Question about Briggs & Stratton Garden
I need a routing diagram for the drive belt of a Firestone Deluxe tiller to help me understand how to install a replacement drive belt.
PyroPCMan
  • 405 Answers
SOURCE: Drive Belt
1ab6618.jpg Fig. 29: Drive belt routing-1996-98 4.3L, 5.0L and 5.7L engines
Hope this helps
Posted on Jul 02, 2008
old marine
  • 2179 Answers
SOURCE: need routing diagram for 2000 lincoln town car serpentine belt
There's a diagram at this link.
Posted on May 11, 2009
Typus
  • 69 Answers
SOURCE: Roper tiller 26 inch front tine Pulley/belt diagram
I am not sure either, but I think that it would be alot cheeper to buy a new tiller, than to use your strenght fixing a old tiller that you didn't bother to keep the instructions for (no, I am not trying to be harsh. I am trying to be nice. and I am not sure about it coming with instructions, they usually do.)
29259605.jpgSorry, that is the closest picture that I can get.
Here is a link that may help. (IDK, because it is blocked where I am at.) http://www.google.com/aclk?sa=l&ai=CqcKEPGEMSvvXJJyotgeEiOyLB_jqoUWYtdrOBMib0rsYEAMoB1DU-N7X_P____8BYMmOo4qkpMQRoAGUt9H9A8gBAaoEIU_Q6ppHU85NtRLlGbCSz8M4YQ7k6yZkGAMPo_XJ9i4rSQ&num=3&sig=AGiWqtyvlB5FasgaU109ezFuPnc-65WzHg&q=http://www.fixya.com/support/roper%3Fcmpid%3DG3372595023
Posted on May 14, 2009
  • 112 Answers
SOURCE: How to install belt on Troy bilt tiller:
With engine OFF If you put belt on engine pully and driven pulley then work the clutch handle you should be able to see how belt goes so it tightens when clutch is worked.
Posted on Jul 16, 2009
mowerman1857
  • 389 Answers
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
Posted on Sep 18, 2009
I need a diagram for a 2011 dodge 2500 cummings serpentine belt.
Jeff, Check the attached links,instruction and guides, diagram for a serpentine belt, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amps Belt routing Installation and system start up for 6 7L Cummins
Serpentine Belt Routing
Drive belt routing
2011 dodge 6 7 cummins serpentine belt diagram Google Search
May 22, 2016 | 2011 Dodge Ram 2500
Drivebelt routing diagram for a troybilt pony lawn tractor
oh oh big trouble...make sure you installed correctly re check ever thing is there a twist in the belt? not riding true on idler pully? correct belt?is belt cutting into guard housing any where? is the belt making howling noise? use veernier caliper to check dimensions of old belt to new belt.I once x out a drive belt with a generic one that did the same thing. my solution dont buy cheap chinese belts stick to OME belts as the chinese ones may not fit as intended.
Jul 09, 2014 | Troy-Bilt Pony Garden Tiller
Replace belt lowes 211-406-062 tiller
Search for a belt routing diagram, I've had the same problem, thought I was going crazy
May 10, 2012 | Garden
I have a very old Wizard (Western Auto) Front Tine Rototiller Model gis 6990 A27 with power reverse. I am looking for a manual or a diagram of the drive belt routing. (Patent #2903077). Any assistance...
Hi and welcome to FixYa, I am Kelly
Here is a picture of the belts installed.
http://photos.cubfest.com/albums/userpics/10231/Belt_Routing.jpg
NOTE the front fwd direction drive belt / closest to the motor is installed like any other belt. The rear belt for REVERSE direction has 1/2 twist. The idler pulley presses in for foward driving and pulls out against the reverse drive belt.
This should be what you need.
Thanks for choosing FixYa,
Kelly
Jun 20, 2011 | Garden
Need to see belt route for gilson bros. tiller
You did not state if it was a front or rear tine tiller. This is for the front tine tiller:
The rear belt has a 1/2 twist in it for reverse. The front belt goes on nomally.
If this does not help you I would like a model number if you can locate it so I can get your the proper routing diagram.
Kelly
Apr 14, 2011 | Troy-Bilt Garden
How to install need diagram of timing belt replacement
2003 Mitsubishi Lancer 2.0L MFI 4cyl
Fig. Accessory drive belt routing-1.8L, 2.0L (SOHC), and 2.4L (4G69) engines
Fig. Accessory drive belt routing-2.0L (DOHC) engine
Fig. Accessory V-belt routing-Mitsubishi 1.5L, 1.6L, 1.8L, 2.0L and 2.4L engines
Hope helps (remember to rate this ansswewr).
Jan 05, 2011 | 2003 Mitsubishi Lancer
I need a diagram for a installing a serpintine belt in a 2005 toyota tacoma
Depends on engine. Copied below diagrams from AutoZone.com:
Drive Belt Routings
0996b43f80209580.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Accessory drive belt routing-2.4L engine
0996b43f80209581.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Accessory drive belt routing-2.7L (3RZ-FE/M) engine
0996b43f8020209e.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Accessory drive belt routing-2.7L (2TR-FE) engine
0996b43f80209582.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Accessory drive belt routing-3.4L engine
Aug 26, 2010 | 2005 Toyota Tacoma
Serpentine belt diagram/ installation?
Fig. Accessory drive belt routing-4.0L engine
Hope helps (remember rated this).
Jul 13, 2010 | 2005 Toyota Tacoma
Lookng for serpentine belt routing diagram for 1998 2.4 L sunfire
1998 Pontiac Sunfire Belt Routing Diagram
A drive belt routing diagram is needed when replacing a drive belt to help simplify the installation process. The problem arises as there are many different ways a drive belt can be configured. In this configuration the belt length will vary not allowing the belt to be installed. Also alternative configurations could turn a particular accessory the wrong direction, creating more problems. Always reinstall the drive belt in the exact configuration as the previous belt to prevent these problems. Always use high quality replacement products to avoid premature drive belt failure. If a multi rib drive belt fails it must be replaced immediately to avoid such situations such as engine overheating and loss of the power steering system. Whenever a belt replacement is required inspect the pulley condition to ensure there are no sharp edges on any of the pulleys, this will cause the belt to shred and fail. Confirm that all pulleys are free from debris such as small pebbles, these pebbles will cause the belt to pit and significantly impair the belt performance. The belt tensioner plays an important role to the drive belt performance, if this tensioner is weak it can allow the belt to lose tension allowing the belt to jump and skip. This condition will result in noises such as squeaking, chirping and ticking.
Hope helps (remember rated this help).
Jul 11, 2010 | 1998 Pontiac Sunfire
Serpentine belt replacement
2.0L Engines
See Figures 11, 12 and 13
The accessory drive belt for 2.0L engines has no provision for manual belt adjustment, since these engines use an automatic belt tensioner. Drive belt slack is taken up by the automatic tensioner.
Movement of the automatic tensioner assembly during engine operation is not a sign of a malfunctioning tensioner. This movement is the tensioner self-adjusting and is required to maintain constant belt tension.
The belt tensioner has a belt length indicator. If the indicator marks are not between the MIN and MAX marks, the belt must be replaced.
0900c1528008d836.jpgFig. 11: Drive belt routing-2.0L SOHC engine with A/C 0900c1528008d837.jpgFig. 12: Drive belt routing-2.0L SOHC engine without A/C 0900c1528008d838.jpgFig. 13: Drive belt routing-2.0L DOHC engine
Jul 24, 2008 | 1999 Ford Escort
Garden Logo
126 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
