Question about Electrical Supplies
Clarke 9000 generator stopped putting out electrical power. asking for trouble shooting information. Has 150 hours and had been working fine.
3 Suggested Answers
  • 18 Answers
SOURCE: Generator will not generate electricity.
I assume it is a hand start genset. The most common problem if it has been sat for a while is rust on the ignition timing flywheel. If you take the pullcord housing off (recoil) then you will see a big flywheel with what can only be described as a big forked prong with a couple of wires on it. This flywheel should be stainless steel and rusts when sat around for a while without use. Its job is to complete the circuit to the spark plug every time the flywheel passes the forked prong at a given spot on the flywheel, the faster the wheel turns the faster the spark hence the engine runs quicker. Clean the rust off with a releasing agent (wd 40) hey presto!!!!!!!!!!!
Posted on Sep 19, 2008
SOURCE: hi, i have a clarke generator g900 ,no spark
this gen has a oil level sensor that will short the "primary" of the ignition coil as well as a spark enhancer that is called a CDI unit but the drawing does not show a Capacitor in or near it?
I hope this helps
Where did you get your replacement coil Colin?
Peter
Posted on Feb 14, 2010
1996 f150 no electric power
Blown main fuse or fusible link . Finding a electrical distribution diagram an using a volt meter to test to see where B+ voltage is missing is the way to find the problem . Do you know how to trouble shoot automotive electrical circuits ?
Apr 18, 2018 | Cars & Trucks
Power horse 9000 will not generate power
You7 need to run these tests in the video and come back to us with the results. Send your test results to us here: https://www.generatorguru.com/ask-the-guru/
Then we can tell you what the problem is :)
How to test your Electricity Generator AVR Brushes and Alternator on...
Feb 10, 2017 | Electrical Supplies
My coleman powermate pro 6750 generator only puts out like half power, after 30 minutes it loads up and runs fine. what causes this?
It would be surprising to me if the engine was running at proper speed while it is not putting out full power. I am not familiar with your particular model so my answers are coming from knowledge of generators in general. If it is running at proper speed then it would have to be a regulator problem. This is assuming that it isn't trying to run in an overload condition and that you are letting it run a little before you put a load on it.
Dec 22, 2015 | Coleman Electrical Supplies
I can jump it but then it runs for a minute and then quits running
Hi, if the car dies after removing the jumper cables, the alternator is not working. Remove it and have it tested at your local parts chain. If you have any questions, please let me know, and thanks for using FixYa.
Feb 02, 2011 | 2001 Pontiac Montana
Portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Mar 16, 2010 | Pramac Electrical Supplies
Can u esplain about trouble shooting in diesel generator
my 500 kva diesel generetors dosnt work since mornning its workes after 4 houres when the weather changed
Oct 25, 2009 | Pramac GBW30P Encl Diesel Genset w/Perkins...
1984 F-150 Brake Lights and Blinkers
on the brake peddle there is a switch when you press the brake peddle..check to see if after you press the peddle it should activate..it could be stuck or out of place...you may need to get a new one..
the blinker you will have to purchase a blinker relay...ask any part store for it...
Feb 16, 2009 | 1984 Ford F 150
Coleman Powermate only puts out 110V
If you haven't seen it yet, here is a page that may help with a manual or parts list.
This problem sounds kind of bad, generators don't do well when the engine stops under load.
Start by checking the circuit breakers in the distribution box (outlet panel) - you need ot do this with an ohm meter. After that check the power windings of the stator with the ohm meter, be sure to check between the 2 windings (should be open), and from each one to ground with the winding isolated.
Whining, a burning varnish smell, and breakers that trip all the time are indicators of long term overload problems. This could happen if you had most of the load on one winding for a significant amount of time, or if the one winding mostly powered motor-like loads with high startup currents.
You may want to look at this answer I posted some time ago.
Regards,
Carl
Jan 06, 2009 | Coleman Powermate Powermate 5000W...
Sep 17, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Electrical Supplies Logo
154 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
