My electric baseboard heater makes an annoying clicking sound constantly. I know it is the expansion of the metal but is there a trick to get rid of the noise. I just moved into my new home and had never been diturbed by my heating like tis. I hear the clicking from downstairs! Thanks for answering.
  • 3,289 Answers
You are correct, the "clicking" sounds you hear are the result of the metal expanding due to heat. You're probably hearing it more now probably because the thickness of the metal parts is thinner than that of those your old house's baseboard heaters. There is really not a whole lot you can do about the issue outside of replacing the units that bother you. Fortunately, these hears are pretty inexpensive to purchase and easy to install when used as a replacement for existing heaters. If unsure or uncomfortable doing the work, contact an electrician.
Bring a short heater's cover and compare the thickness of it to those you find for sale elsewhere. A thinker cover will be less noisy - but will make *some* noise when heating.
I hope this helps & good luck!
Posted on Mar 21, 2011
Pulsating noise in electric baseboard heater
It is the coils they can't take the heat so the hoter it is the more vibration from heater
Mar 30, 2016 | Marley Heating & Cooling
My electric baseboard heaters make a pinging sound which drives me nuts when I am trying to sleep! Any suggestions other than changing the unit? Thanks
Electric baseboard heaters heat by radiant heat. This mean the heater is heating the metal of the heater first which causes expansion of the metal. This will cause popping metal sounds becouse it is heating up. When it kicks off, by the thermostat, it starts to cool which causes contraction of metal. This will also cause noise. Most all base board heaters I have installed and worked on does this. Sorry there is little to nothing you can do. :)
Jan 25, 2011 | Marley HBB1004 Electric Baseboard Heater
My 500 Watt Electic Baseboard heater ticks all the time, what can I do to stop this. Thank You
More than likely, the ticking is caused by the heating element ... expanding and shrinking as it gets hot and then cools off. You might get rid of some of it if you will gently lift the element and insert a small piece of fiberglass between the element and the element rest. If this noise annoys you ... maybe you can turn the radio up? :-) Don't use any other kind of material for this job.
I hope you find this suggestion helpful ...
Thanks for your interest in FixYa.com
Nov 27, 2010 | Marley HBB1004 Electric Baseboard Heater
The baseboard is very noisy? Humming sound
there are clips that hold the actual element inside the enclosure.check to see they are loose or broken. a small amount of humming noise is normal while the heater is being energized expansion/ contraction of alumimun fins is normal.
Feb 19, 2010 | Fahrenheat FBE15002 Baseboard Heater
How far off the floor do i install hot water baseboard heaters
When you install the baseboard heater make sure the bottom part which is the all thing must sit over the floor and touch the tiles or carpet and use 2 or 3 wood screw against the wall. That is it and do not put any kind of paper or cotton or material things above the cover. Beside that you are ok and it is not like an electric wall heater.
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
When my heater kicks in after a few minutes there is a pop.
the sound that you are hearing may be from the metal expanding when it gets hot.
Nov 25, 2008 | Fahrenheat Electric Convector Baseboard...
2000 watt baseboard heater is making loud clicking noise
Most base board heaters installation instructions say to attach to the wall with screws which are slack ( not fully tightened) in order to allow the heater case to expand and contract otherwise you get a clicking noise
Nov 17, 2007 | Heating & Cooling
Heating & Cooling Logo
191 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
