Question about Braun Tassimo Espresso Machine/Coffee Maker
My Tassimo maker is leaving water in the tea disc. Not fully making the tea.
4 Suggested Answers
SOURCE: All lights flash
Try cleaning the light sensor that reads the barcode on the disk. If it is dirty, some of the discs won't work. Also, try holding the water canister down with your hand while the coffee is brewing. If the canister vibrates, the lights may blink.
Posted on Apr 19, 2008
SOURCE: starts fine, but loses fizzle at the end
I had the exact same issue and was finally able to fix it today! The problem was the air pump was losing pressure and not pushing anything through the tube that's supposed to clean out the remaining water from a brewed disc. I didn't take any pictures, and the machine is already back together, so I'll just describe it the best I can. Every screw I had to remove was a T10 torx head. First, remove both silver plastic sides. To do this, remove the cup holder and the black plastic piece that the cup holder sits in. Also remove the water container from the back. Each side is held on with 4 screws, 2 in the front and 2 in the back. Remove those and take the sides off. Then you need to remove 4 more screws in order to take the top part off. 2 are on either side of the beverage disc holder, and 2 are in the back, halfway up the channel where the water container sits (facing down). Lift the top off, and you'll see a plastic, open topped gear case. That's the air pump assembly. Push the rubber strap that's over the top of it aside so you can lift the whole gear and motor mechanism out of its rubber holder (don't disconnect any tubes, just get it free from the rubber sleeve). Once you've done that, you need to remove the back of the plastic gear housing, which is just a piece of plastic clipped to the rest of the housing. You'll then see the rubber diaphragm that is the air pump. It's connected to the gears by a black piece of plastic sitting over the top of the gearing. You can slip that over the top of the gear and pull the diaphragm out. For the next step, I used petroleum jelly, but you can use whatever you think would work to help the rubber seal to the plastic and not let air leak out. Rub the edges of the rubber with the petroleum jelly (avoid the little flaps - you don't want those to stick to the plastic). That's it! Just reassemble everything and give it a shot. I was amazed that this worked as well as it did. It works like new now!
I hope this helps save some time and troubleshooting!
Posted on Jan 11, 2009
  • 4 Answers
SOURCE: every light blinks and it won't heat water
just posted this solution to another problem. there is something on the glass bar code reader up where you insert the t-disc - or the water vessel is not properly seated in the base of the coffee maker.
Check both.
Posted on Feb 05, 2010
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
All lights flash at same time-I need a descaling disc- do not have!
I found that my local appliance parts place (Reliable Parts) had them for about $7 each which was quite a bit less than ebay sellers and direct from Tassimo.
(Make sure yours is not hiding in its slot on the back of the machine.)_
Apr 04, 2014 | Braun Tassimo Espresso Machine/Coffee...
Tassimo - red water warning light stays on even with full water container
The floating indicator disc may be stuck down. Use a fork to work it back up.
Jun 26, 2012 | Braun Tassimo Espresso Machine/Coffee...
How to make ice tea , in the iced tea maker
Recipe for Ice Tea
1. Take one teaspoon of Tea
2. Bring a small saucepan of water to a boil. Pour ½ cup water over the tea leaves. Brew for 3 - 5 minutes. Add honey, stirring well.
3. Add enough ice so tea reaches the 1-cup mark. Fill 2 tall glasses with ice. Add ½ cup tea and several lemon slices to each and stir.
Feb 20, 2011 | Mr. Coffee Iced Tea Maker TM1S
My Tasssimo coffee maker is 11 months old and isnt functioning.
Possibly all you need is to clean off the bar code reader window. It's right under where the bar code on the t-disc ends up. A little dried milk, etc., can cause your symptom.
Dec 18, 2009 | Braun Tassimo Espresso Machine/Coffee...
Tassimo not fully dispensing the t-disk
I do not have experience with milk or chocolate, but for coffee and tea, at the end of a brew cycle, the green light should flip to the MANUAL light. For the next 30 seconds you have the option to press and hold the start button, to force more hot water through the pod into your cup. Give this a try to purge the pod of it's goodies!
Good luck.
Gazzer.
Dec 21, 2008 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo 3107 or 3701
Yessir, you need a t-disc to use it, because the machine reads the bar code that is imprinted on the aluminum lid of the t-disc to get instructions of how hot the water should be, and how much water should be used for the beverage you're qnting to prepare. no t-disc, no drink, no working machine. it's that simple.
Oct 23, 2008 | Braun Tassimo Espresso Machine/Coffee...
All lights flash
Feb 09, 2008 | Braun Tassimo Espresso Machine/Coffee...
Tassimo
Have you tried using bottled water? I had the same problem and found that Spring water tasted the best.
Jan 14, 2008 | Braun Tassimo Espresso Machine/Coffee...
Leaky Tassemo coffee maker
i think it's supposed to do that. the cup at the base is supposed to be catching all the water that the tassimo is 'leaking'. it should be dumped after every cup of tea/coffee. if you have taller cups, and do not use the cup base that comes with the machine in order to fit the taller cups under where the tea/coffee comes out, then you are right. it seems like it's 'leaking' because it is. there should be enough room in the base for one cup, but then it can also be removed so as to dump the excess water out after the cup is made. hope this helps!
Feb 03, 2007 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo Espresso Machine/Coffee Maker Logo
116 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
ellipse0904
Level 1 Expert
Jim Thurston
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
