Question about LG WM1812C Front Load Washer
Have oe code displayed...i have drained and cleaned out the filter and still get the code.
    Brigadier General:
  • 6,277 Answers
'oe' for LG's normally does refer to drainage problems. Were you able to see if the pump motor was clear and working? If not try these, especially the bit about the motor ;-0)
Here are my (complete, general) guidance notes for checking both the drain filter and the drain motor.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Mar 21, 2011
JOE LLAMA
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
  • 3230 Answers
SOURCE: water wont drain
OE-pump blocked. Disconnect the power before attempting any work. Use of an RCD (plug in power breaker) is recommended.
Disconnect pump from sump hose and check for obstruction in either item. Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace.
Also check the filter - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together, remove the hose, take out filter and clean.
Good Luck!!
Posted on May 06, 2009
SOURCE: For LG WM2233HW, Error Code OE. Already check
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Posted on Jun 24, 2009
jan mczeal
  • 632 Answers
SOURCE: OE Code LG washer - cleaned filter, checked pump
It is a long drain error. The washer is not fully drained after 10 minutes of draining. Remove the cabinet cover and check the following:
  1. Connector The connector may disconnected or disassembled. Reassemble or repair if necessary.
  2. Drain pump coil
    Check pump coil resistance between the terminals using an ohmmeter. Resistance should be between 10-20 ohms. If the resistance is too high or too low, replace the drain pump.
  3. Voltage Check the voltage between the connector in step 1 during spin. The voltage should be 120Vac, else replace the main board assembly
Main board replacement:
  1. Disconnect the power connector and sensor switch assembly.
  2. Remove the main board protective cover.
  3. Disconnect the connectors.
  4. Remove the screw on the back of the main board.
  5. Slide the main board to the right then pull it up.
  6. Replace the main board in reverse order above.
Posted on Nov 10, 2009
TheMobilian
  • 8220 Answers
SOURCE: my lg wm1814cw has a code of OE witch says to
You probably have an object in the pump or a bad pump
See page 27
Posted on Mar 13, 2010
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Oct 29, 2017 | Washing Machines
Lg d/washer about 8yrs old Oe code. Checked grey wire thiery. Cleaned hose filter etc. Was working fine moved house.Whats next.
A drainage problem causes "OE" to be displayed on the digital display panel. The drain hose is likely kinked, clogged or frozen. Inspect the hose and remove kinks. Unclog the hose, if needed. Replace the hose if the problem is not resolved. If the dishwasher still does not drain,
Feb 23, 2015 | LG Washing Machines
WF328 AAG OE error code...how do reset this? or can I reset this?
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code.
  1. Locate your drain pump access door on the front of the machine.
  2. Clean out the filter area.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
Jan 24, 2011 | Samsung WF328AA Front Load Washer
Stopping during rinse cycle . not spinning. OE light
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code. The grinding noise you are describing is most likely a failed drain pump or clogged with foreign debris.
Jan 17, 2011 | LG Washing Machines
IT DON'T GO THROUGH CYCLES COME UP WITH A CODE OE
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Jan 06, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Hello there, what does OE mean in the display?
OE is a water drain error.
Please clean the filter.
front lower left hand corner behind little door.
If after cleaning the filter the washer still will not drain the drain pump may be defective.
Jan 15, 2010 | LG WM-2277HW Front Load Washer
Morning, LG WD1295FB error OE, plese advise
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service. oe_led.jpg oe_lcd.jpg LED display models LCD Display Models Step 1: Check the drain pump filter. Step 3: Confirm that the washer is leveled properly. Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine. An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Oct 26, 2009 | Washing Machines
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG WM1812C Front Load Washer Logo
35 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
