Question about Western Digital Computers & Internet
I have an 80GB Passport that has always worked fine. But now it is giving me an Unknown Device error. I am not using a usb hub and it is using the orginial cable. Is there any help or it just dead?
    Problem Solver:
  • 15 Answers
It most likely is not dead. the board that adapts from the hard drive to the usb is normally what goes bad. you can purchase a 2.5" external hard drive enclosure to transfer the hard drive into once you take it out of the passport casing. if you use an old credit card or a thin flat head screw driver you should be able to pop the casing off of the passport to get to the hard drive. but there is still a chance that the hdd could be dead. just more likely the adapter board.
Posted on Mar 21, 2011
WD 500 g Passport Power Surge
The power surge error means that your external drive is drawing more power than your USB port can supply. The best solution is buying a powered usb hub (USB hub with external power source) and connecting the device through that.
Alternatively (if you're desperate), you could try testing it in other ports - for instance, if you're using it in a front USB port, try the back ports and vica-versa. If you need something on the drive urgently, and you have the option, you could always try plugging it into another computer and getting the data that way, but of course this is only a temporary fix.
The fact that the drive is in a NTFS/FAT32 format shouldn't make a difference with regards to the main issue, which is power....but like I said, your best solution is unfortunately to buy a powered hub and running the drive through that.
Good Luck,
-LL
Feb 23, 2010 | Electronics - Others
Western digital passport i/o device error
90% of the time this is a power problem. The USB port on the computer can not supply enough watts. Use an external USB hub that has a 5V power supply.
Oct 14, 2009 | Western Digital 250GB MyBook External USB...
Passport not been recognise
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Aug 04, 2009 | Western Digital Passport WDXML800UE...
ST-500 not recognized with Epson CX9400 printer
Printer is draining USB power resource. Add a powered USB hub and run drive off of that.
Jul 23, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a WD Passport drive that I want to use through a Targus mini USB hub. The Passport drive has power, but it will not install through the hub. Apparently wants a driver and apparently they don't have...
The reason your full sized drive works fine and the passport doesn't is that the full sized drive has it's own power supply and only uses the USB for data transfer. The Passport drive requires much more power from the USB to spin up, so, if you want to run it through the USB hub at the very least you will need to replace the USB hub with a powered one.
As for a driver, you don't need one to use the passport on XP that's why you can't find one but the Passport does require a dedicated port(2 for Amperage on some systems) or will need to be plugged into a powered hub or it simply won't get enough juice to fire up. That is the reason it won't show up.
In short, buy a powered hub, or plug it in direct. Nothing else is likely to work.
Hope this helps figure it out
Chris
May 07, 2009 | Western Digital Passport 320GB External...
Drive not recognized
Have a look at this Website>
http://support.wdc.com/product/install.asp?level1=2&lang=en
May 07, 2009 | Western Digital 80GB Passport 2.5" USB...
Western Digital Passport 160 GB external HD won't load.
WinXP SP2 blocks the use of the drive because it thinks it draws too much power. But there is a simple procedure to override this (from WD site):
"Problem:
Under Windows XP, an error message of "Power Surge on Hub Port" or "USB device has exceeded the power limits of it's hub port" is displayed when connecting a USB device to a USB port on a computer or Hub.
Cause:
Under some computers, USB devices are only allowed to draw a maximum of 500 milliamps (mA) per connection from the USB port on the computer system or from a USB hub. Under the Windows XP Operating System, with the release of Service Pack 2, if a device attempts to draw more than this (500 milliamps), a USB port balloon message is displayed to indicate this over current condition. When connecting a USB device that draws power from the USB bus, a very brief over current condition is sometimes detected by the OS, and the warning message is displayed.
Resolution:
This message has no affect on the functionality of the USB port. The USB hard drive should still function correctly on the USB port regardless of the error message. To prevent the USB Power Surge Alert message from displaying, please complete the following steps:
Click on Start.
Click on Control Panel.
Double-click on the System Icon.
Click on the Hardware Tab.
Click on the Device Manager button.
Click on the + next to Universal Serial Bus Controllers to expand the selection.
Right-click and select Properties on any listing that displays USB UNIVERSAL HOST CONTROLLER.
Click on the Advanced Tab.
Check the box that says: Don't tell me about USB errors."
This works fine, and the drive works fine afterwards. I suspect it actually draws less power than they say. Maybe it has a brief power draw spike on startup, but it's running power seems less. In any case, it works fine without the Y cable. I do think it is tacky that WD doesn't give the cable for free, since my $7 Sabrent 2.5" Hard drive enclosure came with a y cable.
But most likely the drive will work fine for you. It is a lovely quiet drive, and takes up no space at all.
Feb 01, 2009 | Western Digital Passport 160GB External...
WD Passport appear as an unknown device
try it again, after going to wd dot com, and getting and installing a new set of drivers..
Oct 13, 2008 | Western Digital Computers & Internet
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Computers & Internet Logo
26 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
