Question about LG 32LH20 32 in. LCD HDTV
No have hdmi signal 32lg2000-za and no suport for this model
I have a HX32N2176h Hisense 32" LED tv will this TV handle and display HD when connected to a Laptop or Android Box with HDMI Cable?
The Hisense HX32N2176H will display an HD signal of 1366x720 with the HDMI input. (Any resolution above 480 (lines of pixels) is considered HD.) However, this isn't a full-HD (1080) capable TV. See https://www.hificorp.co.za/hisense-32in-81cm-hdr-led-tv-hx32n2176 for the specifications. Click on the Technical Details tab.
I hope this helps.
Apr 25, 2018 | Hisense Televison & Video
Digital signal
This is an answer you'll find in your owner's manual. If you no longer have the manual, please go to Samsung's website.
Dec 15, 2013 | Samsung HW-E550 Crystal Surround Air Track...
Have hooked up system according to manual (I think) using HDMI, to Samsung plasma set. Also have audio cable hooked up (from subwoofer to tv). Get absolutely no sound through system. I imagine I have...
Look on the back of your TV for an HDMI port that has "ARC" on it, connect that to the HDMI Out on the subwoofer. Make sure that your HDMI cable supports ARC. That is the only connection you should need to the subwoofer, remove everything else. Other option is an optical cable between the TV and the Subwoofer.
I just discovered this after fooling around with it for the past couple of days!
Dec 27, 2012 | Samsung HW-E550 Crystal Surround Air Track...
LG TV HDMI no signal problem
You need to make sure the TV is set to the same input that you are plugging into. This is done in the video menu.
Oct 05, 2012 | LG 32LG30 32 in. LCD HDTV
What does v3.35.1 mean on a blank white screen on a LG 37LG3000-ZA MODEL
If you're trying to use it as a monitor, it looks like the HDMI port on the tele is not working. It could also be a faulty lead from your PC.
Jan 05, 2011 | LG Televison & Video
Acer al2216w problem
wronge connection check it
May 01, 2010 | Acer AL2216W LCD Monitor
TV not receiving video signal from DVD. Component video setup from DVD player to SR-606; DVD input assigned to IN1; TV receiving TV signal routed through same HDMI working OK. Was working OK once. Didn't...
This model has a defective hdmi pcb assy. this is a well know defect with this model.If under warrenty have hdmi bd replaced if not the hdmi pcb assy retails around $350.00
Mar 28, 2010 | Onkyo TX-SR606 Receiver
Resolution not supported error on Iomega SCREENPLAY HD 500gb
Avi files should be 700 or below when playing on a conventional tv,625 or 525 prefered.
if set to hd format trough HDMI output the display warning will not appear has the iomega will upscale trough the HDMI output,and will suport any resolution.
Nov 11, 2009 | Iomega ScreenPlay
HDM1 BOX FLOATING
This is telling you that you do not have a High Definition Mode source connected to teh screen.
Oct 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
LG 32LH20 32 in. LCD HDTV Logo
305 people viewed this question
