Question about Garden
Huskee LT 4200 My son purchased this for me last July... the belt will not stay on ... I never got my whole yard mowed last year.. always waiting for someone to come put belt on... the warrenty people came out and, they said belt was wore out and I had to get a new one...(NEW MOWER< NEVER MOWED WHOLE YARD YET!!) so they installed a new one, and said that was all that was wrong with it... i did one mowing after that, the only full mowing of the year... Its spring and i am trying to mow again ... belt fell off twice... then broke ... only have my front yard mowed ...There has to be something wrong with this mower, what could it be? Also I need a picture and instructions on how to install the belt Thanks
SOURCE: Mower will not start
First of all have someone check the battery voltage with a meter. If it is up good do this. The + or red wire from the bat.goed to the starter. From there a smaller wire goes to the ign. switch. From there wires go to a solenoid etc. Check all the wire for cleanliness and breaks and also clean all grounds.Don't forget to have the solenoid and starter checked if all the wiring is alright. Good luck.donnyb60
Posted on Mar 24, 2009
  • 2841 Answers
SOURCE: Husqvarna YTH2348 drive belt slipping
Is there the proper amount of tension on the belt?Look in your owner's manual to find out how to adjust the tension.
Posted on Aug 05, 2009
  • 4088 Answers
SOURCE: loss of power uphill
Check the valve clearances--if they are tight, the added heat of climbing will close the clearance to the point that the valve(s) quit sealing causing loss of power. Check the spark plug(s)--should show a medium brown on the interior insulator(s). Make sure the muffler is not plugged. Check the engine ventilation--grass clippings and dirt can choke the air flow. Make sure the wheels turn freely.
Posted on Sep 12, 2009
rtpflh
  • 546 Answers
SOURCE: I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Posted on Sep 28, 2009
jdlipscomb41
  • 157 Answers
SOURCE: New Poulan gas mower blowing white smoke
if its new carry itback theres a number of things it could be but it sounds like the crankcase is full of gas check the oil and see if theres gas in it.
Posted on Oct 26, 2009
I have a huskee lt 4200. I keep buying deck belts for it but it keeps eating them up. The tensioner pulley is engaging but the belt flaps around real bad. Ive replaced cable. Caint figure it out.
Clay it may be time to replace the pulleys,including the engine pulley, check all bearings and blade spindles for wear and free movement and if the tensioner is on an arm lube the arm so it move freely.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Why am Breaking So Many Belts on My Mower
http://www.tractorforum.com/f166/burning-up-deck-belts-21199
Craftsman lawn tractor breaking belt after each use
Why Does My Yard Man Mower Keep Destroying the Belt That Is on the Deck to...
Jun 05, 2016 | Garden
Need instructions how to put on and route a mower 42 deck huskee lt 4200
here is a diagram from the internet, hope it helps.
May 15, 2016 | Garden
Huskee LT 4200 Lawn Tractor I had to jump my mower today and mowed for 45 minutes, turned it off, added gas, started mowing again for 30 minutes, turned it off and now it won't start, turn over or...
A couple of possibilities, either the main fuse has blown, they are normally an auto motive design and located undrt the the hood of the machine, or the start solinoid has burnt out.
Jun 18, 2013 | Garden
Huskee LT 4200. I jumped the battery to get it to start. I mowed for 45 min, turned it off, added gas, starting mowing again for 30 min. Turned it off & now it won't start, turn over or crank. I...
try tapping the starter lightly with a small hammer to rule out a stuck armature. Also make sure all of your connections are tight.
Please explain how you "jumped" it. was it with another battery?
Jun 18, 2013 | Cars & Trucks
Huskee LT 4200 Won't Turn Over
Remove spark plug. Then try it. Sometimes filled with gas.
May 28, 2013 | Garden
Huskee LT 4200 modle 13aj771g031 how do I get the small rear drive belt to go on the pully
Set the brake/clutch. This will disengage the linkage that tensions the main drive belt, allowing you to put it on the pulley.
I hope this is helpful.
Aug 16, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Husqvarna yth20k46 - When turning transmission does not work
I only had my mower 3 months and that problem started. I was told to change the drive belt, It got worse. Now the transmission will only drive the mower for about 15 min and will come to a complete stop. I have to let it sit about 30 min before the drive will work again. No solution yet but I'm looking at replacing the "sealed" drive assy. I do have a very healthy yard of St Augustine which is tough. I can mow a thinner yard a little longer.n
Apr 06, 2010 | Husqvarna Garden
Huskee LT 4200 won't move forward or back(no noise) .
try checking the engangeing pulley to see if it move,if it does then check the belt hope this help you
Aug 28, 2009 | Garden
Garden Logo
191 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
