ThinkPad G40 Here's a good one for you. A few months back I got a ThinkPad G40 from work. They were going to throw it away because they couldn't get it to power up. I brought it home and messed with it a little. Found I hand power up to the connector for the Keyboard, which also has the power button on it. So I figured it was a bad keyboard. I tore the keyboard apart and was able to jump it across and get the laptop to fire up. Been using it like this for the past couple months now. I just bought a different keyboard thinking like I said that the keyboard was bad and was hoping to fix the problem with a different one. Wrong answer. It's doing the same thing with the new keyboard as it was when I got it. Any suggestions?
  • DerrickB870 Aug 10, 2008
    Thanks Bud. I got to looking at this thing closer and sure enough the connector for the keyboard is broke. Now my next question is where do i find the part number so i can try to track down a new motherboard for this thing?
    Genius:
  • 1,027 Answers
Usually, if the 'bad part' was replaced and it still does not work, mans that that was not the bad part. I would suspect the connector for the keyboard on the motherboard - possibly a cracked connection.
Posted on Aug 03, 2008
Ibm thinkpad audio drives G40 2384
You can get the driver from the computer manufacturer's website. If you want all drivers covered and updated, then you can install an automatic driver updater like RadarSync. You don't have to go to different websites to find the different drivers because the software will do all the work for you.
I hope this helps!
David
Feb 15, 2013 | IBM ThinkPad G40 2384 Notebook
Lenovo G400 cannot power up after few times and now completely dead?
Try a backup power adapter/cable. The Power supply may have died.
Jun 11, 2011 | Lenovo ThinkPad G40 PC Notebook
My ibm thinkpad G40 wont turn on
Check the power source, plug it into the wall don't try to just run off the battery. If it still does not turn on plugged into a working outlet the power supply needs to be replaced.
May 06, 2010 | IBM ThinkPad G40 2388 Notebook
IBM ThinkPad G40 2388 PC Notebook no network controller and video controller
you need to install network drivers neither LAN or Wireless and Display driver. Go to link below to download the drivers:
http://www-307.ibm.com/pc/support/site.wss/MIGR-50513.html
Mar 06, 2010 | IBM ThinkPad G40 2388 Notebook
My thinkpad g40 is not giving sound plz help me to find latest drivers for win 7
go to the website of lenovo or realtek to find the latest realtek HD R229 for win .7
Oct 06, 2009 | Lenovo ThinkPad G40 PC Notebook
IBM G40 won't reboot
Unfortunately only few people know your problems solution but I'm happy that i can help you.
Its simply a problem of setting HDD ( Hard Disk Drive ) type which can be changed using BIOS setup. I hope your laptop must have SATA but if its not working on current settings then please change it to another options available.
Surely, your system will get booted after that and furthermore you can re-install your windows again...
Rate this solution if it was helpful to you.
With Regards,
Shyny
May 29, 2009 | IBM ThinkPad G40 2388 Notebook
IBM ThinkPad G40 2388 No power
Start by checking the power supply with an ohm meter to see if it's working, or has the proper output. If the supply is good, then the problem is most likely going to be with the power management system on the motherboard, and the motherboard will have to be replaced. This could be a serious problem, so If it's not the power supply, I would recommend that you take it to a service shop in your area to have the exact problem area tracked down. A power management system failure is common in these machines, but there are a few other replaceable board components that can cause this as well.
Sep 05, 2008 | IBM ThinkPad G40 2388 Notebook
Bios password ibm thinkpad g40
Sounds like you tried this, but it's worth a shot again. Remove the CMOS battery on the motherboard and let the laptop sit for an hour, then replace the battery with a new one.
If the only real issue is changing the time and date, you can do this in Windows and it will reset the BIOS clock, too, of course.
If the problem is that the time and date keep reseting, you either have a low CMOS battery or a short on the motherboard that is resetting it.
If all else fails, you might need to flash the BIOS from a floppy disk with the latest BIOS version for your machine to reset it and go from there.
PS: BIOS reset problems on laptops are sometimes due to power problems caused by battery packs going bad; check your battery pack, too, and see if it is working okay.
Good luck...
Oct 23, 2007 | IBM ThinkPad G40 Notebook
Computers & Internet Logo
434 people viewed this question
David Payne
David Payne
