Question about Whirlpool Ovens
Whoolpool AKG668/AV main oven continuoulsly trips off when initially switched on and the display flashes with zeros and a small letter 'A'. Resets after about 3mins then may happen again. Eventually it will remain on and works fine until it's switched off/on then happens again. I have noticed that at least one character in the display seems dimlyilluminated but in normal operation it's fine.
SOURCE: Whirlpool GBD307PDS Electric Double Oven
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
Posted on Jan 20, 2008
eagle338
  • 4889 Answers
SOURCE: Smeg oven problem
The pop would usually mean a busted fuse. Turn off the oven, disconnect completely from the power supply and then take it apart. See if you can find any toasted fuse or roasted wires. Also the reason for tripping the mains off is due to the fact that the oven is draining more power than it should. I would recommend a thorough inspection of the oven by an electrician..
Posted on Jun 18, 2008
  • 1462 Answers
SOURCE: AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Posted on Sep 07, 2008
  • 44 Answers
SOURCE: Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Posted on Mar 19, 2009
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Posted on Nov 02, 2009
Why does it trip breaker?
There probably is an internal short.
Oct 04, 2015 | Neff Ovens
Cooking a roast in small oven last nite, all electric went, oven tripped it. Now no top oven working or main oven or fan. What has gone wrong?
When the mains fuse keeps tripping as soon as you switch on the oven, there could be a shortage in the oven, or some of the voltage is leaking to the ground. What it is causing it? I would not know. sorry.
Mar 24, 2015 | Ovens
When the oven is heating up, a light inside the oven flashes very brightly. Not sure what that means or if it is unsafe.
when the oven is cold open it and ensure the light inside is screwed in fully. It is probably making poor contact when it is cold.
If that does not fix it, ignore it. If the power to the element was shorting it would trip the earthleakage or your main power switch.
LPG
Sep 10, 2012 | Whirlpool Ovens
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
Power tripping off at mains when switching oven on
It will probably be the main oven element that has failed.
This is located at the rear of the inner oven compartment behind a removeable cover.
Jun 03, 2010 | Neff B1641 Single circotherm super...
Main (lower oven) will not switch on
You need to access the fan motor and see if you are getting a supply to it, if you are and it is not going, then replace it..
If no supply then I would suspect faulty selector switch or thermostat.
Plsz leave feedback.
Dec 09, 2008 | De Dietrich Ovens
Sep 07, 2008 | Ovens
Ovens Logo
48 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
