Display say Speakers off. How do I get them back on?
    Sniper:
  • 54 Answers
Find "SPK" button in front panel or remote, press it to switch SPK on or off
Posted on Mar 21, 2011
Ford 2011 Edge speakers don't work following a MS Sync update
You need to take that back to the dealer an not even mess around w/that problem, mam/sir... Good Luck
Jan 21, 2013 | 2011 Ford Edge
The speakers made a repetitive popping and buzzing sound that seemed to strobe as soon as I plugged the entire system in. After awhile the popping stopped and the speakers began to play music, the display...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 14, 2011 | Altec Lansing ADA 890 Computer Speakers
My surround sound speakers don't work. No power
LCD will display which speakers are active. And this depends on 2 things: the source signal and decoder mode.
If source signal is stereo, only front L+R speakers are used. For 5.1 signal (for example DVD over HDMI / optical/coax spdif) all speakers installed (which are not set to None) are used.
To listen to stereo input signal using all speakers, switch decoder to enhancer mode.
Feb 24, 2010 | Yamaha RX-V457 Receiver
Back surround speakers dont work.
If the display reads 2 chan then that means stereo, and the sound mode is not in any type of surround processing. For your surround speakers to operate you must select a surround sound mode.
Dec 06, 2009 | Audio Players & Recorders
'protect' blinked and then no sound or display
Disconnect the outside speakers "at the speakers" then turn back on. If the problem persists, disconnect the speakers at the back of the receiver and try again. If the problem stops "at the receiver" check your terminals and make sure no braids are touching each other. If the problem stops when you disconnect at the speaker, chances are good it's a bad voice coil from moisture. Most "outdoor" speakers with a brand name on them have a pretty good warranty. Good speakers have a 10 year warranty and the manufacturer will replace. If you still have an issue, post a comment and I can help you some more
Jul 26, 2009 | Sony STR-DE925
Have Model S-3F flatscreen monitor w/speakers - Speakers aren't w
I assume it has speakers built in since your post is in the monitor category. You need to connect the speakers in the monitor to your sound card. It should have included the audio cable to do so. The cable should have a green plug and it plugs into the green jack located in the back of the computer.
Feb 14, 2009 | Miro Display Radius S-3F Monitor
Surrond sound not working
it all depends what digital mode you use ,yes in Pro Logic mode on the display it shows only 1 S but if you try the balance for the SL-SR you will hear the difference .
Feb 03, 2009 | Sony STR-DE675 Receiver
No display info on receiver
Try plugging a video monitor AKA your TV into that monitor output connector on the rear of the yamaha.
Select video in on the TV and see if anything shows up from the yamaha
Sounds though like the receiver has serious issues. If you can get your moeny back , do so
Feb 24, 2008 | Yamaha RX-V661 Receiver
Display shows only L and R speakers.
I think you need a digital coaxial wire instead of the composite ones
Nov 19, 2007 | Yamaha HTR-5630 Receiver
Display shows "L" and "R" highlighted in Red
maybe the sound setting is in mono mode versus stereo surround,this only occuring on older model surround systems.   if that doesnt do it , try unhooking  and then hooking the speakers back up  or ; maybe they are even...................switched      hope i could help            i  man   fixxxxxxxxxxx
Aug 27, 2007 | Panasonic SC-HT730 System
227 people viewed this question
 Grubhead
Grubhead
