Question about BenQ PB6100 Multimedia Projector
Ceiling-mounted benq projector giving upside down immage? how can i reposition the immage? thanx
    Scholar:
  • 146 Answers
It should be an option in the on screen menu to flip picture
all projectors have this as option
it will be under "source" and it is "mirror" setting
good luck
Posted on Mar 21, 2011
How to se benq mp623 screen upside down?
Very fixable - Go to your main menu (using your remote) and navigate to the option to flip the image. This feature is to accommodate projectors mounted upside down to the ceiling. Check your manual under general operation.
-GWOOD
Jul 14, 2014 | BenQ MP623 DLP Projector
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
Upside down picture
turn the projector up the other way,
or
Press the Menu button.
Select the Advanced menu. You see the features and their settings on the right side:
Press Enter and use the directional buttons and the Enter button to set the following option:
Projection
Front: Projector is in front of the screen
Front/Ceiling: Projector is in front of the screen, mounted upside-down from the ceiling
Rear: Projector is behind the screen
Rear/Ceiling: Projector is behind the screen, mounted upside-down from the ceiling
Feb 22, 2011 | Epson EMP-54 Multimedia Projector
The image from the InFocus is upside down. Do not have a users manual. thanx, mike
In the main menu, go to Settings, select System, and uncheck Ceiling (that setting is to allow it to be mounted upside down from a ceiling mount).
Aug 10, 2010 | InFocus X1a DLP Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
How can i flip the screen up side down on the projecter
Or you can hold down the [A/V Mute] button for about 5 seconds to change the projection setup from Front to Front/ceiling or Rear to Rear/Ceiling.
Mar 31, 2010 | Epson EMP-S4 LCD Projector
How do i mount my hopper projector sv 10 to the ceiling
Yes it should be mounted upside down as you would not want to see the bottom of the projector all the time, unless the bottom is as good looking as the top, which I doubt. I wonder if you bought or got a ceiling mount rack with it. First mount the rack on the ceiling and then fasten the projector to it. And before that its picture has to be turned upside down too.
Aug 11, 2009 | Philips Hopper SV20 Replacement Lamp -...
Settings on ViewSonic PJ513D Ceiling Mounting
The user's guide says for ceiling mounting,
"Set Front Ceiling in the System Setup: Basic > Projector Position menu after you turn the projector on."
The user's guide is on the CD included with the projector as a pdf file. You can also download the user's guide here:
http://www.viewsonic.com/assets/006/5619.pdf
If you find this solution gives you what you needed, please take a moment to rate it. Thanks for asking here!
Feb 22, 2009 | ViewSonic PJ513DB Projector
Angle of projected image
Hi there
No this can not be changed , the PB6100 was actually designed to mounted upside down in your ceiling and therefore the lens is 28-30 degrees upwards when projected on a flat surface.
Flip it upside down and you'll see what I'm getting at.
Oct 07, 2007 | BenQ PB6100 Multimedia Projector
BenQ PB6100 Multimedia Projector Logo
741 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
