Question about Klipsch Image S4 Headphones
The left earphone has stopped working. There seems to be no external damage to the headphone or wires.
Earphone-only left earphone works... how can u repair right earphone
Rotating the jack or twisting the wire joint on the headset might work.
Nov 09, 2012 | Bose Around Ear Headphones Earphones
I found some pretty cool earphones... they are puregears purebeats headphones set. When I found them, the right earbud wouldn't make a sound unless I jiggled the wire by the speaker. And the left one...
The thin wire used in the leads breaks internally and there is no easy way to fix them, you could try to fit another cable to them but it is usually not very successful. Replacement is about the only option.
Mar 02, 2012 | Audio Players & Recorders
My right ear bud wont work after like 3 weeks. i was wondering if i broke anything
I have done some research on damaging earphones and it seems to me as if you have been pulling the earphones off in an incorrect way which may put strain on the place where the wire and the right phone meet.
Thus you may have accidentally pulled the wire out of the socket slightly. I doubt you will be able to fix what has happened.
Mar 12, 2011 | Skull Candy S2INBT Headphones
External speakers are working but headphones/earphones are not working on my computer
Maybe the headphone connector is broken. If that is correct you need to replace the motherboard. If you had connected the earphone and accidentally received a tug on the cable perhaps the earphone connector was damage.
Nov 18, 2010 | Computers & Internet
I have Seinheiser HD 202 headphones that my dad bought me for Christmas about a year ago. About a few months ago the left earphone stopped working. I have tried messing with the jack but that didn't seem...
The fault is in the cable: you will have to dismantle the left speaker housing and start cutting from the cable until the break is removed then solder it back to the speaker - use an multimeter to check the continuity of the wires.
Oct 10, 2010 | Sennheiser HD 202 Consumer Headphones
The right earphone on my headphones stopped making noise yesterday. There is no volume coming out of it at all and right now i am listening out of my left ear only. I was able to fix the problem by pulling...
if you are techy or have a knowldge in connecting wire, then you can give a try to fix the right portion of your headphones. There was just a wire inside of your earphone which have been cut. For some instance maybe you had pull your headphones thats why the wire inside has been cut. If you can't repair then that's the time you'll need to buy.
May 26, 2010 | Sony Clip-On Style Stereo Headphones
One earphone stopped working
not thrased jus yet wire in casing came lose needs to be resaudered
May 13, 2010 | JVC Gumy Ear Bud Headphone - Peppermint...
How do you Fix earphone?
It could be the wire is broken inside, or more likely the jack is not fitting into the plug as well as it did when new. Have you tried it in another device to see if it works there?
Mar 25, 2010 | JVC HA-FX66A Consumer Headphones
Klipsch Image S4 Headphones Logo
680 people viewed this question
Top Klipsch Audio Players & Recorders Experts
Sock Puppet
rhodesworks
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
