Question about Zanussi ZWF1640 Front Load Washer
Machine stops after about 2 mins. drum doesn't seem to go around, doesn't have an Error message, just gets stuck with remaining washing time showing on display. Drained plug at bottom and made sure nothing was blocked. Tried it on a spin and drain but still gets stuck Swithed machine off and on, thinking the micro processor may set itself. It double clicks at the beginning of the cycle (this normally happens at the end)
  • 236 Answers
SOURCE: Zanussi wdj 1094 washer dryer
possibly the motor brushes are worn, the clicking is the pcb relay changing the motor direction.
Posted on Jun 01, 2007
  • 641 Answers
SOURCE: E20 error message
The E20 error code means - not draining It seems more as an issue of a clogged drain line or malfunction pump.
Posted on Aug 04, 2007
  • 183 Answers
SOURCE: Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Posted on Aug 30, 2007
  • 1462 Answers
SOURCE: Drain pump removal on Zanussi FJR1254 Washing Machine
not easy.suggest you disconnect pump and power up independently as an easy way to check if it runs
easiest way to remove pump - and its awkward - is to undo the 3 screws holding the pump to its housing
Posted on Jun 29, 2008
futureloginn
  • 734 Answers
SOURCE: Zanussi IZ 12 Washing Machine Front Load
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Posted on Dec 03, 2008
Washing Machine cycle not completing with washing inside I have a Hisense WFNA9012 washing machine that will only finish a cycle when the drum is empty. Put any washing in it and it seems to get stuck 20...
it seems that the water sensor is not working , look for a small 5mm pipe near the bottom of the drum after removing the back panel, take it off and blow gently into it you should hear a click and one when you release the air if you do then the water sensor is in order then go to the small pipe you took it from and clean the [pipe out with a pipe cleaner or a metal rod as this pipe can get blocked with soap goo, replace the pipe and try the machine again. good luck eric
Jan 01, 2018 | Washing Machines
Can you help? we have a hotpoint aquirius 1100 waher, the drum seal seems to keep getting dirty, wife keeps machine spotless and allways cleans seal, but constantly gets brown scum going onto washing and...
hi my trick is .................... WHITE VINAGER ...YES VINAGER ... right get 5 ltrs of white not brown or your cloths will STINK :))) now wip some around seal .... tip 2 ltrs into drum ...and rest into powder capartment .... leave for 5 min ...then put on boil wash ...DONT PUT ANY THING ELS IN ..IE CLOTHS OR POWDER.. it normally gose .. wash through x2 times with powder ect b4 any cloths go in . bsc appliances bristol 07779933829 postal service too.
Feb 26, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Maytag MAF 1675 showing an 'Error 2' message
sounds like money, well it might just be money
probably money stuck in the pump
Jun 11, 2009 | Washing Machines
Changing the drum
I fixed the problem (following the user's guide).
1. After reinstalling the new drum unit into the printer, keep the front cover open.
2. Press "Clear/Back" on the machine
3. Press "1" and when the LCD shows "Accepted", close the front cover.
May 14, 2008 | Brother DCP-8040 Copier
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
Zanussi ZWF1640 Front Load Washer Logo
59 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
