Question about Poulan Garden
Poulan Leaf blower. Fuel Lines. Need both line sizes, and schematic on what line to run to bulb and other to carb. Will run for a second if I spray carb starter into carb, but seems to starve for fuel. I thnak you in advance..jim
boscia
  • 163 Answers
SOURCE: Poulan leaf blower wont start
try changing the spark plug. if that doesnt work let me know and i'll help you trouble shoot it.
Posted on Nov 30, 2008
  • 211 Answers
SOURCE: leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Posted on Dec 05, 2008
#1 Taper
  • 1041 Answers
SOURCE: wont start, not getting fuel, checked lines,carb and used starter fluid, runs but won't continue to run
You may need to do a more detailed cleaning on the carburetor. I like to use a Den Tek Brush, (used for cleaning teeth), to get into the small ports. They work great for this job. You may also need to check the small screen in carb. It gets blocked with debris.If you need further assistance, please contact me.
Jim
Posted on May 25, 2009
#1 Taper
  • 1041 Answers
SOURCE: poulan pro leaf blower doesn't start
As long as it has fire, all you need to do is:
Check the fuel lines for cracks/breaks. If this is o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure the small screen in carb. is free of debris.
If you still have trouble after this, then you will need to buy a carb. kit and replace all appropriate parts.
Jim
Posted on Jun 09, 2009
#1 Taper
  • 1041 Answers
SOURCE: where does the fuel line with filter go on the carb?
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 20, 2009
My poulan pro bvm210vs blower wouldnt start. Changed fuel lines, fuel filter, and cleaned carb. Now, fuel bulb will only prime when unit is on its side. It then will start, run10 seconds and die
Sounds like you made the Fuel line in the tank too short . OR the stone filter on the fuel line is not able to move about the Fuel tank to follow the fuel
May 06, 2015 | Poulan Garden
Need to replace both fuel lines on My BVM200 LE leaf blower, 1 large and 1 small fuel line, can You tell what size they are??
On your blower, it looks like the small line supplies fuel to the carburator which will be connected to the fuel filter in the tank, and the large line looks like the fuel return line.
http://www.ereplacementparts.com/poulan-type-gas-blower-parts-c-16962_31724_131359.html
Jul 19, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
What's the easiest way to change a fuel line in a poulan weedeater blower?
remove old lines with new, try inserting the lines from the fuel tank. this will take some time. connect the fuel filter to the end of the pick up line. pull the line until the filter rest on the bottom of the tank. pull both lines trim to size and attach to primer bulb and then to carb.
Oct 20, 2009 | Poulan Garden
Poulan leaf blower won't start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Sep 26, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Which lines hook to what?
Fuel filter to bottom of carb. The suction port of primer to the top of carb outlet line to other port to tank.
To tell which port is outlet put your finger on one port and push bulb if the bulb collapses and doesn't return then that is the inlet (suction) side.
Aug 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Won't stay running
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Jim
Jun 25, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Where does the fuel line with filter go on the carb?
Jim
Jun 19, 2009 | Poulan Garden
Poulan pro leaf blower doesn't start
Jim
Jun 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Mccolluch airstream V back pack blower fuel lines
The short one goes to the primer bulb and the long one, with the filter, goes to the carb.
Jim
Jun 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
345 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
