Model no 29AZ71X is getting switched off intermittently even though power supply is there. I have to swich off the main and switch on after 40 seconds. I am unable to find out the mistake.
  • 42 Answers
Sounds to me like one of the components on the main power supply board is faulty. Check for any of the capacitors that have mushroomed up. The capacitors look like little cylinders coming out of the board. If you do see one with a domed top, than the cap is bad - replace it. That does take some soldering, but the parts are normally fairly cheap ( $5-10 ) per capacitor. Hope this helps
Posted on Mar 21, 2011
Switches itself on and off intermittently
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Apr 17, 2016 | Samsung Televison & Video
What is the most likely cause of a power up problem with this TV
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Feb 22, 2015 | Televison & Video
My TEAC LED TV LE 4087FHD turns on intermittently.I need to turn power off and on several times for the tv to switch on. Any suggestions?
SMPS start voltage problem. Check all the reisistors; that supply the initial voltage to SMPS control section; at switch ON. Contact any service technician.
Nov 30, 2014 | Teac Televison & Video
I have 2 lights in the midle of the room single swich I would like to install a second swich in a different position thank You in anticipation Pat Tavani
You must have two wires connection between two switch. Power supply (hot wire) must going to first switch. It is like you have one road. Then you have 'crossroads' and two wire. It is going to another switch. There is another 'crossroads' on that switch and two path became one road (electric). After that switch your wire going to bulb. Of course, second connection of bulb going to power supply (not hot wire). Switches gas one middle (main) point and two output. It has three connection (like road crossroad with main road and two way from it). It look like this:
F o-----------==========----------------
I
O
I
N o-----------------------------------------------
Aug 25, 2011 | Hardware & Accessories
26la30q wont turn on
Hi
You have to start checkin from its main ON/OFF switch itself. If the switch have any contact contact trouble, the set will not turn On, even though you hear the click sound from the switch. If switch is Ok, then you have to come to the power supply regulator board. It can be easly recogonized the powe supply regulator boad. The main supply line will go straight to it. There will be more that 5 or mor secondary voltages from it, according to Tv model. These secondary wupplies will energzed only after the power supply switching circuit work properly.
Ther is a fuse [ a cartridge type; replaceable]. Check the fuse first. If it has blown; be carefull when you replace it; because there must be some reason for the blowing of that fuse. It is really a protection device. Before replacing it, you have to check the entire power supply board for some short circuit. If you have sound knoledge in repairing Switched Mode Power Supply [SMPS]; just proceed. Otherwise get it repaired by any experienced service technican or by authorised service center for Proscan. OK.
Jul 08, 2011 | Proscan 26LA30Q 26 in. LCD Television
I have anew Sony 40 inch EX 520 series Led warranty not valid in India since purchased in Bangkok. The power standby light goes of very often and the Tv goes dead. If I switch off the power supply for...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 15, 2017 | Televison & Video
My sanyo tv model CE32LD81-B is currently on standby but i cant switch it on with or without a remote i think it may have been blocked
I think it has a power supply fault. The standby power supply is a small, separate supply from the main power supply.
I hope that helps.
Mar 10, 2011 | Televison & Video
Unit will not turn on
I realized your problem. i think the problem is the main board of your unit. pls spicify the model and brnd.
Nov 16, 2007 | E-Machines Emachine T5026 power supply **...
Monitor turn on &off intermittently
there is a loose contact in power supply. 1 check for plug or socket loose 2 switch intermittent 3 fuse loose. 4 any connector loose. 5 any component in oscillator looseor print break. 6 swiching transistor print loose. 7 main filter capacitor loose or dry. hope this will help.
Oct 08, 2007 | LG Studioworks 563N 15" CRT Monitor
Sansui LCDTV 40 inch goes Off automatically
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 10, 2017 | Sansui HDLCD-3700 37 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
