Question about Philips AJ100 Clock Radio
My Philps AJ100 is blocked on AM radio. I want FM radio. I don't find AM/FM button.
How do I fix the factory radio-antenna situation where I have no AM radio, when FM works fine?
If you pick up FM. It isn't the antenna. It's an internal radio problem.
Aug 11, 2015 | Cars & Trucks
Wont pick up fm
Deploy the antenna, and orient it. Keep the radio away from electric appliances such fridges, and electric machines. Put the radio on a window sill or close to a window. If a building blocks the line of sight between radio and transmitter reception may be affected.
Dec 10, 2013 | Dewalt DC011 AM/FM Radio
Don't know how to save and assign radio channels
ok change the channel to what u want to listen to then hold the number 1 button for like 3 sec or 5 secs then that channel is programed to channel 1 repeat steps for button 2 3 4 5 ect... with ur other fav stations u like to listen to.. then u can press the fm button to go to fm 2 which again u can program 1 through how ever many channel numbers ur radio shows now program different stations other then the ones u just programed on fm 1 choose 5 or 6 other station the fm2 just offers u more stations to program other wise just program the normal 5 or 6 stations to ur radio
May 16, 2011 | Car Audio & Video
I can't change the radio from am to fm. when i push the source button I get only am and aux in> i can't figure out how to get fm radio
not knowing what make and model your radio is i can't say 100% sure, but there should be a band button that should go from am to fm. some radios also have more than one fm selection. (fm1, fm2).
Jan 19, 2011 | Car Audio & Video
Radio phillips aj100 stuck on am band cant get it to switch over to fm frequency.
Press RESET under the radio a few seconds. Adjust clock, alarm and radio again. AM gone, FM back on the air...
Jul 26, 2010 | Philips AJ100 Clock Radio
Phillips SAA7130HL TV Tuner VISTA 64 BIT DRIVERS
well i had the same prob, so i downloaded drivermax, which I think is free.
drivermax scanned my computer and found all the drivers I needed including the vista philps tv tuner driver.
another way is to download iobit advanced system care which is an excellent free program and click the utilities button and then click drivers update. This should give you the philips driver as well.
hope this helps
it certainly worked for me
anyway you should be able to use the 32bit xp driver.
regards peter
Jan 23, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Programing the radio stations
You just press the program button on the front of it. It's next to the Stereo/Mono button!
Jul 04, 2008 | Sony MHC-RX66 Shelf System
Philips AJ100 Clock Radio Logo
126 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
