Question about D-Link AirPlus DI-614+ Wireless Router
I can connect to my di-614+ through wireless connection but i don't have internet access
    Problem Solver:
  • 5 Answers
Sounds like the router and modem arent talking what kind of internet connection are you using and have to tried accessing the internet with the ethernet cord that runs from the modem to your computer. if you cant access the internet with that direct connection to the modem you might have a bigger issue
Posted on Mar 21, 2011
  • 171 Answers
SOURCE: DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Posted on Jan 25, 2008
SOURCE: Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Posted on Jan 30, 2008
SirHanz
  • 145 Answers
SOURCE: D-Link DI-524 4 Port connection Problem.
Perhaps the router is not broadcasting its SSID, therefore is invisible to would be tappers. Type 192.168.0.1 into a browser on a computer directly wired to the router, leave the username blank, if you havent changed it, the password is admin by default. Once logged in check that wireless is enabled and that you are broadcasting the ssid, you may want to setup/change security settings for the wireless connection at this time also.
Posted on Feb 11, 2008
Teis
  • 340 Answers
SOURCE: di-524 dlink; wireless laptop connects but no internet or network
Your wireless card is dead, replace.
Posted on Nov 23, 2008
RickOz
  • 145 Answers
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Posted on Apr 10, 2009
Password protect wireless access
You'll need to access the administrator web page for your router, and then set a security key (password) for wireless users.
For step-by-step instructions for setting up security on the D-Link DI-614 router, see:
http://technicallyeasy.net/2010/10/how-to-secure-d-link-di-614-wireless-router/
Sep 04, 2012 | D-Link 2.4GHz Wireless Router DI-614
How (or whether) to configure dlink 614 as a wireless access poin
go to this link and read the manual.
You may require a firmware upgrade also.
Thanks
Please rate the answer if it was helpful to u
Good Luck
Jun 23, 2009 | D-Link AirPlus DI-614+ Wireless Router
How to lock my router so neghbours cant connect
Follow the instructions on this D-Link page (it shows DI-614, but it is the same procedure for your model):
http://support.dlink.com/faq/view.asp?prod_id=1055
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 26, 2009 | D-Link DI 514 Wireless Router (DI-514)
Modem and wireless not talking
If u r inside a wireless network and internet is ok, u will able to ping both the wireless router gateway and modem gateway. If u cant ping the modem gateway, u can try connect the modem directly to your pc, and test again. U need to make sure the modem is OK, and able to connect to internet. Then only u move to check router. This is due to very often internet access having problem.
Mar 10, 2009 | D-Link DI 514 Wireless Router (DI-514)
DI 524 and airport express
Yes, that is possible for as long the DI524 is already properly setup and can provide already internet connection everything should be working fine there....
Nov 10, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-614 router works sometimes
hi ,
there is surely a way of doing that and the way is to open the routers page while connected to the router with the help of an ethernet cable .
but i would rather suggest to reset the router and then start again ... with this u can upload a new firmware for router as well ....
moreover u will be able to do all the settings on the router again ....
Oct 28, 2008 | D-Link AirPlus DI-614+ Wireless Router
Wireless not working properly
Can you detect the wireless network name?
Oct 04, 2008 | D-Link AirPlus DI-614+ Wireless Router
D-Link 614 Plus
You need to do some reconfiguration on your router by using the setup cd or by manually configuring it using the user interface of the router.
Apr 05, 2008 | D-Link DI 514 Wireless Router (DI-514)
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-614+ Wireless Router Logo
91 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
