Whirlpool duet front-loading washer--drum quit spinning--took off back of washer and there is fine black dust (from the belt?) all over and the belt is off the pully wheel--the pully wheel has LOTS of play in it--took off the nut holding the pully wheel on the drum spindle and there is no sign of wear and no play in the actual spindle or drum mechanism--is the wheel pully supposed to flop around like that?--also, when i put the belt back on, it won't stay centered; it works its way off as the pully goes around--are there supposed to be bearings somewhere that keep the pully wheel from wobbling?--the metal pully wheel has also rubbed against the plastic drum cover and cut into it
  • chiefssalina May 05, 2009
    Belt off how do I put back on with out any big issues
  • 261 Answers
SOURCE: new belt install
OK your a pro if you attached a pulley correct, now for the belt. The belt is elastic in nature and can take some abuse, so first loop it on the motor and loop it on the top of the pulley, holding the belt with one hand that follows the other hand turning at the same easy speed. it will get real easy a third of the way around and your done!
Posted on Sep 10, 2008
  • 1304 Answers
if you have gotten that far your good
now try to look at the motor it sounds like your belt might be a lil off track on the mortor shaft
there is a adjustment srew on the top left of the motro its hidden under things but its there
you can looses this and swing the motor
make sure you have it lined up on the motor shaft and it should stay aligned on the pully
Posted on Oct 08, 2009
  • 1474 Answers
SOURCE: The drum seems to run crooked and rubs...
You can buy new drum Spider which has bearing fitted check cost 1st...
Posted on Nov 17, 2009
  • 93 Answers
SOURCE: whirlpool duet washer, inner stainless drum rubs
This sounds like a worn bearing housing or the bearing itself has packed up,either way you would have to strip and check these and replace what is broken
Posted on Dec 28, 2009
  • 670 Answers
SOURCE: My plastic drum seal on
You have more serious problem than just your drum seal. The support arms in the wash tub are broken. The wash tub should always spin true. When it wobbles it is a sure sign that the suport arms or spider arms are broken. It is an expensive repair since the wash drum, the outer plastic tub and the door seal need to be replaced. Check your warranty, to see if some of these repairs can be covered. Get a few estimates before deciding whether to repair or replace it. Sorry.
Posted on Feb 22, 2011
Duet washer making a loud noise on spin cycle, it squeaks on low spin and then when it gets up to high speed, it is really loud. What could this be?
In most cases it is something that is sticking between the drum and the housing. Check inside the boot by the door. If that is not helpful move the drum by hand and listen to see if you can locate the area of the noise.
Dec 30, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Tighten belt on duet whirlpool front loading washer
There is no adjustment for the belt of WP front load. If you hear loud noise when the drum is spinning because the drum bearing was loosen. If you have insurance cover tell them to replace. Else, a cost of repair is expensive.
Oct 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool dryer front loading wont turn the drum i change the control board but still wont work .
did you check the belt to see if it's broke,the belt raps around the drum and the motor,when the motor turns on and spins the belt spins the drum.
Mar 28, 2011 | Whirlpool Duet Front Loading Dryer Rack...
Very loud roar when spinning 2 years old
Could well be drum bearings quite an expensive repair, if you remove the belt and turn the drum by hand it should be quiet if not then drum bearings worn....
May 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer...after problem with it getting out of balance due to not draining and trying to spin with a heavy load, I have since noticed if I place my hand inside the will spin freely...
Your original problem is likely to have damaged the bearings and the spin tub shaft... the shocks can fail, but that would not affect the fitment of the shaft and bearings.
Apr 21, 2017 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the belt on a whirlpool duet washer
To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and remove the rear panel.
2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, please let me know. I hope this helps you.
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Squeaking noise on the Duet GHQ91
Yea i would change the belt, it really is not a hard or expensive repair.
Jun 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
