then set first boot device as your harddisk.Then save settings and exit.
Let me know if you need further assistance.Thanks.
Posted on Nov 13, 2009
System hangs / MS Server 2008 R2 SP1 x64
You need to identify what process is causing the high usage, and it has to be done in normal mode. Take your time and sort by usage in Task Manager.
Mar 27, 2013 | Intel Server Board S5520UR (BB5520UR)...
Intel DQ965GF Motherboard won't load WIN OS (WINXPPro volume disk or Win7) tho an old Dell disk did load. Is there a fix? Thz
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+965+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DQ965GF
Windows 7 is not a supported system, but you can use the drivers from the vista system, but only the 32 bit.
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
After the post, BIOS will attempt to boot from the first device listed in the boot order.You need to change that, so the first boot device in the list is the dvd drive. If that device is not bootable, BIOS will attempt to boot from the second device listed, and so on.
Note: The boot order is a BIOS setting so it's OS independent. In other words, it doesn't matter if you have Windows 7, Windows Vista, Windows XP, Linux, or any other PC operating system on your hard drive or other bootable device, these boot sequence change instructions will still apply.
Here is how you do this:
http://www.hiren.info/pages/bios-boot-cdrom
But ofcourse there could be a problem with the dvd drive or harddrive.
To install windows 7, you will need at least 1 gb ram or more, and a dual core cpu.
Best of luck
Feb 12, 2013 | Computers & Internet
INTEL DQ965GF-Motherboard boot up problems
check all leads from motherboard to hard drive including electrical extensions and all of your cd/dvd drives make sure connections are secure dust free and not faulty
computers need all power and data to travel through every working device and to finish its cycle
so any faulty lead will end in computer error or shutdown or fail to boot
make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets
some motherboards cmos batteries are soldered in
might be getting hot check your CPU make sure it has a thermal paste and a dust free and secure seating
hope it helps
Apr 21, 2012 | Intel DQ965GF Motherboard
I own a Asus k501 laptop and every time I turn it on a screen comes up and says, "Check cable connection! PXE-MOF: Exiting Intel PXE ROM." What can I do about this?
You may want to open up the slot that the hard drive resides in and make sure that it is connected into its socket correctly. If you've done this...you should try:
1. Power the notebook on, and immediately begin tapping F2 to get into the notebook BIOS.
2. In the BIOS use the arrow keys to select the Boot Menu.
3. In the Boot Menu will be "Boot Priority Order" and below that will be a list of devices. The first in the list should be "IDE 0".
4. If "IDE 0" is not the first, use the arrow keys to highlight "IDE 0"
5. Use the designated keys to move "IDE 0" to the top.
6. Press the F10 key and press the enter key to save and reboot the computer.
Jul 21, 2011 | ASUS Computers & Internet
Intel core 2 duo d945gcr
Click the below link and download all the drivers for your Board.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+965+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DQ965GF/
Dec 29, 2009 | Intel DQ965GF Motherboard
Just installed the dq965gf motherboard and nothing is happening upon boot. I have everything hooked up. Whats going on?
Double check the power connection to the hard drive. Also, try a different power connector.
Then try just the hard drive without the CD plugged in.
I've seen systems not boot if the CD has a problem.
I don't know if you have an add-on video card, but if you do, be sure it's seated firmly. This, too, will prevent a boot.
Nov 26, 2009 | Intel DQ965GF Motherboard
When i format my lap i miss my sound drivers, i need it immediatly, if anyone have please help me
Do you have the original drivers? do you know what sound hardware you have( check the system in the control panel) Or if you need it immediately, use a generic windows driver( when it asks you what driver you want to update to, choose from the list; it will show some generic driver) question. do you have a PC runnig windows, apple, linux, solaris? is it an internal sound card, or you upgraded it ? if you did upgraded it, you need to get into your bios, and choose the option to disable the internal sound card( usually it tels you when you boot, it say press "xxxxx" for BIOS. be careful what you do in there. hope this works, otherwise, clarify some more.
Jun 15, 2009 | Intel DQ965GF Motherboard
Hard to boot
Dear user,
As per your problem i like problem in your motherboard pl checkout with repairer vendor.
Regards,
Ravindra Shah
May 28, 2009 | Intel DQ965GF Motherboard
Motherboard
Hi T, you know you can not run two different types (Speeds) of memory at the same time? Please re-check page 14 in your manual. Make sure your current memory timing for 667MHz is set to 5-5-5. Lost display, incert your old memory & reset the cmos jumper page 52 in your manual.
Aug 25, 2008 | Intel DQ965GF Motherboard
Intel dq965gf mainboard
read this site
http://www.intel.com/products/motherboard/dq965gf/index.htm
told that the max reccomendend conf is 8 gb of ram.
Sergio
Jun 19, 2008 | Intel Motherboard
Intel DQ965GF Motherboard Logo
44 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
