Question about Western Digital My Passport Elite WDBAAC3200ARD - hard drive - 320 GB - Hi-Speed USB USB 2.0
My wd passport has just stopped registering but lights on and beeps 3 times when turned on.
  • Western Digital Master
  • 27,725 Answers
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure
hope this helps
Posted on Mar 21, 2011
My wd passport wont open the details and files ....it is there on devices and printers but wont open the files in it..my wd passport is wdbacy5000abk-01
What hapened to the drive before it stopped working, does it fell down? try to listen to drive very carefully, does it spinning ? are there any abnormal noises e.g click... or beeps ?
Feb 25, 2014 | Western Digital My Passport Essential...
WD 1TB light is on but not blinking and can not be read
You can try to open the hard drive cabinet and to put the hard drive into another cabinet in order to see if the problem comes from the unit itself
Feb 05, 2013 | Western Digital 1TB WD My Passport SE for...
When I turn on my dell 9200, a beeping sound starts from the CPU and nothing comes up on the screen
how many beeps you have?if three short beeps its you RAM failure..try to reinsert you RAM or replaced it a new RAM..if theres a long beep..its your video card..
Jul 27, 2011 | Dell Dimension 9200 PC Desktop
Everytime i start up the computer it beeps 3-4 times, and the monitor says vga input not connected...whats could be the problem?
here are the beep codes for your exact dell model. this should give you a starting point on finding out what the problem is.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Reseating the memory modules may fix the beep code errors in the following table. If the problem persists, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-3-1 through 2-4-4
Memory not being properly identified or used
4-3-1
Memory failure above address 0FFFFh
If you hear one of the following beep codes, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-1-2
Microprocessor register failure
1-1-3
NVRAM
1-1-4
ROM BIOS checksum failure
1-2-1
Programmable interval timer
1-2-2
DMA initialization failure
1-2-3
DMA page register read/write failure
3-1-1
Slave DMA register failure
3-1-2
Master DMA register failure
3-1-3
Master interrupt mask register failure
3-1-4
Slave interrupt mask register failure
3-2-2
Interrupt vector loading failure
3-2-4
Keyboard Controller Test failure
3-3-1
NVRAM power loss
3-3-2
NVRAM configuration
3-3-4
Video Memory Test failure
3-4-1
Screen initialization failure
3-4-2
Screen retrace failure
3-4-3
Search for video ROM failure
4-2-1
No time tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
Unexpected interrupt in protected mode
4-3-3
Timer-chip counter 2 failure
4-3-4
Time-of-day clock stopped
4-4-1
Serial or parallel port test failure
4-4-4
Cache test failure
Jan 01, 2011 | Dell Dimension 4600 PC Desktop
Its a western digital WD passport 750GB portable drive and its not showing up on my computer. I can see the blue light and feel it running but not registering on the laptop or desktop
Usually what has happened here is the usb interface has failed. The little hard drive with all your data is perfectly fine but the interface can no longer talk to the computer.
There are a couple of fixes. One is to send it in to WD who may or may not preserve your data. You can buy another passport and take the drive out and put it into the new drives enclosure. And third which is the way I've been fixing these is to go buy a usb drive enclosure. These start at $15 and up. Then you just take the drive out of your passport, plug it into the enclosure and you are back up and running.
This type of failure is common to all manufacturers.
The enclosure swap is something you can do yourself. The hardest bit is actually opening the case on the passport. Any computer shop should be able to do it for about $40 or less.
Sep 29, 2010 | Western Digital WD Passport 250GB Portable...
My WD external drive dropped about 2 feet. It now makes a whirring/beep sound. I was able to successfully disconnect the unit. I have turned off and restarted the computer. The whir and beep stopped,...
Ok their is a needle that FLOATS above the metal disks inside the hard drive, when that is dropped either when its on or off, if that needle TOUCHED the disk in anyway your drive is scratched and screwed, thats what happened to yours, sorry but you need to buy a new one.
Aug 09, 2010 | Western Digital WD Passport 250GB Portable...
I forgot my password how can I open WD passport?
This one way for unlocking your WD passport but assume you will lost your data
Download wdsmartwareupdate here : http://www.wdc.com/wdproducts/wdsmartwareupdate/
Download instructions :
1- Locate you WD disk entry, click on Windows or Mac according to your operating system.
2 - Click on Download now link at the bottom and download the soft.
Unlock instructions :
1- extract the zip file you've downloaded en run the.exe.
2- select Continue to update and accept Licence Agreement.
3 - Next select Update Firmware
4- Check the check box "I understand ......" under Warning section, a button "drive erasure" will appear.
5- Click on drive erasur button
6- Wait until the end of the process and quit
7- Unplug/turn off the passport and plug it back in. Your WD passport is unlocked
Dec 16, 2009 | Western Digital Passport WDXML800UE...
I accidentally droppped my brand new 320gb WD Passport now it isn't working it lights up & it has a tick sound then stops spinning...pls help.. :(
Most likely you have damaged the actual harddrive, the ticking sound is NOT A GOOD HARDDRIVE SOUND! Contact western digital and tell them that your NEW harddrive is making this sound out of the box DO NOT MENTION DROPPING IT. They should RMA it as long as you really did just buy it.
Oct 04, 2009 | Western Digital Passport 320GB External...
WD Anywhere Backup expired? What next?
If you purchased the software not a trial just register the product it's Free.If it was a trial then $ could be involved.Good Luck.
Sep 11, 2009 | Western Digital Passport WDXML800UE...
Western Digital My Passport Elite WDBAAC3200ARD - hard drive - 320 GB - Hi-Speed USB USB 2.0 Logo
1,176 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
