Question about Whirlpool Duet GHW9150P Front Load Washer
I have a duet model ghw9150pw3 and on the spin cycle even with no clothes in it, it will knock and vibrate. it is worse with clothes in it. no codes or anything come up.
  • 1 more comment
  • mgpg24 Mar 21, 2011
    machine is super level
    machine is dead level
    MACHINE IS DEAD LEVEL
    Guru:
  • 262 Answers
Top Removal
1. Disconnect power supply to unit.
2. Remove 2 10mm screws from washer back.
3. Slide Top Cover towards the rear to clear the screw
head from flange on the bottom side of the Top
Cover.
You will see two suspension springs, one on each side of tub. Ensure they are secure.
Make a visual inspection of unit.
Motor nut check and rear struts
2. Remove two screws attaching Back Cover and slide
cover up and lift bottom edge out of retaining slots.
3.Check the tightness of the rear pulley bolt.
Tighten if necessary.
4.There are two rear struts that are on each side of the tub.....ensure these are secured. Push top of tub down slightly to ensure they move freely up and down.
If you haven'y found any issues....plug machine back in,with rear cover off, start a spin cycle and watch from rear. This should show you just what is happening.
Please post results.
Keith
Posted on Mar 21, 2011
    Brigadier General:
  • 3,513 Answers
Hi
Please check whether your machine is in level or not,this the most important reason for a washing machine to vibrate.
Thanks for contacting fixya.com ,please get back to us for further queries.
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Whirlpool duet steam washer knocking noise when in spin cycle.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Loud knocking and vibration during spin
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have WP Duet HT front laod washer. Model #-GHW9250ML1 Type 199 080 SC/WG Problems - 1. while the tub is spinning it makes a knocking sound. When the tub slows it knocks louder. What is the problem and...
COULD BE LOOSE BASKET OR REAR BEARING LEAKING OR SIMPLY SUSPENSION SHOCKS BROKEN ,, EVEN SHOWS 1 MINUTE JUST ESTIMATE TIME NOT READY TO SHUT DOWN NORMAL ON DUET MACHINES
Nov 29, 2008 | Washing Machines
Whirlpool Duet GHW9150P knocks when spinning
I had that problem while the washer was under warranty. Luckily my neighbor is a repair man. He removed the front cover just under the door. There are shocks under the barrel that keep it aligned. One of mine was damaged and the barrel became misaligned. Check that area, that might be your problem. Good Luck!
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Spin Cycle
SOUNDS LIKE THE MAHINE IS NOT LEVEL LIFT THE WASHER UP AND LET DOWN EASY IF YOU HAVE SELF ADJUSTER IT NOT YOU MUST ADJUST THEM YOURSELF THE SQUEAK
COULD BE DUE TO UNBALANCED WASHER OR BEARING IN THE MOTOR
Oct 27, 2008 | Maytag PAV2300 Top Load Washer
Duet HT has Knock in Spin cycle
well id be leary myself and honestly not at the machine but the tech(s) that are looking at it. i would put back in for another call request a different company if possible.Theres probably 7-8 authorized Whirlpool service Companies in my area alone. acn demand that the tech call the Technical assistance line if unsure of problem.I cant see telling a cust "normal noise don't worry about". these units spin very quietly.On a side note they were installed correctly??? strange to get 2 with came problem..
Mar 13, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal De
