Question about Toshiba e-STUDIO 352 Black and White Copier
Disposed of used toner? - Toshiba e-STUDIO 352 Black and White Copier
  • 132 Answers
Open the front door you will see a plastic bottle take it out and dispose of the toner in the bottle clean the bottle and wash out with soap and water to get rid of all the waste toner the ideal sinareo is to purchase a new bottle
Posted on Mar 21, 2011
Message the toner bottle is full please call the server machine printing rico 4500
The bottle full message indicates that the waste toner collection bottle is full. The full bottle needs to be removed and the toner disposed of properly. Then a replacement collection bottle needs to be installed and the waste toner counter reset. This site has the toner bottle: http://www.precisionroller.com/waste-toner-containers-for-ricoh-aficio-mp-c4500/details_47769.html . It is possible to reuse the bottles but most people will spill the toner when they try to empty a collection bottle. You do not want loose toner in your environment.
Turn off the printer (at the power switch) and wait for the lights to stop blinking before attempting the replacement. See page 62 of the network guide for the replacement procedure. See https://www.ricoh-usa.com/downloads/downloads.aspx to search for your printer and get the manuals.
I hope this helps
Jul 06, 2015 | Office Equipment & Supplies
What is CF60
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Feb 02, 2014 | Toshiba e-Studio 232 Black and White...
Used toner bottle is full
I'm going to assume you typed the model wrong, and that it is a 1035 like the header states. If this is the case, the used toner on these is inside the transfer belt unit.
Open the duplex unit if equipped, then open up the right-side door. Attached to the door is the transfer belt unit, as see below:
602d8058-7b67-4449-895f-e01b266fd371.jpgLift the lever as shown, then lift unit out of machine. There is a panel with 6 screws near the bottom of the unit, remove all 6 screws and remove the cover. Be very careful, this thing is going to be FULL of used toner, and will make one HUGE mess if not disposed of properly. Once emptied, put cover back on, re-install unit, close doors, and you should be good to go.
Jun 09, 2013 | Ricoh Aficio 1035 Copier
Can i empty the 7120 waste toner bottle?
No you should not empty this bottle. It is designed to keep the excess toner inside itself and should be disposed of properly. NOTE: To return the used Waste Toner Container for recycling, follow the instructions included with the new container. If the instructions or shipping label are not available, click on the [Recycling] link under the Product Resources section of this window for additional information. Follow this link for detailed instructions on how to replace the bottle once you have a new one onsite. http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=161,E=0000000002703235792,K=5302,Sxi=14,Case=obj(1554) Hope it helps!
Feb 10, 2011 | Xerox Office Equipment & Supplies
What to do of waste tonner or can we re use the waste tonner
The waste toner must be properly placed in the safe place.
Try to keep the empty toner and disposed it properly.
Dec 24, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
How does one replace the toner cartridge on the hl 2040 printer
Open the front cover (it tilts down from the top). Pull out the drum and toner cartridge assembly. Place this on newspaper or something that can be disposed of later to contain any spilled toner. Do not touch the electrodes on the unit. Push down on the blue lock lever to release the toner cartridge and slide it out (push slightly down and then lift up) of the drum. Place the old toner in a bag for disposal to contain the remaining toner. Open the package for the new toner cartridge and hold it level. Gently rock the cartridge from side to side to get the toner evenly distributed. Pull off the protective cover and slide it into the drum until it locks into place (the blue lever will return to the original position). Slide the blue tab from left to right and back several times to clean the corona wire then return the tab to the home position (marked by an up arrow).
Slide the drum assembly back into the printer and close the front cover.
I hope this helps.
Aug 11, 2010 | Brother HL-2040 Laser Printer
Copier Studio 55 Copier. Disposed of old toner and replaced with new toner. What a messy job. All done and the message is "join finisher to copier" Do not understand message. Please assist.
Hi how are you this is jack
Dear ,
you copier e-studio 65 showing message dispose of used toner.. ok.. Its donot mean dispose all old toner and install new toner... Its mean dispose used toner box... Dispose toner Box is a seprat box copier all garbage toner droped this box and when this box are full then copier showing message please dispose used toner box... please check it and dispose it.
Thanks
Aug 04, 2010 | Toshiba e-Studio65 Copier
Replace waste toner tank Does it mean that the toner is already used
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Jul 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Toshiba e-STUDIO 352 Black and White Copier Logo
257 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
