Question about Jura Capresso CoffeeTEAM TS 46505
CoffeeTeam TS grinder won't start We've had the CoffeeTeam TS coffee maker/grinder for about a year. It's generally worked fine, though sometimes the grinder wouldn't start and we needed to bang the coffee maker on the counter to start it. Now the grinder doesn't seem to work at all. We've cleaned the feeder channel, but that hasn't helped. My wife is happy with this coffee maker, when it works, and we'd really like to find a way to get it to grind again!
  • 14 Answers
SOURCE: unable to make coffee automatically using whole beans
The rivets in the back of the Jura Capresso units are actually oval security screws. The bit that removes these screws are made of a very hard metal and cost me over $50.00 two years ago. Also many people who attempt there own repairs tear off the little plastic tabs that keep everything together nice and tight. We repair Jura Capresso Krups Bosh etc. www.hotncold.com
Posted on Aug 03, 2008
SOURCE: "Fill System/Press Steam"
Remove the tray at the front of the machine. Look inside and you will see a rubber flap which separates the right and left side of the machine. Gently lift this to the right and look inside to the left (a small mirror like from a womans compact and a flashlight will help you see in there.) You will find a small circular screen (about the size of a half dollar.)  You need to wipe ALL the coffee grinds off of this screen. That should fix the problem. If you use dark beans, you are probably grinding them to fine and some of the oily residue is sticking to this screen. Try grinding the dark beans more coarsely. Only change the grinder WHEN IT IS GRINDING by adjusting the litlle knob in the box where you place the beans. If the problem started just after changing the filter you may have air in the water line and it needs to be flushed. Try running the tea portion hot water until it clears. These suggestions were given to me by Capresso and actually worked for my machine. Good luck. Gary
Posted on Dec 14, 2008
  • 60 Answers
SOURCE: fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Posted on Jun 02, 2009
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Posted on Aug 14, 2009
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
  • 2069 Answers
SOURCE: My Jura S9's grinding unit clogged (due to Peete's beans)
Use the TABLET CLEANING. please refer to this manual here on page 24 if you don't have one.
Regards
Posted on Apr 28, 2010
CoffeeTEAM TS leaks water
Hello, what I have found is the most common cause of water leaking out of the bottom of the capresso team coffee maker is a leaking silicone hose that runs to the boiler (see the photo below showing the split in the hose). The replacement silicone hose needs to be safe for beverage dispensing, food & dairy processing, taste and odor-free, with a temperature range of -75? to 350? F. All you need is a sharp pick, a phillips screwdriver, and a pair of needle nose pliers. Remove the four rubber pads on the bottom using the pick. Use the screwdriver to remove the six screws holding the bottom plate on. Remove and replace "BOTH" hoses using the needlenose pliers to pinch the hose clamps. Better to play it safe while you have it apart. If one is bad the other is likely not far behind. I hope this helps.
Jan 28, 2014 | Jura Capresso CoffeeTEAM TS 46505
Coffee bean light won't go out when full and coffee won't work
Hi coffee friend I have just answered this question. I think
After you have done all the cleaning you have done, you can try this: do check that all knobs correctly set. That the steam spout is closed. that the water tank sitter correctly
Disconnect from power, wait 2-3minutes connect again and hope for the best.
Kolbrun
Apr 16, 2012 | Solis Palazzo Espresso Machine
Does the gaggia titanium have a grinder sensor? Can anybody tell me where it is? I have the "grinder blocked" message. I've cleaned the grinder, Shute and doser door, but I still have the...
Hi...Grinder blocked message is ..when you make coffee there is no current going into the grinder. In other words the grinder motor is blown(coil windings in the motor is blown). You have to replace the motor. The problem is common with Gaggia, Talea, Odea coffee machines. hope your machine is less than 2 years old to get fix under warranty.
Apr 10, 2012 | Gaggia Titanium Espresso Machine
WHY WON'T THE COFFEE BEANS SLIDE DOWN INTO THE MILL TO BE GROUND???
Beans as you know have lots of oil on them. Over a period of time, the oil from the beans get caked up on the shoot, or hopper area where beans are filled/stored and so it needs to be cleaned. First get as many beans out as possible, then take a soft no lint cloth and put little vinegar on it, and clean in area best you can. ( make sure machine is unplugged ofncourse) then, spray a little Pam in that area, let completely dry, then add beans and should flow easier . Thanks for using, mike from fixya
Jun 15, 2011 | Jura Capresso CoffeeTEAM TS 46505
Our DGB-700 has stopped grinding the beans. The motor sounds very weak. I have taken it apart and cleaned thoroughly with no good results. Can it be repaired or is it just time to "move on"...
I use Capresso CoffeeTeam model #454 10 cup 50 oz digital coffeemaker burr grinder combination with four grind settings. Now it is more than 5 years old, works every single day without any problem. Capresso has the great customer support. Its price for the refurbished item is compatible with the price of your Cuisinart. I am not sure it is the solution for you but I am very happy with my coffeemaker.
Jan 04, 2011 | Cuisinart Grind Brew DGB700 12Cup Coffee...
I have the saeco vienna coffee machine and lately it does not make a good coffee, it looks more like tea. I have the setting set to the strongest coffee and I also notice that the coffee grounds are really...
You can remove top panel and find the grinder.
Remove the limit lock screw and udjust in more fine grinding manualy. So now you can have more fine grinding.
Remeber that you have to move only two step at a time, then make coffee and then move again to more fine, this will avoid blocking the grinder and also burning the grinder motor.
Also before doing the above you can ckeck the grinding burrs if they are in good condition or they need to be replaced.
Sep 03, 2010 | Saeco Vienna SuperAutomatica Coffee...
Jura F70 Grinder stopped working
The switch or photo sensor is not sensing any beans present.
So it can't continue
Use torch to inspect bean entry area
Small brush etc
Apr 18, 2010 | Jura Capresso Coffee Makers & Espresso...
Saeco Primea new machine - slow dripping
look in manuel how to ajust the coffee grinder its grind the coffee to fine when you ajust the leveler of coffee move it only when the grinder work do a few ajustment it will be fine pierre
Dec 25, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Slow
Adjust your grinder to grind coars, when the machine "drip" out the coffee then it is to fine, adjust the grinder two step and then you have to maker 3-4 cup of coffee to make your new tasty coffee;-)
Mar 19, 2008 | Saeco Vienna SuperAutomatica Coffee...
Jura Capresso CoffeeTEAM TS 46505 Logo
112 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
