Question about Whirlpool Dryers
Whirlpool dryer stopped heating Model - wed5500sq0
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.,.,.
Posted on Mar 21, 2011
Drum size for whirlpool wed55005Q0
This dryer is probably the WED5500SQ0. It's listed as a 6.5 cu. ft. capacity.
I hope this helps.
Sep 01, 2016 | Whirlpool Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
I HAVE A WHIRLPOOL DRYER MODEL LER4634PQO...IT WON'T STOP RUNNING WHEN IT GETS TO END OF CYCLE AND IT DOES NOT HEAT UP
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 10, 2011 | Whirlpool Dryers
My electric dryer will not start when I push the button. We have checked the breaker and there is power to the cord. What do we check next? Model WED5500SQ0
top load if so go to the back remove the plate follow the wires it should be one wire by it self hook to a white block look like ceramic replace it
Oct 15, 2010 | Whirlpool Dryers
Whirlpoo dryer WED5500SQ0 dryer won't turn on but timer still counts down
There can be many reasons why your dryer will not start orturn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 20, 2010 | Whirlpool Dryers
Heat only works for a minute and then the heat stops
There is a thermostat that regulates temperature. Your dryer MIGHT be overheating. Check your lint filter, vent, and vent hose for blockage first. If not, it might be time to replace the heating element.
May 18, 2009 | Whirlpool Dryers
Whirlpool accue temp dryer gets hot then heat shuts off
Sound like you need a new agnitor for your dryer take the model # to order part and install very carfully good luck
May 09, 2009 | Whirlpool LGQ8000JQ Gas Dryer
Dryer Not Heating
ive got same problem and engineer told me to buy a thermostat kit cheap and easy to do yourself.loads of sites sell these but i cant find one that matches to my model number.you might have more luck.
Sep 08, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
116 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
