How to reload and format which keys do I need to press and when ?
  • 33 Answers
I do not understand what you need help with can you be a little clearer as to what you are wanting to do?
Posted on Mar 21, 2011
Sir laptop formate kar diya hu uska webcame and function key is not working
Hmmmm, interesting problem, you really need to learn to articulate what the issue is "in common english"
Remove the Webcam drivers and Reload the Webcam drivers. then test, if okay good, other wise reload the Webcam software as well
Oct 12, 2013 | Sony VAIO Computers & Internet
My ti nspire cx cas is totally stuck at the loading screen , it keeps reloading and reloading with a sign at the left corner at the bottom that say's that my battery is empty ? what should i do ?
I have a doubt, when I choose to completely format the calculator it will clear your operating system, files saved on it, but the product key (ID protuto) will be deleted too?32d3cd84-9b87-4f5d-abfe-aa04ca86df4c.jpg
Dec 18, 2012 | Texas Instruments TI-Nspire CX CAS...
My samsung SGH-i617 will not load windows moble when it is turned on. What is my problem?
The problem could be the Operating System (Windows Mobile) itself. Try to remove the battery while the phone is turned ON so that it will be soft reset.
If same problem occur, you need to contact the manufacturer to reload the Operating System (OS).
This will be the best solution. Good luck!
Jan 03, 2010 | Samsung BlackJack II Smartphone
How do i free 8mb in Sandisk Sansa M250 i formated but the same result happens plz help me!!!!
SanDisk tech support recommends formatting the m200 series in both MSC and MTP modes to completely clear out all work areas,"fragments" and residual data. The m200 has a very basic Operating System that doesn't have a defrag option. According to tech support, the m200 needs formmating occasionally to keep it working smoothly. I learned that formatting will also clear up intermittent hang-ups. I format mine each time I reload it.
Format in MSC Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then MSC.
Connect the m200 to the PC via the USB cable
Right click on the "Start" button.
Left click on "Explore"
Find the m200. It will show as a hard drive, for example: "SANSA M250"
Right click on the m200 device and select "Format"
After formatting is complete, click on the "Safely Remove Hardware" icon on the System Tray and stop the device
Disconnect the m200 from the PC.
Format in MTP Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then Auto Detect.
Connect the m200 to the PC via the USB cable.
Find the m200. This time it will not show as a hard drive but as a music device, for example: "SanDisk Sansa m250"Note there is no drive letter in MTP mode.
After formatting is complete, disconnect the m200 from the PC. There is no icon to stop the device.
Your m200 device is now formatted and ready to reload.
By the way, MSC mode is mostly for use with other than Windows XP computers. If you are using WinXP and Windows Media Player 10, you might consider using MTP mode and WMP to manage the m200's.
Source: http://forums.sandisk.com
If i was helpful, kindly do Rate!
Regards.
Jul 28, 2009 | SanDisk Sansa m240 MP3 Player
To clear phone memory
In order to format your Nokia 6630, please follow the following steps.
Note: Make sure that you format the memory card first so that there is no trace of virus in the phone and remove any password from the memory card.
1. First of all make sure that your phone's battery is full and then switch off you mobile phone.
2. You'll need to hold three buttons together which are: The green button, left selection key and the no. 3 key
3. Keep on holding these three buttons and then press the power button to switch it on.
4. After this you'll get a screen which will say FORMATTING.... after that you can leave the keys.
Caution: This will completely format your phone memory and will reload the whole phone due to which you'll lose all your contacts or in fact anything stored in the phone memory.
I hope this helps you....this step can be taken for any Nokia phone which has Symbian OS Series 60 Version 7 and above...
Mar 19, 2009 | Nokia 6630 Cellular Phone
Reloading firmware in a hanged nokia n73
Try Software format by *#7370# and re install.
If not working try Hard reset. Press and hold Call key, * key and 3key simultaneously all three and switch on the phone. Hold it till u see formatting.... in the screen. It worked for my 3230. I dont know if it will work for N73.. Try it anyways. Hope u have backed up ur phone before..
Mar 08, 2009 | Nokia N73 Music Edition Smartphone
My pendrive can detect but it appear please insert dsk into drive
i) this is trick i followed with my pen drive, if you an windows xp cd, insert it in ur computer and restart ur computer(follow the procedure of formating ur system or reloading OS, where u will get message "press any key to boot from cd....), make sure that ur pen drive is inserted when u are restarting ur system,
ii) i'm not going to format ur system, when u get message(to fromat in C press Enter or ESC), at this point of time u press ESC and will see all ur partition(harddisk, like C, D, E.....)and u will even ur pendrive partition separtely a
iii) and now highlight or select ur pen drive partition and press key D to delete partition and follow instruction ....after completing this deletion process, again press C to create partition........
and ultimately come out  them by pressing ESC and this will prompt "whether u want to  abort formating ur system, say yes..........Enter and normally continue ur operations in ur system...
iv) if u are familiar formating ur system u can do this very easily(note: i'm not formating ur system)
Thanking you
M. Sridhar
Feb 04, 2009 | Transcend (589307) Media
Transcend pen drive
Thanking you
M. Sridhar
Cannot read my flash drive!!!
Thanking you
M. Sridhar
What is this?
Feb 03, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Load Error! Press a key to reboot
If the computer after power on is checking the drives ie the CD and/or floppy to boot from then it is a software problem. You need to put in your recovery CD/disk and hope fully it will allow you to just fix the errors within the boot up files and not have to install os.
Your norton could help - try booting from that or the ones you produced by using Norton.
If you have to reload then do not format just save old - it should give you that option.
Jan 30, 2008 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
