Question about ASUS K8V-MX Motherboard
My disply is not carrect what can i do - ASUS K8V-MX Motherboard
  • David Petry Mar 21, 2011
    What is yur operating system and ar you using onboard graphics and/or a graphics card? If you're sing a graphics card could you provide manufacturerand model?
  • ASUS Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
also
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Posted on Mar 21, 2011
I purchased a cadex watch from you which is not working carrectly
This is the Fixya.com site, which does not sell watches, so you have posted to the wrong website, sorry.
Nov 05, 2016 | Watches
My cpu is front light on but not go to disply powr fan is ok runing but not show the disply plz help me any on
check the display monitor cord to CPU if attached perfectly/check on off switch of display screen
Feb 23, 2015 | Computers & Internet
Gigaset a495 showing Register HS, and i cant making call.. plz give me a solution
gigaser A495 Handset ,
Actualy one problem may Handset Disply not work,Pls reply how to work in incoming and disply screen number.
Aug 18, 2012 | Siemens Gigaset A495 Cordless Phone
My 5130 mobile disply damaged now its displying vertical and reversible letter displying what i do my mobile warrenty is over
when i turn on my fone, the screen remains blank but i am still able to press buttons into it. can you help?
Oct 03, 2010 | Nokia 5130 Cellular Phone
Delete divert on disply
use ##002# to cancell all divert. This will work only in GSM networks.
Oct 13, 2009 | Cell Phones
Error code 001. On/off switch trips off after 10 seconds
when you open the front door you,ll find under the disply a smal hole put eny nail in it a doller sign will apeer in the upper left corner of the disply pres
star , 4,star you will see another disply press the right arrow till you find error word press on it and then press star (astresk. the disply will turn off and on again theis error might be from the heater lamp if
it comes again change the hamps
May 08, 2009 | Canon NP 6545 Copier
Error messege
Check paper out switch behind tractor assembly. It may be bent and also make sure that the green bar (if used) is installed carrectly between the tractors.
Jan 05, 2009 | Tally T6218 Matrix Printer
I changed the battery and now the computer won't "reset"
Did you change the Batt right before the emissions test? If so bad idea. Yes the car needs to be driven for some time before the computer sets up timing fuel and spark carrectly. Drive some more then try the test again, should be ok and pass
Dec 28, 2008 | 1997 Nissan Sentra
ASUS K8V-MX Motherboard Logo
24 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
