Hi/fi i'd like a system with am/fm, single cd player with 2 spkrs in the room with 2 extension spkrs to carry the music to 2 other parts of the house. i could accept a 3 cd plyr. extension spkrs do not have to transmit stereo. suggestions? thank you
  • gewertz Aug 03, 2008
    your response failed to mention an amplifier to drive 4 spkrs, 2 local and 2 remote as stated in my original request. a boombox is out in left field and is totally non responsive.
  • 640 Answers
You could go with a home surrond sound system with satellite speakers.The 2 rear speakers are wireless and can be moved around.
Posted on Aug 03, 2008
    Genius:
  • 1,689 Answers
  • 19,396 Answers
A CD is stuck in my bose system How do I get it out?
From an other web site
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Oct 09, 2014 | Bose & Wave& Music System
Remote shows no response
I have just had a major problem trying to get the handheld (touch screen) music centre to communicate with the multi room interface. It took over a week to sort out by trial and error, but here is the solution :
1. Disconnect everything from the multi room interface apart from Room A and the CD player (blue connector).
2. Turn off the electricity supply at the wall (turning off any in line extension lead is not good enough - it needs to be at the wall socket). Leave turned off for at least 2/3 hours.
3. Turn back on and then leave it again for 2/3 hours.
4. Touch the music centre and you should find that it has now registered with the interface unit.
5. Connect the other rooms and input sources with the power switched on (contrary to instruction manual which advises you connect everything before powering up).
6. Test each input systematically as you connect them.
Hope this helps. I was on the verge of buying another multi room interface (I have 2 music centres and neither worked so assumed in was the interface at fault), at a cost of £200, so now glad I persevered with resetting the system !
Mar 03, 2014 | Bose LifeStyle 50 System
Sony audio docking system ipod PCB spare part
Do you know hqew.net? Know the pcb.hqew.net is the best PCB small batch customization supplier in China?
http://pcb.hqew.net/?s=544849
or
http://www.aliexpress.com/store/233890
Is custom PCB link
Jun 30, 2013 | Sony 100 watts Hi-Fi Audio Stereo Sound...
I have a Tivoli Music System radio/CD player. When it is moved to another room and plugged in at the new location, it won't run! The screen lights up a little, but has to sit for 30-40 minutes bef
The Tivoli Music System must be left without power for a minute (60 seconds or more) anytime it is unplugged, before being plugged in again. If you observe this little rule when changing rooms, it should turn on and be usable immediately (after ensuring it has been at least a minute since it was last connected to power.)
Nov 18, 2012 | Tivoli Digital AM/FM/CD Hi-Fi Music System...
Hello I have a Bose Wave music system-single cd capacity and a cd is stuck in it-I kept pressing "eject" as it was saying "disc error" it now says "no disc" even though the cd...
The Bose Wave System is top of the line and deserves a specialist, the Bose service department does all the repairs on their own products and carry the parts to implement such repairs. They do not authorize any other repair facilities to work on their items. I suggest you get in touch with them to assess your Bose Wave Music System.
Mar 14, 2011 | Bose Audio Players & Recorders
I have a small new Philips Music system which plays CD as well as FM. It is brought from Poland with a guarantee last month. The problem is that CD'S get stuck after about 25 minutes of playing. ...
Did you get a small piece of single wire with the system. That's the FM antenna. Connect that at the back of the music system labeled FM Ant: and it should solve your problem. Just check in the auto tune mode does the radio stop at the station number correctly and if the stereo indicator light up.
When the player gets stuck, if you put another CD will it play the new CD play for 25 minutes ?. If so try playing the last track of a CD after a cold start. It it does not play the last track on a cold start , you have some physical blockage/damage on the lens rail after half position.
Mar 07, 2011 | Philips Audio Players & Recorders
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Aiwa nsx k570
i need the circuit diagram for the CD player in NSX K 570 Aiwa 3 CD changer music system . I am Located in mumbai colaba. 9819890987
Mar 18, 2008 | Audio Players & Recorders
No sound from stereo
If you can hear a hiss then the spkrs and amp are OK. It sounds like you're not on whichever source you're wanting to hear or it is on mute. Make sure ther is no function enabled that turns the sound off or over-rides it (like a tape monitor or AUX in...).
Sep 09, 2007 | Aiwa NSX-DS55 CD Shelf System
108 people viewed this question
 Grubhead
Grubhead
