Need replacement transformer SK-U48120-11 but can't find specs anywhere
  • Rielle Burst Mar 21, 2011
    Who is the maker of your product?
3 Suggested Answers
robotek
  • 1512 Answers
SOURCE: blown power transformer
Hi
What has happened to the transformer. Does it have an open circuit primary?  Get back to me if you want a fix.
regards robotek
Posted on Dec 19, 2008
gopakumarg43
  • 75581 Answers
SOURCE: Need the specs for or an SK-U48120-11 transformer
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
Site is listed with Google. You can locate it either at the bottom part of first search page, or at the top of second page.
Sometimes, one among the advertisements by the side and bottom of each post might help you to get details about the availability of spare parts and other components.
Posted on Jun 02, 2012
Westinghouse SK-32H240S has no picture.
yes there is something wrong with the board
Aug 03, 2012 | Westinghouse SK-32H240S Television
Westinghouse SK-32H240S no backlight
The voltage source to back light inverteres are from the main power supply regulator board. Check it.
Jul 20, 2012 | Westinghouse SK-32H240S Television
I would like to replace the unknown transformer inside (PCB mounted.) I don't know the rating req.
Usually the transformers have the specs written on the case ..and all you need is to order one wit the same values..but if there seam not to be any written specs on the case...look for the user manual of the device ..and in there is specified the voltage and amperage of the power source .. or ..just look for a replacement part by the device name ...
I would suggested to measure it with a voltmeter ..but if it is defective ..Im not sure if you get anywhere..
If the device runs on batteries too ..you have the voltage needed by summing the batteries voltage ..(the values have to be the same ) //and the amperage will not matter that much ..if the difference is not high
Jul 24, 2011 | Flashpoint Cameras
Identifying specs of blown transformer on PCB
I have the same problem, with the same transformer. Did you ever find the specs?
I was thinking of buying the Frigidaire board, connecting to line voltage and measure output voltage.
Jul 09, 2010 | Frigidaire FAC126P1 wall/window Air...
I have a westinghouse tv model number SK-32H240S no picture
It seems that your unit has some sort of Video side, PSU fault, or a problem to the Video section that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Westinghouse SK-32H240S Television
Astar MP-27BH power transformer.. will pay
Check this link to find the power supply you're looking for. The transformer itself it might be impossible to find it.
Good luck.
Nov 09, 2009 | Astar LTV-2701 27 in. HD-Ready LCD...
SK-32H240S Gets past the "W" then goes black, with sound.
one of your transformers probably blew. had same problem with mine so took it apart and saw the problem. did some research. Darfon makes the power board and you have to buy the whole board not just the transformer. could cost you around 200 dollars. best bet is to call a local tv repair company and see if the have spare transformers for that lcd.
Jul 01, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Fried transformer in air handler above board no #'s or voltage specs
What you need is a 24 volt transformer that has a rating of at least 40VA. 120 volts is the primary and 24 volts is the secondary voltage. You should try to figure out why the transformer burnt out first.
Paolo
May 05, 2009 | Heating & Cooling
Blown power transformer
Hi
regards robotek
Dec 12, 2008 | Audio Players & Recorders
Vtech DECT 6.0
get a multi meter and test the charging unit for 9v. if the transformer output to batteries is other than the 9.6, you will see that output.
it will say right on the transformer what the ouput should be.
it has to be at least what the output of what the battery is.
if it's not you'll need a new transformer.
i've seen this before where the battery output is 9v but the charger is only producing a limited out of around 3v.
Jan 14, 2008 | GE 28112EE2 Cordless Phone
275 people viewed this question
 Grubhead
Grubhead
