Question about Arris SURFboard® SB5101 Cable Modem
Just had cable Internet installed and have had problems with it disconnecting every night at the same time, SB5101N Motorola. I have a wireless router, Belkin F5D8236-4, and was previously hooked up to my DSL. When this problem happens, the modem light on the router is flashing orange. I will then disconnect the router and plug my laptop directly into the cable modem. reboot both and cannot get on the internet. All lights on the modem seem correct, all solid except pc/activity which is flashing green. By the time, usually 7:30 to 9:00, and Charter, my ISP, can check it, they state that all is working fine. My question is, is there something wrong with the router, even though I cannot connect when directly plugged in? Is there something wrong with the modem rj45 plug? Is there a setting in my router, dynamic something, that changes after a period of time. I have changed it, but still cannot connect when directly plugged in? Sorry about the long post, tired of dealing with Charter. I know enough to be dangerous, so any ideas would be appreciated!
    Scholar:
  • 60 Answers
As long as your laptop doesn't have a firewall enabled then you should almost always be able to get connected by directly connecting your unit to the router.
Here is how to Determine if you Windows Firewall is enabled
Once it is disabled try resetting your Belkin back to Factory default Settings.
If all that still doesn't work I would attempt attaching it to the modem, and know once and for all if you router is working correctly.
Hope this help, and if it did please remember to leave Feedback/Testimonial. Thanks.
Posted on Mar 21, 2011
  • 3 more comments
  • dtman02 Mar 21, 2011
    Have tried those things previously and no resolve. If I connect to the modem directly, i will not have internet. After 9:00 I will get low rates, 2.0 to 3.1, then off to the races, 11.0 to 19.0.
    It is just odd that it has happened every night, 4, that we have had it installed.
  • Dane Andreasen
    Dane Andreasen Mar 21, 2011
    When ever you have cable internet you are, what I like to call, "Slave to the Swarm.". Meaning your rate is determined by how much your neighbors/town is using it.
  • Dane Andreasen
    To me is sounds like Charter needs to come out and check your internet's signal strength, Its possible it is too low and could need to be amplified. A lot of the time they will just attach another splitter and then attach the modem to it, but they need to put the modem as close to the Line-In(the initial cable coming into the house) as possible. This way you get the clearest route to the i-net, because there is less "middle men" to interfere.
    Thanks
  • Dane Andreasen
    Not a problem. if this help please leave Feedback/Testimonial.
    Thanks.
    Have a Good Day. :)
Slow computing speed with SB5101N
You should buy a new router basing on your broadband network. even though you have a high speed network you cant browse fastly without a good router
May 08, 2012 | Arris SURFboard SB5101 Cable Modem
I can't find my WEP Key for the SB5101N Router. I tried the numbers located on the router itself, none of them have worked.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 14, 2011 | Arris SURFboard® SB5101 Cable Modem
I have tried everything, i tried the command ipconfig renew but it doesnt show nothing, the modem (motorola sb5101n) has all the lights on and the pc activity blinks like everything should be working, but...
This could be a couple different things. One it could be the IPV6, if so disable it and it will work. If not then it also could be your antivirus blocking the connection (which i would check first) or it could be the vista IP configuration flag causing it which you would need to follow http://support.microsoft.com/kb/928233
Mar 27, 2011 | Arris SURFboard SB5101 Cable Modem
How to reset my password and id on my motorola sbg901
Number three is the reset button, then it will be default, which is all listed below.
Manual Configuration:
Step 1:
Directly connect your computer to the Motorola SBG901 cable modem via an Ethernet cable. This is needed as enabling security will disconnect the wireless connection until wireless on the computer is properly configured.
Step 2:
Open up your web browser (Example: Internet Explorer) and enter the following URL:
* http://192.168.0.1
Step 3:
This will bring you to the cable modem login screen. Enter the following information:
* Username (all lowercase): admin
* Password (all lowercase): motorola
Dec 28, 2010 | Computers & Internet
I wanted to know what is the best wireless router compatible with motorolla SBV5120 cable modem? thank you very much
The Motorola SB5120 SURFboard® is a very popular, solid and reliable cable modem compatible with most cable providers. If your modem is two years or older, upgrading to the SB5120 has been known to show speed improvements up to 3X faster than older DOCSIS 1.0 modems. Set up is simple and fast.
  • Compact design: With its attractive and compact design, this cable modem won't clutter up your work space
  • Easy to maintain: Simplify troubleshooting with the handy font-panel LEDs and built-in HTML-based diagnostics
  • Stand-by switch: Disconnect the signal without unplugging the modem with the top-mounted stand-by switch
  • DOCSIS™ 2.0: Take advantage of DOCSIS 2.0 technology for up to three times greater upstream capabilities than older modems running on DOCSIS 1.1
Linksys BEFCMU10
Quick to set up at a great price, the Linksys BEFCMU10 offers fast connections to your cable broadband provider. Connect it directly to any PC with an available USB or Ethernet port, and you're ready to surf the Internet. With the Linksys Cable Modem, you'll avoid monthly rent charges, and make the most of your high-speed cable Internet connection.
  • Compliant with all industry standards: DOCSIS™ 1.0, 1.1, and 2.0 - compatible with any cable Internet provider
  • Ports: Ethernet, USB & Cable
  • Buttons: Reset
  • LED Indicators: Power, Internet Cable, Internet Activity, Ethernet & USB
  • Easy installation: One phone call to your Internet service provider completes the setup
D-Link DCM-202
D-Link's DCM-202 Cable Modem is powered by TurboDOX™ bandwidth acceleration software increasing your download speeds up to 20 times. The DCM-202 makes your broadband connection more efficient and effective by clearing network congestion, resulting in a boost in download speeds. With the DCM-202, you will get more out of your broadband connection with increased bandwidth and enhanced performance.
  • Always On, Always Connected
  • DOCSIS™ 2.0 Certified
  • Ethernet or USB Connectivity
Netgear WGT624 Super G 108 Mbps Wireless Router Netgear's WGT624 108 Mbps Wireless Firewall Router is 10 times faster than 802.11b routers providing 4x the range of 802.11b devices, and double the range of most other 802.11g products. Your home network is secure with over 10 security and privacy features including a double firewall and wireless encryption. Netgear's Smart Wizard set up software gets you connected in 5 clicks or less!
  • Interoperable with existing 802.11b and 802.11g networks
  • Smart Wizard gets you up and running in fewer than five clicks
  • Lighted power, test, Internet, wireless and LAN status icons
  • Works with most Internet gaming applications that support Universal Plug and Play
Dec 12, 2010 | Computers & Internet
Can I use a wireless router with motorola phone tools. What I want to do is to connect phone tools on a desktop and then add a wireless router (USB) so I can get wireless internet on my laptop.
Your question is somewhat confusing.
For clarification, there are two questions that you could be asking.
The first question would be: Can your phone be 'Tethered' to your laptop with either a Data Cable or Bluetooth to have internet on your laptop by using your phone as a modem? (No wireless router is needed to do this.)
The second question would be, that you have an internet connection on your desktop computer and want to use a wireless router to have internet on your laptop via WiFi. (In this case, your cell phone would not be needed.)
If the first question is what you are asking, to use your cell phone as a modem to provide internet access to your laptop - then the answer is, Yes. This is what you will need:
1) You'll need a Data Plan added to your regular cell phone service account.
2) To tether your laptop to your phone, your laptop will need to have either Bluetooth installed or you will need a USB Data cable.
Tip: If your laptop does not have Bluetooth installed, you can purchase any USB Bluetooth Doggle (on eBay for a couple of dollars) and plug it into one of the USB ports on your computer. Once plugged in, the doggle will automatically download the Bluetooth drivers to your laptop. Otherwise, you can use a USB Data cable to tether your phone to your laptop.
Note: Depending on the model number of your Motorola phone you may have to download the Data Cable Drivers onto your laptop.
If your phone is not one of the following phones then you can use Motorola Phone Tools. (Motorola OS, Motorola Linux OS, Motorola iDEN, Motorola Symbian/UIQ, Motorola Windows Mobile and Motorola i-mode Handsets. )
If you need the Motorola Phone tools (if your Motorola Phone Model was NOT one of the models I listed above)
Just click here::
http://bit.ly/1TN7A6
If your phone model is a (Motorola OS, Motorola Linux OS, Motorola iDEN, Motorola Symbian/UIQ, Motorola Windows Mobile or Motorola i-mode Handsets), you'll need to download the drivers for the Data Cable and install them on your laptop.
Click here:
Since you did not include which cellular provider you use, I cannot provide you with the information to manually set up your cellular internet connection.
Now, if the second question is the one you are asking, that you have internet on your desktop and want to use a wireless router to get internet on your laptop, here's what you'll need:
1) Connect a wireless router to your desktop.
2) Your laptop should have a small WiFi switch or button on the front or side of your laptop. This will need to be turned 'ON". (See your owners manual for your laptop to do this.)
If your laptop has WiFi installed, on your laptop go to START > (Look on the right side of the menu box and click on: 'Connect to' -- If you don't see, 'Connect to' in the menu you'll have to purchase a USB WiFi adapter. A good one is a D-Link DWL-G132 and can be purchased on eBay for about $10. Install the drivers for it first before plugging it in to your computer.
Click here to download the DWL-G132 drivers:
ftp://ftp.dlink.com/Wireless/dwlg132/Driver/dwlG132_drivers_130.zip
Once you download the drivers and plug in the DWL-G132 into one of your laptop's USB ports then click, START > Connect to > and select your wireless router.
May 30, 2009 | Motorola Mobility Mobile PhoneTools...
Can I use my router just as a Wireless router with a DSL .
i doubt it will work. most times the cable companies give you a modem/router all in one box. the problem is there in no inbound connection to recieve an internet signal other than the cable cord connection. with the dsl modem you will need a seperate router. they cost around $40-50 on avg
Feb 05, 2009 | Arris SURFboard SBG900 Wireless Router...
Cant get motorola wr850g to see time warner cable modem
I had same problem and what i did is i restarted the device and i installed it to the cp again you probably did something wrong
Aug 14, 2008 | Arris Wireless G Broadband Router (wr850g)
Connecting to internet
i am connected and signal strength is strong but i still cannot get on the interned (time-warner cable)
"dsl server error"
Aug 06, 2008 | Arris Wireless G Broadband Router (wr850g)
Downloading Problem with Motorola SBG900 Wireless Cable Modem Gateway
Sounds like your laptop is hit with spyware and or viruses. Try starting it in safe mode (F8) and seeing if you still have this problem. If it works in safe mode go to grisoft.com and download the antimalware free trial. Restart in normal mode and install and run the trial version.
Aug 05, 2007 | Arris SBG1000 Wireless Cable Modem Gateway...
Arris SURFboard® SB5101 Cable Modem Logo
613 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Jerry
Jerry
Greg Ulan
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
