Question about Sony PlayStation Portable (PSP) Console
All games cannot be read from the memory stick after adding some new games, what is the problem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 48 Answers
I take you have hacked your psp.
through some research i have found that psp; 1000 and 2000
are alot easyier to hack, however the psp3000 after hacking you can not switch your psp console off otherwise you will have you re-hack it.
if you have got a hacked psp with the hack still working then try formatiing your stick and trying again.
if you have the psp-go then i am sorry to inform you that i have no knowledge on that model. but i suggest you opening a new problem stating with greater detail
E.G. i have a psp go, i have tried putting games onto it via my datastick but they dont seem to being showing. what can i do to fix this?
i hope i havee been of some help. thanks.
Posted on Mar 22, 2011
Memory stick pro duo reading problem
Usually that means there is a problem with the memory stick itself. Try replacing or buying a new memory stick
May 09, 2010 | Sony PlayStation Portable (PSP) Console
Tip
How to "Format" your memory Stick on Sony PSP.
With Memory Sticks, SD etc, I recommend that every so often, regardless, and particularly, when you first buy a memory stick. You must reformat it on the Sony PSP. So that anything added by the memory stick manufacturer is removed, along with any hidden files you might have accidentally added.
You can format any size Memory Stick Duo in the Sony PSP by doing this:
  1. Push the little HOME button on the bottom left of the face of the unit.
  2. Use the arrow keys to move to the SETTINGS area, then move the up and down keys until you get to System Settings.
  3. Once you are there, click on the "X" button and scroll up and down as needed to find Format Memory Stick. Click on "X" again to select that option.
  4. The Sony PSP will now confirm that you want to reformat the memory stick (which removes every file and game save thereon, of course): choose yes and it'll format in just a few seconds.
Now you have a pristine new Memory Stick to work with and should have no problems with music, photos or other material you might wish to copy onto your PSP.
on Feb 12, 2010 | Video Game Consoles & Games
Memory card corrupted , cant retrieve saved games
Try a "Reformat" or your memory card. here's how.
I recommend that you do this every so often regardless, and particularly when you first buy a memory stick. Reformat it, on the Sony PSP. So that anything added by the memory stick manufacturer is removed, along with any hidden files you might have accidentally added.
Feb 12, 2010 | Sony PlayStation 2 (PS2) Console
Trying to put new hard drive.when it starts up it beeps 3 times and no picture on the monitor.is the power supply bad? originaly the hard drive crashed and the trying to reinstall it kept coming up error...
3 short beeps is a base 64K RAM failure
Remove added memory
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
  • Information about installing and adding new hardware including memory can be found on document CHADD.
Jan 31, 2010 | Gateway Computers & Internet
Did not boot and with 3 beep sound
Remove added memory
Replace memory
Aug 04, 2009 | Computers & Internet
Help?
You have to make an ISO folder and put the iso files inside that folder. It has to be in the root of your memory stick or else it won't work. It probably got deleted when you formatted the Memory Stick.
Jan 24, 2009 | Sony PlayStation Portable (PSP) Slim...
Reading "The Memory stick could not be read" 80010005/80020321
hi,
format it with windows: right click on your memory stick letter and format !
Dec 15, 2008 | Sony PlayStation Portable (PSP) Console
My computer crashes now and then... Tends to happen alot when im playing a pc game? It makes this loud screeching noise when it freezes i am forced to shutdown manually
Your Memory card is the problem.
Try this steps:
1. Remove added memory
2. Open computer and reseat memory
3. Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
4.Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer. If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Aug 25, 2008 | Computers & Internet
Psp memory stick
Yes, of course...the memory should be included in the package when it is brand new...
Aug 15, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
157 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
