Question about Health & Beauty
I have a Sharper Image Body Fat Scale and I can only use it about 1 time every 5 or 6 tries. It is frustrating to push all the proper buttons on the remote and have it refuse to work. Absolutely nothing happens. I have programmed it for me on all 4 memories to see if that helped. It doesn't! Routine: Push Clock/BFA button Push Recall Push Enter on whichever memory you want to use Step on scale and wait for it to work I did figure out what I thought was the problem. The remote must be pointed at the scale and be not more than 24 inches above the scale. Now even that won't work. I have replaced all 3 batteries at the same time. Any advice you can enter will be greatly appreciated. I am so frustrated that I am ready to return the scale. Thank you.
  • 2712 Answers
SOURCE: body fat scale Question
Like all body fat tests, body fat scales don't actually measure your body fat percentage. They determine your body density. The examiner (or the scales) then uses a formula to calculate body fat percentage based on body density. These formulas just predict your body fat. Unfortunately there is no one formula that accurately predicts body fat for the whole population. Differences in age, gender, ethnicity, body size, and fitness level all have a significant affect on the results. Well, whether body fat scales measure your "true" body fat percentage or not doesn't matter! As long as they can accurately monitor changes in your body composition over time, that's all you need.
Posted on Aug 27, 2008
  • 2712 Answers
SOURCE: digital scale question
Digital scales purport to measure your body fat through a process called BIA, or bioelectrical impedance analysis. Essentially, it clocks the speed that electricity travels through you. The scale runs a low-level electric current through your body, using your feet as positive and negative electrodes. The current encounters different levels of impedance, or resistance, from fat versus muscle. The scale measures this impedance, and throws it together with other factors (age, sex, height) to come up with your BMI, or body mass index.
SOURCE: I can not change measuring The omron scale model HBF-400
how can change lb to kg
Posted on Dec 07, 2008
SOURCE: Midland alan 48 plus transmit scale not moving
Sorted now, soldered a new output transistor into the board and all working.
Posted on Dec 12, 2008
SOURCE: Watchers WW-87 Body Fat Glass Scale
Hi
At this web site bottom left hand corner there is an instruction manual
http://www.conair.com/weight-watchers-glass-digital-scale-p-667-2_60_38.html
Posted on Dec 16, 2008
I changed the battery and now when turned on all icons on screen flashing non stop
try repeated pressure to reset (5-6 times in 10 sec) or could see if there is a small hole near battery compartment, push with paperclip (button reset)
Jun 06, 2014 | Soehnle Exacta 63694 Body Fat and Water...
Tn425 sharper image bathroom scale how to change from kg to pounds?
There is a small finger slider switch underneath the scale, setting the scale to either pounds or kilograms.
May 07, 2014 | Terraillon TFX70 Sharper Image Body...
Abdorer twister - body analyzing scale
I updated this review 3 weeks after getting the original one -- I contacted the company to see if I was doing anything wrong to get the body measurements. After telling them what I had done -- they determined that perhaps the scale was defective. They sent me a brand new scale and I did not have to send back the original defective one. The weight is consistent and doesn't vary when you move it to different spots. I love this scale and it looks very sleek too. After I figured it out, set up was simple and it literally took me 5 minutes to set it up
INTEY Body Fat Scale Body Composition Monitor Measure Body Weight Fat BMI...
Feb 15, 2018 | Health & Beauty
I have a healthometer BFM920KD-01 scale and
Just push either the #"1" or "2" user button and hold it down. The display will flash the height numbers. Hit the Up or Down arrow to change the flashing "5" to a six, etc. Then hit the "set" button to "enter" your choice. This advances the display so that you can now change the inches, gender and age. You're good to go!
Apr 14, 2012 | Health-O-Meter Health o Meter BFM588DQ-81...
I keep getting e on scale dont know what i did wrong setting it up Model bfm884dqn-60 it is for 4 users height of 5 3 1/2 is displayed pls HELP Thanks
I think that those numbers are for the spacing of the feet? I'm not sure what that number is, but anyway you have to push select 3 times and it will save and then the scale will zero out. After that you can push one of the four buttons and program you height/age/gender. I think they really made this scale kind of user difficult.
Sep 03, 2010 | Sunbeam Healthometer Body Fat and Weight...
I need a users manual for my Um-016
Tanita UM Series Body Fat / Hydration Monitor InstructionsTanita UM Series Body Fat Monitor/Scale Instruction Manual
How to Determine Body Fat Percentage
Setting & Storing Data in the Memory
1. Turn the power on using the set button.
2. Select a Personal data number using the Up/Down arrow buttons, then press set.
3. Select your Age using the Up/Down arrow buttons to scroll through numbers, then press set.
4. Select Male or Female using the Up/Down arrow buttons, then press set.
5. Specify the Height using the Up/Down arrow buttons, then press set.
The unit will beep twice and the display will flash all data (Male/Female, Age, Height) to confirm the programming. The power will shut automatically, or you can tap the weight only button (in front of monitor) for quick shut off.
How to select Personal Data Number
1. Press the Up memory button to turn on.
2. Use the Up/Down arrow buttons to select your personal data number, then press set.
3. The unit will beep and the display will show the programmed data.
4. The unit will beep again and the display will show '0.0' and then step on the platform.
5. Your weight will show first, then "00000" will appear and then your Body Fat Percentage will appear on the display.
Programming the Guest Mode
1. Press the Down Guest button to turn on
2. Follow the same steps for programming as outlined above.
3. The unit will beep twice and show '0.0', then Step onto the platform.
Taking Weight Measurement only
1. Select weight only mode, by toe-tapping the weight only button located at the base of the scale.
2. Wait for the scale to display ‘0.0', then step on.
Replacing the batteries
1. When the "Lo" error message appears on the screen, the batteries need to be replaced.
Understanding Your Readings
Healthy Range Indicator
(Please note this function is only applicable on adult mode, as no standard healthy ranges have been established for children and athletes.)
Your body fat monitor/scale instantly compares your body fat reading to the healthy range chart. Following your body fat reading, a black bar will flash across the bottom of the display, identifying where you fall within the body fat ranges for your age and gender.
(-): Underfat; below the healthy range. Increased risk for health problems
(O): Healthy; within the healthy body fat percentage range for your age/gender
(+): Overfat; above the healthy range. Increased risk for health problems
(++): Obese; high above the healthy body fat range. Greatly increased risk of obesity related problems.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
Say it in English,not British
1. Turn the unit on.
2. At the same time, press and hold the "G" button and the power button.
3. While continuing to hold down the "G" button, release the power button.
4. Release the "G" button.
5. If you have done this correctly, the unit will power on. This procedure will switch back and forth between lbs. and kg.
Sep 04, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Manual and User guide for Tanita 2204 Body Fat Scale
Do not watch body fat scale, watch your mirror. The progress is visible there. Use proper food, exercise a lot and don't worry about body fat scale. This tips helped me: fatlossguide us so if you have 2 min extra time, take a look. best of luck
Apr 03, 2009 | Tanita 2204 Body Fat Scale
How do you program users?
Storing and Recalling Weights
1. Your scale can store and recall up to 5 weights. If your scale has one button,
weights can be stored for one user. If your scale has two buttons (User and
Save/Recall buttons), weights can be stored for multiple users.
2. Tap center of scale platform with foot and wait until "00.0" appears.
3. Stand on the platform without shifting or moving until weight is displayed.
4. For single user scale: When weight reading appears on screen, step off the
scale, press Save/Recall button and hold for about 2 seconds to save the
reading.
For multiple user scale: When weight reading appears on screen, step off the
scale, and press User button to select a user number. Then press Save/Recall
button for 2 seconds to save the reading.
5. Weight reading blinks twice, then becomes stable. A small number (1-5)
appears in the upper right hand corner of your display, indicating which of the
5 weights is displayed. (Once you have 5 weights in memory the current weight
always saves as "1" and the oldest reading is eliminated.)
6. Weight reading is saved. Press Save/Recall button to review the last 5 weights or
let the scale shut down automatically. (Note: until you have 5 weights stored in
memory, the display will show the number and "–" for each weight for which
no data point has been stored yet; i.e. "3 –", "4 –", "5 –" if only 2 weights
have been saved.)
Hope this helps!!
Feb 09, 2009 | Precision Camera Weightwatchers WW70 Body...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
