Question about LG Washing Machines
I am trying to level the washer with the stand but nothing seems to work. On the spin, the whole washer shakes around, as they are new.
    Brigadier General:
  • 6,277 Answers
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
John C
Posted on Mar 21, 2011
Shakes like crazy spin
Your maytag washer tub and basket assembly sits on a base counter balanced by 6 springs. Is is possible to move the tub around by hand. The best test is to start a spin with the unit empty of cloths, allow the tub to reach speed for a few seconds, lift the lid and check the tub position after it stops, if the tub is off center with the lid opening, re center the tub and run spin again. If your tub returns to an off center stopped position you most likely will need the base kit replaced. The base kit replaces the entire bottom of the unit along with new springs, and snubber, if so packaged per your application. Maytag experienced a defective stamping dye when these bases were stamped, thus they were stamped crooked. This test is performed with the machine it's self relatively level on the floor. If the tub assy leans and favors any one direction while you are trying to center it with the lid open, you may have a rusted or broken counter spring in side the unit. Pleazer Appliance...
Apr 11, 2014 | Maytag Washing Machines
Whirlpool duet mod#ghw9160pwo washer shakes the whole house during spin cycle. shocks look good, springs look good and adjustable feet are tight and on floor. the washer is level and i get no alarm...
Unit probably has bad main shaft and bearings. Worn bearings will cause excessive shaking on spin cycle. The shaft, bearings and seal will have to be replaced. Also if you grab the tub by the top and shake it up and down, it will have a little play in it. That will confirm bad tub shaft bearings. It's a pretty big job for a DIY.
Dec 10, 2017 | Whirlpool Washing Machines
The washer gets unbalanced on small loads that never happaned before a couple of weeks ago. The machine has a unbalance spin load compensator but makes ungodly banging now, that's never happen until...
the problem with small loads is that the tub gets unbalanced very easy,if it spins correctly with a larger load there's nothing wrong with the washer,it's just unbalanced,you can open the lid and move the clothes around by hand to try to balance out the load,very common,also has the washer been moved?check for level,if it was moved one of the legs could have moved to put the washer unlevel,
Mar 08, 2011 | Maytag MAV5920E Top Load Washer
Have a Roper (Whirlpool) top load washer Model RAL 5144BWO, that vibrates excessively. I ran it without any clothes, and still vibrated excessively. I watched it go through the spin cycle with the lid...
Hi, Well it sounds like either one of the tension springs that hold the outer clear tub to the frame down below came off or broke, or that the basket or gearbox shaft is warped. One other thing to try is the back feet on those washers are spring loaded to take out some of the vibration, if those feet arent level it will make the washer shake. it is easy to reset those so they are level. Stand infront of the washer and grab the back of the unit and pull it towards you so that you raise the rear legs, then simply set it back down. To check the spring you will have to take the outer shell off and look at the springs that are at the bottom of the tub assembly holding the tub down on the frame. Good luck and I hope I was some help.
Dec 09, 2010 | Washing Machines
Front loader washer shakes house
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 06, 2010 | Washing Machines
Spin cycle shakes whole washing machine
have you tightened the jamb nuts on the legs after leveling the machine so they can't move from where you set them initially when you leveled the unit?
Mar 21, 2010 | Kenmore HE2 Plus Front Load Washer
Matag washer Performa shakes badly on spin cycle
Ensure the washer is level by rocking it. If its level should'nt be able to move. You may have a weak floor. to checks this look to see if anything is vibrating around the washer.
Feb 10, 2009 | Maytag PAV2300 Top Load Washer
Washing machine shaking on spin cycle
what is the brand of the washer along with the model nunber
Apr 12, 2008 | Washing Machines
Kenmore Washer won't agitate, spin or drain
It's not your exact model but does have some good information about the possible causes.
http://www.shopyourway.com/questions/1099421
If you need further help, reach me via phone at https://www.6ya.com/expert/sean_97e45db9c0ed1da4
Apr 07, 2017 | Washing Machines
Washing Machines Logo
22 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
