I have a Kyocera TaskAlfa 420i, I need to delete all my printing jobs from the memory because I am getting a memory full message when I try to print, please tell me how to do this, I do not have a manual
Slimsl
  • 108 Answers
SOURCE: unable to delete print job
Switch off or unplug the printer and then delete it. make sure you have administration rights to delete print cue if your under active directory.
Posted on Dec 12, 2007
SOURCE: X5150 and Vista print issue
I am posting this in hopes of helping others that are having issues with the Vista print spooler. In my case, I have an HP Pavilion laptop running Vista connected to a wireless hub. I also have a Minolta Konica 2300DL printer that is connected to the network via the wireless hub as well. Ever since obtaining this laptop, I have not been able to print to the printer other than stopping and starting the print spooler to obtain a single print 'job'. After about six months I found a post that contains the fix - I cannot take credit for it! Follow these instructions to get your printer to work:
1.) Go into control panel - I would suggest classic view as it is a little easier to navigate.
2.) Then go into User Accounts.
3.) From User Accounts go into Turn User Account Control On or Off
4.) UNCHECK Use User Account Control (UAC) to help protect your computer.
5.) At this point you will probably require a reboot.
Once this exercise is complete, you should be able to print. One more item off of my Honey DOO list!!!!!
Posted on Oct 28, 2008
websnail
  • 419 Answers
SOURCE: printer will not cancel print job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
START
Control Panel
Administrative Tools
Services
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
Posted on Jan 25, 2009
frcs68
  • 1605 Answers
SOURCE: how do I clear data from my RAM disk on Dell 3100cn printer
The RAM for the printer is temporary.
turn off the printer and unplug the printer from the outlet. wait for 20 sec. plug the printer in and turn it on.
you can select in the printer properties page of the printer to print immediately instead of spool and print from the last page first. that will eliminated the ob store in the RAM.
Posted on May 15, 2009
SOURCE: i canceled a print job and it says it is deleting
If you haven't tried restarting your computer, do that first.
If that didn't help try to restart your print spooler.
Click on your start button and then on Run.
Type services.msc and then OK. In the services window find Print Spooler.
Double click it to open, it should say started. Click stop, wait for it to stop, then click start again. This should clear out your job.
Posted on Nov 24, 2009
Lexmark Optra S1250 Printer - Message "38 Memory Full". I tried to power on the printer without the printer cable attached.
You may have a document (or multiple copies of the same document ) stuck in the print queue. Turn off your printer, then pull the plug. Got to the control panel (or equivalent) on your computer and check the Lexmark print status for content and delete it, if possible. Reconnect the data cable to the printer, then reconnect power and turn it on to initialize. Cue up the print job again and go.
Feb 16, 2018 | Lexmark Office Equipment & Supplies
I HAVE SEEN ERROR f 248 IN TASKALFA 3501CI
Update firmware and make sure you delete all the jobs from the print Que, if the problem still exists you need to replace the hard drive.
Mar 19, 2016 | Kyocera Office Equipment & Supplies
How to fix error c2250 in kyocera taskalfa 420i?
You need to replace the charger, the charger is stuck and doesnot move, or if you have tech experience to remove the clip that locks the charger.
Feb 16, 2016 | Kyocera Office Equipment & Supplies
Error messg 016-700 Memory Full
Try this, it may be a large print job held in memory.
Press 80-0-1327 to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the print job.· Press Menu to open Stored Print and delete the holding job. · To avoid this error in the future, do the following:· Delete unnecessary fonts, macros, and other data in printer memory. · Install additional printer memory.
Oct 01, 2014 | Dell 2135cn All-In-One Laser Printer
Photocopy print too faint
developer unit has to run up via simulation 130 in service mode after kit is installed. or check installation of Transfer roller assy.
Jun 19, 2014 | Kyocera Mita TASKalfa 420i Maintenance Kit...
Eeprom TaskAlfa 420I
did u change or fix clean the efrom check the board
Feb 20, 2013 | Kyocera Mita TASKalfa 420i Maintenance Kit...
Kyocera printing black pages
Quite sure this is the main charger. Replacing it is best fix, but you must have heard this already.
Jan 22, 2013 | Copystar Kyocera Taskalfa 420i...
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
Free service manual with code for kyocera TASKalfa 180
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
Ram disk
Stangowner, In this case, the print job is too large for the available printer memory. Your choices are one of the following: Press to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the current print job. · Press Menu to open the Stored Print and delete the current job. To avoid this error in the future, do the following: · Reduce the number of print pages such as splitting the print data. · Increase free memory space by deleting unnecessary data in the RAM disk. As for the RAM disk: When you send a job to the printer, you can specify in the driver that you want the printer to hold the job in memory. When you are ready to print the job, you must go to the printer and use the operator panel menus to identify which job in the memory you want to print. You can use this function to print a confidential job (Secure Print), or verify one copy before printing additional copies (Proof Print). NOTE: The printer holds the job until you delete it by using the operator panel or you turn off the printer. (This is the RAM disk) NOTE: Print and Hold functions require a minimum of 320 MB available printer memory. Also, you need to configure the RAM disk settings on either the OPERATOR PANEL OR THE PRINTER DRIVER. NOTE: Depending on the documents, its job may be too big for the available memory. In this case, an error occurs. Take this link and print it out. It will help you later when you get "other" error messages. http://support.dell.com/support/edocs/systems/3100cn/en/UG/section19.html And here's a link for more "operational" situations. http://support.dell.com/support/edocs/systems/3100cn/en/UG/section16.html#1087088 ZT3000 "Beta tester of "0"s and "1's"
Aug 21, 2007 | Dell 3100cn Laser Printer
240 people viewed this question
k24674
jasbo
jasbo
