Question about OKI C9600hdn Laser Printer
OKI C9850 Yellow is out of registration side to side by 1/8 inch. I get a reg error. Have swapped OPC, fuser, controller board, reg sensor assy, transfer belt and yellow imaging LED assy. What now???
Soulvisitor
  • 1113 Answers
SOURCE: Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Posted on Jan 02, 2008
Soulvisitor
  • 1113 Answers
SOURCE: Oki c5100n printing colors offset
posted by Halfwalkeer on Nov 13, 2007 Report abuse
Just replaced the color toner cartridges in the c5100N, two OKI (cyan and yellow) and one non-OKI (magenta). Now it appears that registration is completely off.
When printing an image, there is a band of yellow at the top about 6mm high, and a band of purple (not cyan) at the bottom about 6mm high. It seems that the yellow printing LED array is printing offset. I've verified this with a typical test page that shows yellow blipped up by several mm.
What the hell happened ? How can I fix it ?
Thanks -
Dean.
Comment by Halfwalkeer, posted on Jan 02, 2008 Drums are all at 34%. Please don't tell me that the drums only have a 50% lifetime on them, because that would just suck royally. When you say the problem is most likely drums, in what way ? What could have gone wrong ?
I was able to more or less fix the problem ... It took several iterations of ColorMenu->Adjust Registration followed by Maintenence Menu->Menu Reset, but it was finally able to pull the registration back into line.
I got worried at one point - after it was "fixed" the printer was powered off. Upon powerup again, registration was off by several centimeters ! Another round of the above finally "fixed" it again, but I haven't powered it down again.
It was a cheap printer. Maybe this is why ...
postsolution.gif Post Solution addwq.gif Work Queue sameproblem.gif Have the same problem? X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Solution #1 posted on Jan 02, 2008 0%20stars.png
4d566c2.jpg Soulvisitor
Rank:guru_s.gif Guru
Rating: 86%, 674 votes
Comment by Soulvisitor, posted on Jan 02, 2008 I was thinking about the band of yellow being caused by cleaning blade wearing on drum, drums are garenteed by oki if over 50 %, under that one is on their own ie purchase new if having problems with them
If you can fix problem doing colour calibration then faulty drum is not likely the issue.
Cant stress how many problems are caused by non gen consumables in machines, highly dont recommend their use.
Posted on Jan 13, 2008
SOURCE: OKI print quality problem
is this still current?
Posted on Aug 19, 2008
  • 97 Answers
SOURCE: OKI C7300
Reload the yellow toner and re-seat the drum assy
check for foreign objects under toner/drum assy
make sure toner is locked and drum is seated correctly
also, check the small door on the left side of drum
if stuck closed, gently push open with small screwdriver
Posted on Dec 08, 2008
  • 4090 Answers
SOURCE: wrinkling envelopes in FS-3900 Kyocera Printer.
try chaning the quality of the envelope, some do not respons well to heat.
Posted on Jun 23, 2009
My oki c3400n continual paper jam's at the fuser. Paper comes out of the printer about 2 inches then jam's. I clear it and it happens again. Don't see any contamination on the fuser roller.
There are paper path cleaner sheets that you can get at supply stores or on line. They are sticky on both sides. They pick up paper dust from the rollers as it passes through the printer.
Feb 17, 2016 | OKI Office Equipment & Supplies
Tip
ERROR codes Canon 3025
Canon 3025
E000 Fuser problem
E000 Heat
E000 Fuser problem
E010 Main motor, motor board, clock pulse
E010 Drive
E030 Counter
E030 Counter
E050 Duplex side to side problem
E050 Duplex problem with cross alignment
E051 Duplex side to side problem
E051 Crossway registration
E200 Scan problem
E200 Scan reverse sensor or scan
E202 Scan return problem
E202 Scan home sensor or home scan
E204 Scan
E204 Document sensor, scan reverse sensor or scale
E210 Lens problem
E210 Lens
E220 Lens
E220 Blank lamp open or lens home problem
E240 DC controller
E240 Bad DC controller
E400 Document feed problem
E400 Document feeder board problem or document feeder interface problem
E500 Sorter
E620 Editor
E620 Editing problem
on Jan 18, 2010 | Office Equipment & Supplies
Oki c8600 registration error 3
Registration Error 3
When a color registration error is detected with coarse
adjustment, or with the main-scan line adjustment.
PU firmware does not notify this warning to CU firmware
at the time of Shipping Mode. Therefore, this status
does not occur in a user environment.
n
2 = Yellow
3 = Magenta
4 = Cyan
Dens Shutter Error 2
DENS SHUTTER ERR
Check 3: Check to see whether the sensor shutter opens and closes normally, by the
MOTOR & CLUTCH TEST of the self-diagnostic function. If the shutter operates
imperfectly, replace the shutter unit.
May 06, 2014 | Oki Electric Industry C8600n Led Printer
Hp2300 jams half way out of tray 1 and tray 2
1. Up to where paper traveled.. If its reached up to Fuser assembly & curl folds accrued under cartridge.. replace Teflon sleeve or Fuser assembly.
2. If paper traveled up to Fuser out(near 2-3 inch)...Clean/replace/flag Fuser out paper sensor
3. If paper traveled up to registration assembly:Clean registration sensors/flags.
4. Check pickup rollers.
Feb 20, 2013 | HP LaserJet 2300 Printer
Oki C9650 not printing Yellow
remove the unit
open the cleaning lamp cover (front of unit)
turn O.P.C drum gear and check that toner is always applied to the developer roller
Sep 27, 2012 | Oki Printing Solutions C9650 Led Printer
OKI 3530 MFP Service call: 150
Your error 150 is the toner sensor board not making contact with a drum and therefore not blowing its fuse. Remove the Main board and you will find the toner sensor board behind it. It has a lot of metal contact springs and you will most probably find one is out of position and just requires removing and refitting. If still not working the part number for the board is: 43614901 OR-Board-PRS
Good luck.
Jul 09, 2017 | OKI B4350 Laser Printer
LED reads color registration error
The black along the side of the paper is usually the black photoconductor , it also could be the fuser. If the color reg says can't be preformed it probly needs a new transfer belt. If the color reg completes and the colors still don't line up it might be the laser. It also could be dirty reg sensors.
Mar 24, 2009 | Ricoh Aficio AP3800C Laser Printer
25 Encoder fail
1. The tractor encoder signal is faulty.
a. Clean any toner or paper dust out of the encoder sensor.
b. Inspect the tractor encoder wheel for damage. Replace it if necessary.
c. The encoder sensor is faulty. Replace the tractor encoder board or the entire tractor
unit.
d. The fuser drive clutch is slipping; replace it.
e. Replace the Engine Controller Board.
f. Replace the encoder cable.
�� Tractor Encoder. The Tractor Encoder Board has two optical sensors that sense the
1/8 inch and 1/16 inch slots in the Encoder Wheels. These pulses are sent to the Engine
Controller Board and are used to monitor and control print location and paper movement.
Location
Remove the Tractor Encoder Cover by removing 1 Screw.
NOTE: Upon installation, the groove on the bottom of the Encoder Cover should
straddle the top of the left end of the Tractor Frame.
Left side of printer, just left of the tractor assy.
Dec 05, 2008 | Printronix LaserLine L1524 Printer
Oki c5150 fuser jamming
This tells me the one of the Pickers in the fuser is damaged and causeing this Jam , I would replace the fuser and chaces are this most likely will resolve your problem
May 02, 2008 | OKI C5150n Led Printer
OKI C7300
Mar 03, 2008 | OKI C5300n Led Printer
OKI C9600hdn Laser Printer Logo
7,051 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
