Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Do you have any idea what the problem would be if the dishwasher fails to stop, The digital dial counts down down until 1 and then never drains or switches off, just keeps on going
    President:
  • 1,140 Answers
The "1" is actually an error code indicating a fault in the water heating circuits. The endless cycle means the water isn't reaching the desired temperature or, in some cases, the controller isn't receiving the correct signal to indicate the water has reached the correct temperature. If the water doesn't reach the desired temperature, the wash cycle wont advance and the "1" will be displayed.
This is usually due to a failing (or failed) water heater or a fault in the control module. Often, one of the pins for the heater relay has burned out on the PCB causing a dry joint. This can sometimes be re-soldered. Occasionally, it can also be a fault with the NTC water temperature sensor (Negative Temperatire Co-effecient), but this is less common.
There are some simple tests you can do without any disassembly or electrical testing.
- If you have an RCD (residual current detector) fitted locally to the dishwasher or in your fuse box / consumer unit, a failing or failed water heater would usually trip this. If an RCD is fitted and is not being tripped, I would start with a visual examination of the solder joints for the heater relay on the control module
- Check whether the water is getting hot. Start a quick wash cycle and leave it to run for about 10-15 minutes. Then open the door and check for the presence of steam and/or test the water in the bottom of the washer by hand. It should be hot, not luke-warm.
These are only simple checks to determine the best place to start looking for the fault. You will still need to do some further testing to find the exact cause of the fault. This will require some dis-assembly of the dishwasher and you will also need a Torx T20 screwdriver and a multi-meter for electrical testing of the water heater.
If you have these tools and would like to try fixing this yourself, please let me know. If you are in the UK, the control module and water heater are about £100 each to replace, so you should take into account of the age of the washer before replacing these. The control module can be replaced fairly easily on a DIY basis, however the water heater and NTC are significantly more difficult and may be best left to a professional service engineer.
If you need further assistance. Please could you also confirm the correct model number of the dishwasher (I don't recall the SGS43C12 having a digital time display) and whether you are on a 120 or 220-240 volt supply.
Hope this helps.
Regards,
BElectric
Posted on Mar 21, 2011
My bosch dishwasher counts down to 1 minute on any cycle but will not drain except by manually hitting cancel. I've replaced a defective drain pump but it still does this- any ideas?
The pressure chamber or hose (pressure chamber to sump) may be blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Apr 18, 2013 | Bosch Dishwashers
Washing cycle wont complete
I had the same problem. Called the repair man, who said it was a defective control board. He ordered a new one, replaced it and now the problem is fixed.
Dec 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Homark dishwasher programs; ( Italian ?? )
just turn the timer around slowly and you will hear it start to drain
Dec 11, 2009 | Dishwashers
When the washer gets to 1 in the cycle, it doesn't stop washing.
try running the test cycle or running delicate economy in that cycle it gets up to 150 degrees in the very first cycle let it run 15 or 20 min see if the water is screaming hot it is not and Luke warm it is not heating it is most likely a control board heaters very rarely go out
Jul 24, 2009 | Bosch SHU5316UC Dishwasher
Cleaning Cycle not Starting
Please provide the model number and the approximate age of the dishwasher.
If this diswasher uses a turning dial to select the cycle, which turns as the dishwasher progresses, I strongly suspect that this timer has failed and needs replacement. Especially since the soap door never opens. Does the dishwasher drain during and at the end of the full cycle?
Mar 29, 2009 | GE Dishwashers
Won't complete the cycle
Try using a quick cycle and see what happens. Don't use sanitize or any extra heat cycle. Sometimes during sanitize high temp rinse or other cycles the timer motor is stopped until the water heats up. The sensor could be defective. Not all machines do this and I'm not real familiar with your particular one.
Jul 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Electronic controls don't count down properly
you have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
Nov 20, 2007 | Bosch SHU5315UC Dishwasher
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
589 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
