Question about 3Com Baseline 2848-SFP Plus 48-Port Gigabit Ethernet Switch (3C16486US)
Hi i forgot password for 3com baseline switch 2848-SFP plus.. can u help to reset the default password thank you rex
4 Suggested Answers
botaksetan
  • 80 Answers
SOURCE: How do i Reset or break in to get reset my
The resetting of the password requires the installation of a console cable to the console port.
Be sure the terminal emulator program is set to VT-100 management using compatible, 38400 baud rate, no parity, 8 data bits and Console connection one stop bit.
Use the included cable, or be sure that the pin-out complies with a standard null-modem cable
Once the cable is connected, reboot the switch. Type a Ctrl/C until you enter the failsafe mode. This will be denoted with the prompt: “CFE>”
At the prompt execute the following commands:
CFE> passwrd
CFE> reset -sysreset
At this point the password has been reset.
Posted on Jan 20, 2010
  • 121 Answers
SOURCE: i forgot my admin password
If it's the Power Plus (3C16475BS) model, there should be a reset button inside a small hole on the back. "10 - Recovery Button" Inserting a paperclip or similar to reset. If it's not the Power Plus model and is in fact (3C16475A), this is an unmanaged switch, with no administrative capabilities. You don't need a password.
http://www.3com.com/products/en_US/detail.jsp?tab=features&pathtype=purchase&sku=3C16475BS
Posted on Feb 25, 2011
  • 136 Answers
SOURCE: i have 3Com Baseline Switch
There is usually a small button on routers that can be accessed with the tip of a pen or a paperclip. When you find that tiny button, hold your pen or paperclip down on it for approximately 10 seconds until the router resets itself to factory defaults.
Posted on Jul 29, 2011
I forgot ip address and password and want to factory reset
Connect the console cable, open a connection to the serial port via a utility such as PuTTY, and do the following:
1) Enter the user name "recover" and password "recover" to place your unit in password recovery mode. The unit will remain in password recovery mode for 30 seconds max.
2) Perform a hard reset by removing power, waiting 10 seconds, and then re-applying power.
3) Once the switch has rebooted, enter a new password for the "admin" user account.
4) Enter enable to leave password recovery enabled, or enter disable to turn it off. You are now logged in as the default "admin" user.
Note: If password recovery has been disabled, the only way to recover access is to return the switch to 3com.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Superstack 3 3848 reset at default
Hi ! I think this solution should be approached. Because this procedure is the same for switches 3Com and HP A-series with Comware OS.
1. Connect light blue console cable between a computer (serial) and the 3COM switch (RJ45 console port)
2. Open PUTTY or Xshell or HyperTerminal with a serial connection and the following settings (19200, 8, 1, N) If not connected may use 9600 or 115200 bps
Starting......
* 3COM 2928-SFP Plus BOOTROM, Version 119 *
Creation Date : Feb 3 2010
CPU L1 Cache : 32KB
CPU Clock Speed : 333MHz
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Mac Address : 002473959EC8
4. When "Press Ctrl-B to enter Extended Boot menu..." appears, press "CTRL+B"
Press Ctrl-B to enter Extended Boot menu...0
Please input BootRom password:
BOOT MENU
5. Press "7" to "Skip current system configuration"
1. Download application file to flash
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5. Modify BootRom password
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set BootRom password recovery
9. Set switch startup mode
0. Reboot
Enter your choice(0-9): 7
7. Press "Y" to skip the current config at next reboot
The current setting will run with current configuration file when reboot.
Are you sure you want to skip current configuration file when reboot? Yes or
No (Y/N):Y
Setting...Done!
8. Now Press "0" to reboot the switch
BOOT MENU
0. Reboot
Enter your choice(0-9): 0
9. The switch will reboot, allow it to fully boot this time
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Starting to get the main application file--flash:/S2900-CMW520-R1101P09.bin!...
The main application file is self-decompressing................................
.........................Done!
System is starting...
Configuration file is skipped.
User interface aux0 is available.
10. Press "Enter", you will not need a password to login.
Press ENTER to get started.
<3Com Baseline Switch>
#Apr 26 12:00:16:292 2000 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>: login from Console VMadmin.co.uk
%Apr 26 12:00:16:461 2000 3Com Baseline Switch SHELL/4/LOGIN: Console login from aux0
11. Now type "initialize" to delete the configuration file and reboot the switch once more, Press "Y" to accept reboot.
<3Com Baseline Switch>initialize
The startup configuration file will be deleted and the system will be rebooted. Continue? [Y/N]:Y
Please wait...
#Apr 26 12:00:33:537 2000 3Com Baseline Switch DEV/1/REBOOT:
Reboot device by command.
%Apr 26 12:00:33:641 2000 3Com Baseline Switch DEV/4/SYSTEM REBOOT:
System is rebooting now.
12. The switch will full start up again, this time completely factory reset.
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Startup configuration file does not exist.
13. Press "Enter", then enter the username "admin" and password "<blank>". Press "Enter" and you will be logged in.
Login authentication
Username:admin
Password:
#Apr 26 12:00:19:811 2000 this article is from VMadmin.co.uk 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>:admin login from Console
%Apr 26 12:00:19:981 2000 3Com Baseline Switch SHELL/4/LOGIN: admin login from aux0
14. If you type "summary" you will see all the switch details.
Amongst these details are the IP address of the switch. If you have DHCP on your network this switch is connected to it will receive one as in my case below, so I can now configure the rest via a web browser.
If not you can use the "ipsetup" command to set a static management IP and access via a web browser.
<3Com Baseline Switch>summary
Select menu option: Summary
IP Method: DHCP
IP address: 192.168.1.250
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.254
Current boot app is: flash:/S2900-CMW520-R1101P09.bin
Next main boot app is: flash:/s2900-cmw520-r1101p09.bin
Next backup boot app is: NULL
3Com Corporation
3Com Baseline Switch 2928-SFP Plus Software Version 5.20 Release 1101P09
Copyright (c) 2004-2010 3Com Corp. and its licensors. All rights reserved.
3Com Baseline Switch 2928-SFP Plus uptime is 0 week, 0 day, 0 hour, 1 minute
128M bytes DRAM
128M bytes Nand Flash Memory
Config Register points to Nand Flash
Hardware Version is REV.B
CPLD Version is 002
Bootrom Version is 119
[SubSlot 0] 24GE+4SFP Hardware Version is REV.B
15. Once you can access the web management page for the switch make sure you set a strong password for "admin" and store it in a secure encrypted location for next time.
16. Don't forget to save your new configuration! Otherwise the switch will be at factory defaults if the power goes off!!
Jul 24, 2017 | 3Com SuperStack 3 3848 48-Port Gigabit...
I work at a school and we are trying to connect 2 HP 3com Baseline switch 3952 together. however when I plug in my Cisco SFP modules into both the switches, neither of the ports light up and establish a...
1.what type of fiber is:SM (single mode) or MM (multi mode)?
2.what type of sfp? 1550 or 1310 if is SM, how many conectors and what type of conectors
3.in 3com usualy u dont need to make a port anouncemant as u need in cisco so if the sfp are ok, i mean if they are pairs and the fiber is same type should work, second problem : sometime the cisco sfp(when is not original from cisco) got problem in other brands hapend to me whit zyxel sw,
so give me more data and i will help you
thanks
Sep 22, 2011 | 3Com Baseline Plus 2952 52 Port Gigabit...
I have 3Com Baseline Switch 2924-SFP Plus i need to manage it but i forget the administrator password how can i reset this switch to manufacture configuration or how to reset the password
First,"There is usually a small button on routers that can be accessed with the tip of a pen or a paperclip. When you find that tiny button, hold your pen or paperclip down on it for approximately 10 seconds until the router resets itself to factory defaults."
After that, you can contact the manufacturer to get some helps if you still have problem.
BTW,
I work for Ingellen Communication Equipment and we are a large fiber optic equipments manufacturer in Shenzhen.Kindly let me know your specific requirements so that i can help
Jul 29, 2011 | 3Com Baseline Switch 2924-SFP Plus
I forgot my admin password on my 3com baseline switch 2226-sfp. i can't remember. Can you please help mo to reset my baseline switch to reset the password only. Thanks jenry
Feb 25, 2011 | 3Com 3C16475A Baseline Switch 2226...
How do I reset the switch?
select restore factory default in administration tab or push reset button
Jan 18, 2011 | 3Com Baseline Switch 2948-SFP Plus 48-Port...
Default password is incorrect or reset doesn't work
The default ip is 192.168.1.1
default user-name and password for the 5 models of 3com are as follows.:
1.
3com default ip: 192.168.1.1
username: n/a
password: admin
or
2.
user-name: adminttd
password: adminttd
or
3com default ip 192.168.1.1
user-name: admin
password: n/a
or
user-name: n/a
password: PASSWORD
OR
5
user-name: root
password: !root
ok try
this
Note that at time you will need to set your local ip of your pc from which you are acess the device to the same range...
That is for example 192.168.1.10
Good luck
uttam
Feb 26, 2010 | 3Com 2816-SFP Plus (3c16485-us) 16x1000...
How do i Reset or break in to get reset my password on 3Com 2948 Baseline Switch 48Port SFP Plus
CFE> passwrd
Jan 20, 2010 | 3Com Baseline Switch 2948-SFP Plus 48-Port...
3Com Baseline 2848-SFP Plus 48-Port Gigabit Ethernet Switch (3C16486US) Logo
1,035 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
