Question about Fujitsu ScanSnap Manager
When I put in the installation disk it gives me the following message: "You do not have a write authority for the installation folder. Make the selected folder writable." This is the second Fujitsu S1500 scanner I have tried. I got the same message the first time I tried ti install the scanner so tech support had me return the first scanner saying the software must be defective and sent me a new one. However, this one is giving me the same message. Please help. I have important documents I must scan immediately. Thanks.
JulesPCaut
  • 702 Answers
SOURCE: problem installing Scansnap S510
This is probably due to the program using the same folder for the new version of the program. Best solution would be to uninstall the new version, uninstall the old version and then reinstall the newset version only.
Running a registry cleaner in between does not harm.
One other thing to try is an uninstall program, but I am not sure that will help.
Posted on Apr 23, 2009
  • 4 Answers
SOURCE: PFUSSMON HAS STOPPED WORKING ON MY SCANSNAP S1500
Find your specific scansnap product and update it:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
A user had a similar issue and I found this update for the scansnap S1500 manager:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/s1500.html
This occurs with certain Intel dual core processors, so you might be effected accordingly.
--Rob
Posted on Aug 14, 2009
SOURCE: I try to scan to folder and get the error message
All you need to do is set up Profiles for scanning. I made a short video tutorial you can view here: ScanSnap Profiles – Scanning to Folder in Snow Leopard
Posted on Nov 09, 2009
Pulkit558
  • 472 Answers
SOURCE: Have just installed S1500 software and finished
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
Posted on Mar 07, 2010
  • 11800 Answers
SOURCE: Just bought (ex USA) new
Mechanical noises = mechanical failure. You will have to dismantle the scanner and inspect the pickup mechanism - the parts that move the paper sheets are defective: the movement of the motor isn't transmitted to the gripping pads, probably a gear is out of position or a linking pin has been sheared off.
If you can't fix them yourself then the unit is pretty much dead : these replacement parts aren't available anywhere, not even the repair shop of a dealer - the parts and the labor to install them would cost more than a new scanner.
But you could search for another defective scanner on which the pickup mechanism is in good working order then buy it and cannibalise it for those parts. Or you can search at repair shops for same.
Posted on Dec 19, 2010
My Dell Latitude D630 unable show the external hard disk existing in windows expoler. Right click and select "manage" on "My Computer", follow by click on "Disk Management" I...
what u need to do is in the disk management right click on the external hard disk and click on change driver letters and path and give uniqu letter then click on and u will be able to see it in my computer and will work fine.
Sep 16, 2011 | Dell Latitude D600 Notebook
Tip
How to back up a offline disk folder
<p>Backing up your computer in a folder on the hard disk that goes offline, because sometimes surprisingly simple for the Windows Sync Center. You have a network available offline. Your computer will copy the backup of the hard drive of your computer's hard drive when you're online. The folder will appear as if it were accessible online, because the files are copied to the folder on your computer and then sync when the device is online. <br /> <p><br /> <p>1. Click "Start", "computer" and open the folder with your backup folder. Right-click the backup folder and click on "always available offline." <br /> <p><br /> <p>2. Waiting for the files in the directory so that the copy on your computer available offline. <br /> <p><br /> <p>3. Right-click again on the backup folder and click on "Map Network Drive". Click "Finish". <br /> <p><br /> <p>4. Click Start, Control Panel, System and Security "and" Backup and Restore. "Click" Create Backup.<br /> <p> <br /> <p>5. Select the mapped drive that you defined earlier in the Drive list. Click "Next" and follow the steps to complete your backup to adjust. Click Save Settings and perform the backup. " <br />
on Jun 22, 2011 | Computers & Internet
I am using Windows 7. I get an error message from iTunes "The folder iTunes is on a locked disk. What is an easy way for someone not computer savvy to solve this issue?
  1. Go to your Music folder
  2. Select the iTunes folder
  3. Share it with Homegroup (Read/Write)
FOLLOW THE IMAGE BELOW AND YOU SHOULD BE GOOD :)
Apr 08, 2011 | Apple iTunes
When i try to scan, it gives me the following message "Undefined error occurred. (0x8021001F) A probably cause is that the system is unstable. Reboot the system. If this does not resolve the...
check in your scanner panel if there is any error showing like U 1 or any other message.if not then your scanner is perfect and check your system
Mar 21, 2011 | Fujitsu ScanSnap S510
Installing of Office 2010 Professional stopped due to an error 1303, which says "Set up cannot access the folder C:\ProgramFile (x86)\CommonFiles\MicrosoftShared\MSClientDataMgr
Hmm i think this one you may have to follow that path as far as you can go and copy that folder in the "MicrosoftShared" folder. Ive ran into this problem before. The MSClientDataMgr folder should be in the install disk somewhere...just gotta look for it.
-mk3ride
Dec 30, 2010 | Computers & Internet
Unable to download folders (photos, personal documents, etc) from 5 y/o Pentium PC to IBM TravelStar 2.0 USB External Hard Drive with following message appearing... "Cannot create and replace (folder)...
Can you "read" any files from the external disk-drive?
Can you "delete" any files/folders from the external disk-drive?
Can you click 'File' and 'New' and 'Folder' to create a new folder on the drive?
Dec 11, 2010 | IBM TravelStar 40GN 40 GB Hard Drive
New portable Win7 won't make recovery disk
Okay....take a deep breath, we'll do this step by step.
1. Go to the following link: http://www.msi.com/index.php?func=driverfile&dno=9927&i=0
2. Select where you want to download the file from. It's best to pick the one that reflects your location.
3. Once the file has been downloaded, extract the folder to someplace you can find it again, e.g. Desktop or MyDocuments or something like that.
4. Run the file called "setup.exe" (without quotes)
5. Follow the directions of the installer
6. Taadaa! All done, you can relax again.
Good luck and don't hesitate to message me if you have any questions/need help.
Dec 26, 2009 | Computers & Internet
Windows XP SP2 Repair
Solution: Rename the C:\WINDOWS\SYSTEM32\CATROOT2 folder to something such as catold to prevent WinXP's Setup program from locating the folder and halting the installation. If you are still in Setup, press SHIFT-F10 to launch a command prompt from within Setup. At the command prompt, type cd\win dows\System32 to open the System32 folder and then type rename CATROOT2 catold, press ENTER, restart the computer, and attempt the upgrade again.
If you cannot reach a command prompt from Setup, reboot the computer from a Win95, Win98, or WinMe startup disk and rename the folder from the command prompt. You can also launch a command prompt by booting from the WinXP installation CD and running the Recovery Console.
Mar 25, 2009 | Toshiba Satellite 5105-S501 Notebook
Disk is Locked Error
If the My Music folder is in the wrong location or incorrectly assigned in the Windows registry, you may see one of the following error messages:
  • "The folder iTunes is on a locked disk or you do not have write permissions for this folder."
  • "The folder iTunes cannot be found or created and is required. The default location for this folder is inside the Music folder."
If you see one of the above errors, follow these steps to troubleshoot this:
  1. Verify the location of your Windows XP My Music folder. The default location for this folder is
    C:\Documents and Settings\username\My Documents\My Music
    If you do not have this folder at the default location and have not moved it to another location, consider creating one inside your My Documents folder.
  2. Download and install Tweak UI from the Microsoft PowerToys website at http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx Note: This utility is for Windows XP only. Please review the system requirements before installing.
  3. Once you have installed Tweak UI, open it from the Start menu.
  4. In the column on the left, click on the plus symbol (+) next to My Computer and select Special Folders. ht1866_01.jpg
  5. In the right pane on the Folderlist, click My Music.
  6. Click the Change Location button. You may see a warning message appear with precautions for changing this setting; after reviewing the message, click Yes. ht1866_02.jpg
  7. In the resulting window, browse for the My Music folder as described in step 1, and click OK. ht1866_03.jpg
  8. Reinstall or open iTunes.
Oct 13, 2008 | Apple iTunes
Computers & Internet Logo
491 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
