Question about O2 XDA Mini S Smartphone
Won't see my mini sd card
How do I install a mini sd card. I thought I would just insert it and the slot and windows mobile would find it.. but not. Is my xda broken?
    Problem Solver:
  • 11 Answers
Format and insert
Posted on Aug 26, 2008
What u mean format what the phone or the mini sd because i cant format it
Posted on Aug 27, 2010
My TransFlash 2.0 memory card doesn't show on my lap top
First, the basics...
There are three kinds of SD cards (SD, SDHC and SDXC). Not all computers are designed to accept all three types. SD cards can store up to 2GB of data, SDHC can store up to 64GB of data, and SDXC cards can store up to 2TB (terabytes) of data. If you are unsure which types of cards your laptop or computer will accept, visit the manufacturer's web site and look for the specifications for your particular model to be sure. It's tempting to want to buy an SD card with a large data capacity, but it's wasted money if your computer will not work with the high capacity card.
Make sure you have inserted the card correctly (and fully). The card is 'keyed' (with a notch in one corner) so it should only fit into the SD card slot one way *easily*. Obviously you can try to force the SD card into the slot the wrong way, but the position which goes in the easiest is probably the right way. Some devices have a symbol beside the slot indicating which way the card should be inserted. Be careful, though. It is natural to think the the card should be inserted with the manufacturer's label facing up, but I've seen devices where the card should be inserted 'upside-down', contrary to what I thought.
If you are using a Windows computer with a 'recent' version of the operating system (Windows Vista or later), the computer should recognize the card (as a newly attached piece of hardware) and show the card as a new drive letter when you open the Windows Explorer program to view your files and folders.
If the card is new, it should be formatted already and can be used immediately, BUT...your computer may need to have a driver program (software that enables the use of specific hardware items). My laptop, for example, uses a driver from Ricoh to enable the SD card slots, and that driver had to be downloaded from the HP support site and installed before my SD card slots would recognize SD cards.
If you know you have the correct SD card device driver installed, have an SD card that will work with your computer but still do not see the card in Windows Explorer, you can check in the Windows Device Manager to check its status. You can also use the Disk Management features of Windows to check what drive letter has been assigned to the drive. If the SD card has been assigned a drive letter already used by another drive, then it will not be available in Windows Explorer.
If you think any of these last problems I mentioned are part of your issue, reply here and I can see if I can help you further.
Apr 18, 2016 | Kingston Electronics - Others
I have a samsung diva mobile, for some reason it won't let me format my sd card via my mobile and the phone doesn't seem too recognise the sd card
Welcome to Fixya
Try to insert the card first to your computer that has a memory card slot reader. If the computer did not recognize the card then the problem is the card already.
Thank you for using Fixya!
Oct 01, 2011 | Samsung S7070 Diva Cell Phone
What do i buy so i can attach my digi power dp-fcr20/ mini sd/ms duo card reader/writter so i can attach my mini sd to it and sorry if hard to understand
If the card-reader states it's for a mini-sd card, then you should just be able to insert the mini-sd card into one of the slots. However, some card readers double-up on slots by making it so more than one card-type can be inserted into the same slot. See if the mini-sd card can be put into one of the slots successfully. Tip: Read your manual before doing so, so you don't get card stuck in wrong slot.
Mar 31, 2011 | Computers & Internet
Not knowing how to insert into hard drive.
You need a USB to Flash card adapter, you push the little card into the slot, and if it is a mini card, it has to go into another card "Carrier" that plugs into another adapter, that then plugs into the PC, either through the USB adapter or a slot in PC, anyway, when you insert it, automatically, a driver will be installed, it is "Built into" Windows, now after it has done so. you can simply use it as a "Drive", meaning you can Copy, Cut, Paste.
Mar 01, 2010 | SanDisk 2GB microSD Memory Card
SD card does not seem to fit in the SD card slot
Is the SD card a mini type or a standard SD card?
The standard SD card is 24mm wide X 32mm long.
If it is a mini SD card you need to purchase a mini SD to standard SD adapter, then you will be able to insert it in your Compaq.
Aug 13, 2009 | HP Compaq nc6230 Notebook
I hav htc t-mobile wing i have inserted micro sd card in the sd card slot of it but in the storage card memory it says "total storage card memory : not installed" i have also tried other cards (witch...
Take out the SD card.Turn off the phone and take out the battery. Now insert the new SD card and then insert the battery. Turn it on and then new card should get detected.
Aug 08, 2009 | T-Mobile Wing™ Smartphone
3gp Movie video not able to play from MINI SD Card
there is some error while converting ur video fomat...u have to use proper format or convert them to .wmv format..it will work fine
Mar 05, 2009 | Computers & Internet
Sandisk Adapter Problem in a HP Laptop
If you install SP3 it may work as SP3 updates the index parameters for file size limitations within such an old OS.
Oct 11, 2017 | Electronics - Others
Software Installation
Pentax camera creates an own folder at each inserted SD card. So, try to find your image and video files in the folder named 100PENTX. For example, my camera saves the shot images into folder: SD card:\DCIM\100PENTX.
Sep 08, 2005 | Pentax Optio SV Digital Camera
O2 XDA Mini S Smartphone Logo
110 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
