Question about Bowflex Selecttech Dumbbells
A small srew has fallen out off of the ********, however the piece that it was screwed into still remains inside the ********. I called bowflex and they advised me to buy a whole new ******** which I think is ridiculous since this one still works perfectly fine. The only issue is that the other piece that was attached to the srew that fell out is rattling around inside. My question is do you think I can just remove the remaining three screws to pull apart the dumbbbell in order to retreive that small loose piece in order to reinsert it back into place. Or do you think once its apart it will be to difficult to put back together in perfect working condition. Its seams to be simple but i dont want to make it worse?
  • 95 Answers
I am not the person to give you advice on fixing your ******** yourself but I did want to give you a link where you can look at a Bowflex SelectTech diagram in case that helps you think about taking it apart or putting it together. You can zoom in to view all the different parts. (If that's not the right one here is version 2). They also have individual parts for sale which may be better than buying a whole new one.
Posted on Mar 21, 2011
Key will not go in ignition
Wrong key?.....ha. No, sounds like the tumblers inside the ignition have "fallen". Try lifting the small pieces of metal inside the ignition with a paperclip or something similar. If you can move any of the pieces inside then you need an ignition. You may even be able to insert the key with the piece lifted. "very delicate".
Dec 05, 2010 | Chevrolet Venture Cars & Trucks
My canon powershot A640 wont turn on despite having new batteries installed, also the USB connector socket has fallen inside the camera, will this cause a short that will stop it powering
Yes, you are probably right. A short within the camera could make it "un-startable. Take it to a local electronist or a Canon dealer and they will help you solve this problem. Also check if the batteries are good and fully charged. Some new batteries could be faulty from the factory.
Apr 07, 2010 | Canon PowerShot A640 Digital Camera
Water goes down into washer, but does not seem to
Well if this is a front loading GE and it has a pump similar to the Frigidaire Models (who knows who makes what for whom) there is a check valve that closes on the pump where the hose connects to the drain hose if this has fallen apart or off the pump will allow the water to drain into the hose rather than staying in the wash tub without knowing the model number it is difficult to be certain of this. If yours has the small access panel on the front with two screws at the bottom most likely the pump check flap (small piece of rubber on the pump outlet) is probably shot. Only other thing is to make sure the drain hose has not changed position and causing siphoning of the wash tub.
Mar 02, 2010 | GE Washing Machines
What holds the 3 pin connector in the bottom of a shure bets 58? it won't stay in...How do I secure it?
there is a small screw in the side of the xlr connector and a small hole in the body of the mic.put everything together until you see the screw thru the small hole.tighten the screw clockwise and the job done!
Jan 06, 2010 | Shure Beta 58A Professional Microphone
I have bowflex extreme 2. Power rods hit the pulley arms when bent.
I called Bowflex and they said there is a Lower Lat Tower Upgrade (Part 001-9704) that fixes the problem for $106.10. Seems like a design defect to me, not an upgrade. Regardless, I have not purchased the part yet to see if it fixes the problem.
Nov 30, 2009 | Bowflex Xtreme 2 Se Gym
How to fix a fallen felt strip inside advent 6552
Yes, most laptops have 4 small screws on the front of the screen. They are hiding under small pieces of rubber. once removed , they screen pops off. You have to be careful and not to break the screen, so, be gentle with it. you can always consult your user
manual for addtional info how to remove the screen. or you can download the manual from their website if you don't have the manual...
Let me know if this helps.
Apr 10, 2009 | Computers & Internet
Won't fit through door - taking it apart
remove the 3 screws in the arm trim cover and the harness unplugs there and the other wires are screwed to the frame right there. Philips head screws.
Mar 20, 2009 | Bowflex Treadmill Series 7
1991 front speaker replacement
ok, i don't have pictures but i'll see if i can help. usually the covers over the speakers either have two srews holding them down or they just need a flat screwdriver to pry them up. if they have srews, you'll need a very small screwdriver to fit in between the window and speaker cover. some screws are star screws which need special star tool to get out. but most are philips screws. if you can get the covers off, you'll see the speakers, now you'll just need to take the two screws holding them down, out.pull the speaker up and out, unhook the wires and replace them. if you have the kind of covers that just pry off, just be careful not to hit the glass, i put up a piece of cardboard to be safe..i hope this helps you.
Nov 28, 2008 | 1991 Toyota Corolla
Loose Focus ring assembly
IF YOU TAKE A LOOK AROUND THE FRONT OF YOUR CAMERA THERE ARE SEVERAL SCREWS, ABOUT 4 I THINK,
1) 1 ON BASE
2) 1 ON THE LEFT LOOKING AT FROM THE FRONT
3) AND 2 INSIDE THE FLASH CASE
REMOVE THESE SCREWS AND THEN YOUR FOCUS RING AND SOME OF THE CASE SHOULD COME OFF
INSIDE THE FOCUS RING YOU SHOULD SEE 3 SREWS IF NOT CHECK THE CAMERA TO SEE IF THEY HAVE FALLEN INSIDE,
IF NO JOY YOU CAN REPLACE THE 3 MISSING SCREWS AND PUT IT ALL BACK TOGETHER
SWEET
DAVOS69
HOPE YOU DONT MIND BAD SPELLLLLING.........
Aug 25, 2006 | Sony Handycam DCR-TRV30 Mini DV Digital...
Bowflex Selecttech Dumbbells Logo
512 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Paul Carew
ray gallant
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
