Question about Ikan Corporation Ikan PT1000W 8 Widescreen Portable Teleprompter PT1000W
I am having issues connecting my powermac g4 to the IKAN 1000W. I am able to connect the IKAN monitor to a DVD player and get a picture. I am also able to get my mac to mirror with an LCD monitor. For some reason, when the MAC and teleprompter are connected, there is no signal. Please help!
Need component identification for G4 powermac
Which component? There are a lot of them. Memory type is printed on each stick. Hard drive and DVD burner are IDE and are interchangeable. Anything connected by USB is plug and play. For Mac ID go to About This Mac menu bar, upper left shown as an Apple logo. First screen will tell you OS, RAM and processor. Click on More info to see a detailed profile.
Apr 09, 2013 | Computers & Internet
Powermac screen developed fine black grid and won't operate properly
Isolate the problem to see if it's the screen or video card by connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without a problem then your original screen is bad and your video card is good. If the Borrowed monitor displays the same problems as your original then your video card inside the computer is bad.
May 29, 2012 | Apple Powermac G4 Quicksilver Logic System...
I would like to connect an Apple Studio Display 17" to my Macintosh Server G4. Can it be done? What adaptor is needed if any?
Apple Studio Displays connect via DVI cables. The PowerMac G4 (all versions) support both VGA & DVI. You shouldn't need any adaptors. It should just plug into the back.
Dec 22, 2010 | Apple Macintosh Server G4
Transferring software and files from PowerPC G3 to PowerMac G4
to mount somthing in a mac is basicly cutting it on for use.
For example if you instal a flash drive or an hard drive via an out side connection, The mac will mount it so you can use it.
Aug 09, 2009 | Computers & Internet
Monitor does not come on
The video card you used may work for the 2nd computer but not for the 1st because of the system requirements. They might be different simply because they are different models. check which video card is RECOMMENDED, NOT MINIMUM, and get the recommended video card.
However, if it is the right video card, then get it checked at a pc shop, like pcworld or somewhere like that and see what they think of it.
Sep 14, 2008 | Apple 64MB NVidia NV-11 Video Card for...
DVI connection to DVI port on PowerMac G4
DVI offers better picture quality since no DAC occurs.
But to most of us Analog VGA will do
Rifaa
Aug 02, 2008 | Acer X193W LCD Monitor
Ikan Corporation Ikan PT1000W 8 Widescreen Portable Teleprompter PT1000W Logo
24 people viewed this question
Top Ikan Corporation Computers & Internet Experts
David Payne
David Payne
Are you an Ikan Corporation Computer and Internet Expert? Answer questions, earn points and help others
