Question about Uniden GPS
I have a uniden trax430 gps how do you set up bluetooth. thanks
Hey allison460
The reason why you can't get bluetooth is because that model doesn't support bluetooth connectivity. The versions superior to this 430 model do. I have the Trax430 also and it works fine for me in New Zealand, although there are some map issues with the POI's (points of interest).
Hope this was a help to you.
Trent
NZ
Posted on Mar 30, 2009
I plugged into a 24volt vehicle,It blew fuse which i replaced,Now it wont even turn on when plugged in.
Bummer, unfortunately, even though the fuse is designed to protect the unit it is still possible to damage the unit before the fuse blows. Fuse blow based on (amps x volts). I am not an electrical engineer but amps x volts = watts. This is ohms law. If the device is designed to run on 12 Volts and you plugged it into 24 something fried.
Now is a good time to take out the tools and see how it works. It may be very obvious, with a magnify glass to see at least one burn part. The bad news is the new boards use such small components that even if you can identify the burned out part, you may not be able to replace the part.
The good news is there is a possibility that you can replace the bread board, however there will be no warrantee.
Sep 03, 2014 | Uniden TRAX430 4.3" TTS US MAP
Uniden Trax 436 GPS - how do I update it. It is sitiing in Update Mode for hours but no sign of completing update
Welcome to FixYa!
To update your Uniden GPS, you need to run the Uniden Trax Central Software while your GPS device is plugged in the computer.
Thank you for using FixYa.
Have a great day.
Jas247
Jul 13, 2011 | Uniden TRAX-436 Car GPS Receiver
User Manuel for Uniden bc108 head set
Hi weesillys56,
I believe you mean the BT108 Bluetooth Headset. Here is where you can download the manual for that unit, as well as the BT109:
http://www.uniden.com/pdf/BT109om.pdf
This should get you going. Thanks.
Regards, Bill
Sep 27, 2010 | Cell Phones
How do i up date on my uniden at the moment i am on update mode and a flower in the left hand corner is going round and round its been doing this for quiet a while how long does it take thank you judy
you need to go to uniden - http://www.uniden.com.au/AUSTRALIA/traxcentral.asp
download trax central software
plug in the usb cable to your pc with the uniden in update mode
run the trax central software - it should find your device and allow you to update it
May 12, 2010 | Uniden MapTrax GPS352 GPS Receiver
Need map of England for my Uniden 3.5 gps
no one can help you until we know what maps it uses. Many unidens were sent out with different brand maps
Igo Igo8 Navig8tor Polstar Insync Destinator etc etc.
No maps are free You need to contact Uniden because just buying a map will not work It has to be written for the Uniden engine.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Uniden MapTrax GPS352 GPS Receiver
Looking for updates on trax430 gps is there any and how do i get them can i buy updates for this thank you
hi there you can not update the 430 on line i have just found out, rand uniden support. You have to send it to them and they update it at a big cost $189.00 nz.
thanks
Apr 07, 2010 | Uniden TRAX-430 GPS Receiver
S620 Using GPS with Memory Map software
In the Comm Manager, select Settings, then Bluetooth.  Again select bluetooth and then scroll down to your GPS receiver assuming you're paired correctly.  Click Menu and then COM ports.  Now click Menu and select New Outgoing Port.  Pick COM6 assuming you have nothing else on this as your outgoing port.                   Now go back to your map program.  In the GPS settings, select COM6 as your GPS and it should now give your position.  I use google maps and have no bother.
Aug 19, 2008 | HTC S620 Smartphone
700p bluetooth set up with Sanyo GPS 4050
I got the pairing code via searching the internet it is 0000 and worked just fine. Now however I get an "Unable to connect message". Sanyo tech support is very hard to get a hold of.,.
May 12, 2008 | Sanyo NVM-4050 GPS Receiver
Bluetooth GPS Tom Tom to operate with PDA Xda IIi
Have you tried using 'other wired device', try each com, rather than bluetooth, on tomtom configuration settings, works for me with TT5 and a Holux BT GPS reciever
Jan 28, 2007 | O2 Xda III
GPS Logo
388 people viewed this question
Top Uniden GPS Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Martin Murray
Are you an Uniden GPS Expert? Answer questions, earn points and help others
