Question about Hotpoint 23 in. BFI68 Built-in Dishwasher
My BFi 680 dishwasher swithches on and lets you choose a program but after around 2 mins it stops and lights 5&7 are flashing (rapid and auto Duo wash) the filters are clean.
  • tdavison590 Mar 24, 2011
    Having checked the prices it appears that the timer is around $120.
    Please confirm that you are sure that this will fix it?
  • 4,323 Answers
Hi
The timer is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 21, 2011
  • Daniel Scott
    Daniel Scott Mar 24, 2011
    Yes right it will
My Ariston LI 680 Duo has stopped working mid cycle. The Auto (eco) and Rapid lights are both flashing and the bottom tray is full of water.
they make cleaners that can be run through a cycle so you don't get the yuckies and it can get places you can't reach. if the float switch is good and its not got a clogged drain I would look for the diagnostic paper sheet that is usually under the front bottem panel.
it will give you voltage and ohm reading tests of components within the dishwasher. the circuit board is worth looking at also. look for browned parts which show heat fatigue. a electrical meter is a must and if not sure of what you are doing and don't want to get shocked by current find a friend close who knows how and can show you.
you say it stops at the same point. time it with a stop watch . if its always exactly the same time the board timer may be out which means board replacement. boards are cheaper than motors ,but bad switches are even cheaper. . run your tests and it will lead you in the right direction. hope it helps
Feb 20, 2014 | Dishwashers
HOTPOINT DISHWASHER BFI 620 ERROR CODE LED FLASHING 1 & 3
Check the end of your drain hose for the clog.
Feb 17, 2013 | Dishwashers
How to program in the 3 pre sets for garage door openers We have a 2001 dodge grand caravan es
Hope this a Homelink. Put new batt in garage door remote. Park outside garage. #(1) Press & hold 2 outer buttons on Homelink. Release ONLY after light starts to flash. Don't hold for longer than 30 sec. Don't repeat to program the other 2. #(2) Hold the remote 3 inches from Homelink. #(3) Press & hold the Homelink buttom & the remote button at the same time. #(4)The Homelink will begin to flash slowly then rapidly. After the Homelink flashes rapidly release the buttoms. #(5) Press the just trained Homelink button if the light stays on constantly, programming is complete..... To program the other 2 links DO NOT REPEAT #1
Jan 10, 2010 | 2001 Dodge Grand Caravan
2005 honda odyssey homelink programming
If you just received your vehicle and have not trained any of the buttons in HomeLink before, you should erase any previously learned codes before training the first button. To do this, press and hold the two
outside buttons on the HomeLink Transceiver for about 20 seconds, or
until the red indicator flashes.
Release the buttons, then go to step 1.
If you are training the second or third buttons, go directly to step 1.
1. Unplug the garage door opener motor from the electrical outlet.
2. Hold the end of the garage door opener remote 2 to 5 inches from HomeLink. Make sure you are not blocking your view of the red indicator in HomeLink.
3. Press and hold the remote transmitter button and one of the HomeLink buttons at the same time.
If the red indicator in HomeLink begins to flash slowly at first, then rapidly, release both buttons, and go to step 5. If the red indictor in HomeLink continues to flash slowly (does not flash rapidly), your remote transmitter may stop transmitting after a short time. Go to step 4.
4. Press and hold the remote transmitter button and one of the HomeLink buttons at the same
time. While continuing to hold the HomeLink button, press and release the remote transmitter button every 2 seconds. If the red indicator in HomeLink begins to flash slowly at first, then rapidly, release both buttons, and go to step 5. If the red indicator in HomeLink continues to flash slowly (does not begin to flash rapidly), repeat steps 2 thru 4.
5. Plug in the garage door opener motor, then test the HomeLink button by pushing it for about 1
second. If the button works, programming is complete. If the button does not work go to step 6.
6. Push and hold the HomeLink button for a few seconds, then watch the red indicator on HomeLink.
If the indicator stays on or flashes slowly, repeat steps 2 thru 5. If the indicator flashes rapidly
for 2 seconds then stays on, you have a rolling code transmitter. Go “Training with a Rolling Code System”
7. two HomeLink buttons to operate any other compatible remotely controlled devices around your
home (lighting, automatic gate, security system, etc.).
Repeat these steps to train the other
Jan 05, 2010 | 2006 Honda Odyssey
Hi My BFI 680 trips the electricity at the mains just as you put it on. Have cleaned the filters. Any ideas ?
could a internal fault in m/c[shorted wires] water,faulty on /of switch,recheck wiring to m/c
Dec 31, 2009 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Function buttons do not work on off button does
I have expreienced the same problem and carried out a hard re-set by holding down the on/off switch whilst pressing the program button. It's now working - but not sure for how long!
Jan 06, 2009 | Hotpoint 23 in. BFI68 Built-in Dishwasher
REMOTE CONTROLS WILL NOT WORK-WALL BUTTON FLASHING RAPIDLY
Does your wall switch have a lock feature? By pressing the lock button, the remote control is disabled. A flashing light indicates this feature has been activated.
To deactivate, press and hold the lock button for 2 seconds. The flashing should stop and your remote should work again.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Open Questions:
See all Hotpoint 23 in. BFI68 Built-in Dishwasher Questions
Hotpoint 23 in. BFI68 Built-in Dishwasher Logo
118 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
