JVC tv screen shakes
My tv screen shakes violently after about an hour or so of being turned on ,why ?and how do i fix it ?
  • Anonymous Mar 30, 2014
  • Televison & ... Master
  • 1,689 Answers
This can be from the power supply section or from the some of the clocking circuits. This is not something you can fix at home. The obvious thing is that there are some components that have become thermo sensitive, and that is why the fault happens after the set is on for a while.
The factory service rep will fix the set by swapping out the defective boards for new ones. There is very little factory support, if any at all, for component level service on these boards.
Sometimes the fault may be a standard type generic part. But, this can take hours of work to locate, if in actual fact this is the case. The time spent just to find out may be worth more than having a defective board changed.
Jerry G.
Posted on Aug 03, 2008
My JVC 47" flat panel worked fine for over a year. Now, when I turn it on, It freezes with the introductory "JVC" screen and goes no further. The only way to turn it off is to remove the power plug. O
This is a common problem for JVC TVs, the problem is the EEPROM on the main board is damaged.
To fix it, is to replace the damaged EEPROM, if you could find one, or replace the main board
Oct 24, 2017 | Televison & Video
Shaking violently
ckeck your c.v. axles
Jun 15, 2012 | 2002 Saturn Sl
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
My brand new amana washer shakes violently when spinning
try adjusting the feet on the bottom of the washer the floor may not be level to adjust the legs turn them with a wrench or if the lock nuts are not tight turn the legs clockwise as you look at the front of the machine till all four feet are sung on all 4 corners. This is the most common problem. hope this helps and thanks for using fix-ya
Feb 15, 2010 | Washing Machines
Vertical lines appear on the screen.
It appears like there is a bad capacitor in the horizontal circuit. Try to put a fan near the ventilation trap, just for a test.
the part cost almost nothing but having someone to your house is expensive.
Your decision.
Jul 01, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
Screen on JVC TV distorted
There is an Aspect button on the Remote for the TV. This button will fix this problem.
Aspect function strectches the picture horizontally or vertically to get rid of black bars in some movies. Sometimes this is good....sometimes bad
May 19, 2009 | JVC Televison & Video
1993 Chevy S10, Hesitation in starting and shakes violently
check the fuel pressure regulator and see if it has a leak (common problem)
Apr 16, 2009 | 1993 Chevrolet S-10 Blazer
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
Violent shaking picture initially but slowly tapers off but still shakes
Do you have a service manual for your tv? If not I would suggest you get one because there could be several things causing this I will post a website whre not only can you get a manual for your tv but they also supply free online tech support to help you troubleshoot and fix your problem
May 06, 2008 | Toshiba 50H72 50" Rear Projection...
No picture
Fixed. As the saying goes, if it don't work, kick it. Well, I didn't kick it but I did shake it back and forth on the stand violently and viola', it works great now. I'm available for hire if you need my expertise.
Mar 31, 2008 | Toshiba 36A60 36" TV
Televison & Video Logo
185 people viewed this question
Top Televison & Video Experts
