Hotpoint ultima wt721. Cycle runs then stops at drain/pump out with alert code f - 05
    Brigadier General:
  • 6,277 Answers
Hotpoint (Indesit!) F05 decodes as 'pump block'.
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 21, 2011
Hotpoint Ultima WT721 F 08 fault code
Try the brushes first. I'm guessing the carbon deposits on the floor are from the brushes.
Nov 16, 2013 | Washing Machines
Hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Cycle ctopped and is flashing f 05
F05 means pressure jammed on full.
Check pump for blockage, or filter if waher has one.
Please rate my solution.
Thanks.
Jun 21, 2009 | Hotpoint Ultima WF865 Front Load Washer
Help with correcting fault code f-5
F-05 error means:-- Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
TO RESOLVE THE PROBLEM:--
Check the Water Temperature Sensor, Heating Element and Element Relay globul1a.gif Check connections to the Sensor, Heating Element and Relay
May 07, 2009 | Washing Machines
Machineflashinf f-05
F05 machine means "Pressure switch jammed"
Try first cutting power to the machine for two minutes, if that reset the code, then the problem was temporary.
If not :
Check if the machine drained, or if water is not being drained.
If drain system works .take off the the lid , locate the switch, it must have a small hose attached.
Remove the rubber hose attached to it, and unlock it by blowing into the hose.
If the water does not drain, this will also cause the pressure switch error.
In this case check the drain hose , and the drain pump.
Finally, ta faulty timer control board can cause the error, you test the control PCB if lid switch and drain system are OK.
Mar 09, 2009 | Hotpoint Ultima WD72 Front Load...
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code on display panel
F-12 is a drain problem.
Check if the drain hose is free, if cycle stops and gives you f12 without draining the water, there is a problem with the drain system.
The Hotpoint should have a removable paner at the back on the lower side. The panel gives access to the pump. If cleaning the drain hose does not solve the problem, the pump must be removed and cleaned or replaced.The repair should be done by a technician.
Dec 14, 2008 | Hotpoint Ultima WF865 Front Load Washer
F-05 error message on Hotpoint 860
i would say there is some thing wrong with the pump
Nov 22, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
